Old 11-07-2018, 03:21 PM   #1
143paul
143paul's Avatar
Default What is the best way to run a wire through the roof?
I have done a few searches without much luck, so any help is welcomed, thanks.
I am mounting a light bar on the roof, and I think the best way to run the wires will be up the B pillar and out through the roof.
For the solar, I am using the standard roof entry - https://www.amazon.com/Proline-Weath...of+cable+entry
but for the light bar, the wire harness will not work through that option.
What other great ideas have people used in the past?
143paul is offline   Reply With Quote
Old 11-07-2018, 04:45 PM   #2
autostaretx's Avatar
Default Re: What is the best way to run a wire through the roof?
What is the issue with the harness and the Proline unit (just to help us give better suggestions).
Some people have simply used conduit elbows instead of the "streamlined" (and dual-wire) Proline heads.
The up-side for that method is "only one round hole" (easy to drill)
The down-side is "kind'a ugly bent pipe sticking out of roof" appearance.
Somwhere in the infinite forum threads there's a photo or two of that style.
There are also far flatter shaped covers, too.
Be aware that the B pillar includes the seat belt retraction mechanism. Care should be taken in keeping your wires from interfering with it (and the squib explosive retractors).
Old 11-07-2018, 04:55 PM   #3
john61ct
Marine quality cable "clams", Blue Sea is good.
http://www.cruisersforum.com/forums/....php?p=2733393
john61ct is offline   Reply With Quote
The Following User Says Thank You to john61ct For This Useful Post:
143paul (11-07-2018)
Old 11-07-2018, 05:06 PM   #4
143paul
143paul's Avatar
Thanks guys for your help
Dick - the problem with the proline is that the light's waterproof connector will not pas through that fitting. I could cut all the wires and re connect, but I am hoping for an idea that avoids that.
John - thanks for the marine clam idea - I will check that out.
Old 11-07-2018, 05:43 PM   #5
Here are a bunch of through-hull clamps and covers: https://www.fisheriessupply.com/mari...&ct=4294967100
(reached by visiting https://www.fisheriessupply.com/mari...upplies/wiring and ticking the "Cable Glands" choice in the left margin menu)
p.s. if there is a marine supplies store in your area, they're a great place for hands-on puttering looking for wiring, connector, fuse block, switches, etc possibilities.
Old 11-07-2018, 06:07 PM   #6
john61ct
You may need a "full split" style
e.g. https://www.defender.com/product.jsp...996&id=4140088
Other terms to google
Cable Glands / Cable Bushings / Cord Grip Connectors / Strain Relief
Old 11-07-2018, 07:45 PM   #7
bobloblaw
Whats the best wire to run on the roof of a sprinter (through a cable clam)? Something like SOOW Cord? I need to run wire to a light bar as well and was going to use regular marine duplex cable, but it's flat and wont work with a clam
bobloblaw is offline   Reply With Quote
Old 11-07-2018, 09:36 PM   #8
Kevsuda
I've run duplex through a cable gland several times without issue. Not sure if that's the same as a clam you're talking about.
Kevsuda is offline   Reply With Quote
Old 11-07-2018, 10:30 PM   #9
Cable Glands don't demand "round"
https://www.fisheriessupply.com/scan...-seal-ds-multi
and
https://www.fisheriessupply.com/scan...-bulkhead-seal
Old 11-08-2018, 12:36 AM   #10
bobloblaw
They don't? It seems like all the cables running through glands in your pictures are round. McMaster even sells specific glands for building (flat) cable: https://www.mcmaster.com/7935k11
I'd be happy to run duplex through a clam.. I just dont want to be the first experiment and have a leak in my roof.
