Old 08-03-2019, 05:03 PM   #11
Yob2kanobe
2017 Unity U24MB LL+
Default Re: Mercedes-Benz Peculiarities
I read a similar post on this and apparently all MB cars and trucks automatically open the fresh air door after a given amount of time to try to keep things from freezing up, I suppose, However this will keep the air not so cool as it is cooling outside air instead of recirculating the cab air. You can restart as you are doing or just turn the a/c off and back on again.
Yob2kanobe is offline   Reply With Quote
The Following User Says Thank You to Yob2kanobe For This Useful Post:
Scarecrow (08-03-2019)
Old 08-03-2019, 05:58 PM   #12
Scarecrow
2017 LTV Unity Murphy Bed
Scarecrow's Avatar
I tried turning the A/C off and back on, but that did not work.
Old 08-03-2019, 07:22 PM   #13
Bobnoxious
Please describe in greater detail about turning A/C on and off? Specifically, the time duration between on and off? Also describe did not work. Fan not operating?
Aren't you under warranty?
Old 08-03-2019, 07:30 PM   #14
GoodToGo
Hmmm... Mine always recovers itself by simply turning off the engine, and restarting it. No lengthy waiting period. Adjusting the controls on the dash does not help, other than reducing the fan speed. I sincerely do not think it is a freezing issue.
I do the same with my 2016 and that works the best. At least the A/C comes back on.
GoodToGo is offline   Reply With Quote
Old 08-03-2019, 07:38 PM   #15
Scarecrow
Scarecrow's Avatar
I waited up to three minutes. Tried rolling down the windows and traveling for twenty. Once this occurs, it does not recover until I pull over and shut the engine off. I can restart it immediately - problem fixed. It seems to get locked in a non-cooling state. When I say non-cooling, I mean the cooling level is so low as to be laughable - not that it disappears completely. The fan will go as high as it can, but the cooling is mediocre. Once restarted, the cooling is very aggressive. Next time I'm in a dealership, I will ask them.
This is not a frequent occurrence. I cannot make it repeat itself at will. It will happen on occasion.
Old 08-03-2019, 07:43 PM   #16
Scarecrow
Scarecrow's Avatar
I have tried adjusting both knobs on the dash.
Turning it off, thinking it had frozen.
Turning on the cab air recycling.
Turning off the A/C, then back on. Both short intervals and long.
Adjusting which vents are being used.
Turning the heater on and off.
Turning the defrost on and off.
Unlocking the doors.
Turning the flashers on and off.
Standing on one leg while driving.
And turning the radio on and off.
I even listened to - God Forbid!! - rap music for five minutes.
No amount of cussing fixes it.
Only a complete motor restart.
I think this vehicle is possessed.
I need an M-B Exorcist!
Old 08-03-2019, 09:12 PM   #17
Bobnoxious
Not saying it is related, One thing I thought peculiar in the owner's manual was making small incremental temperature dial adjustments. I don't recall seeing it mentioned by competitors.
Intermittent issues are difficult to isolate and diagnose. Unless of course somebody has already figured it out.
Old 08-04-2019, 11:15 AM   #18
irvingj
2015 RT SS Agile (3.0L)
Yep, you got it -- it's possessed! (For me, the "standing on one leg" trick usually works....)
2015 RT SS Agile, 3.0 V-6
Old 08-04-2019, 01:23 PM   #19
geds
2018 Serenity
Your problem is you forgot to hold your nose just right!
geds is offline   Reply With Quote
Old 08-04-2019, 03:45 PM   #20
Scarecrow
Scarecrow's Avatar
You might be onto something. My Dad always said "Son, you aren't catching any fish because you aren't holding your mouth right... preferably closed."
The Following User Says Thank You to Scarecrow For This Useful Post:
CJPJ (08-04-2019)
