Old 09-03-2019, 02:15 PM   #1
Snowdrift
Default Cummins Onan generator maintenance
What do people do to maintain their Cummins Onan propane generator? Thank you
Snowdrift is offline   Reply With Quote
Old 09-05-2019, 02:35 PM   #2
marklg
Default Re: Cummins Onan generator maintenance
I found a local "generator whisperer guru" who changed the oil, and tuned it up. It didn't run well before and has run well in the two years since. It is important to run it every few weeks or so under load.
Regards,
Mark
Old 09-05-2019, 02:55 PM   #3
avanti
2014 GWV Legend 3500 I4
avanti's Avatar
Periodically running the genset under load is good advice. However, "every few weeks" is a bit of an exaggeration. This is especially true with the propane version of the genset, for which this is much less important than with gasoline units. In my experience (14 years and two rigs) a few times/season is adequate to keep the commutator surfaces clean. If I had gas, I would do it more often, to avoid carburetor issues. Generally speaking, the propane units are less trouble-prone than gas.
--Pete
