Old 12-13-2018, 04:06 PM   #1
OldWest
T1N Westfalia
Default Part: Fresh Water Tank Drain Valve
Thought someone had asked re a replacement but couldn't find post.
On the James Cook Friends Forum, there is a thread
http://forum.james-cook-freunde.de/v...hp?f=16&t=6315
With a post linking to a red lever drain ball.valve for the one under the driver side body with the chained screw on cap.
https://www.amazon.de/Stabilo-Sanita...ds=kugelventil
More info pasted from that link here:
Stabilo-Sanitaer Kugelhahn 1 1/ 4 Zoll DN32 für Wasser Messing Kugelventil Absperrventil Heizung Absperrhahn
Preis: EUR 9,74
Alle Preisangaben inkl. deutscher USt. Weitere Informationen.
Note: For the drain valve under the Suburban hot water heater, see this thread: https://sprinter-source.com/forum/sh...ad.php?t=60319
Old 12-15-2018, 02:08 AM   #2
CaptnALinTiverton
T1N Westfalia
CaptnALinTiverton's Avatar
Default Re: Part: Fresh Water Tank Drain Valve
I replaced the drain valve equivalent to the one that was there (OEM I guess) and the new one leaked too. I ended up making a tee with barbs front and back with a brass pipe down and a 1/4 lever shutoff below (ends up atop of wheel well). No more leaks problem anymore.
(How many threads do you have going on this subject)?
AL
CaptnALinTiverton is offline   Reply With Quote
Old 12-18-2018, 02:16 AM   #3
Riptide
Riptide's Avatar
AL
Al, this thread is about the big fresh water supply tank, NOT the hot water heater that you also replied to...
...unless you made a tee replacement for both tanks.
Riptide is offline   Reply With Quote
The Following User Says Thank You to Riptide For This Useful Post:
CaptnALinTiverton (12-19-2018)
