Old 01-19-2017, 07:00 PM   #1
Default Underlined blue after Youtube
I've noticed that any text after a Youtube link/embedded screen gets colored blue and highlighted. I find it annoying.
A work-around is to just put a valid non-Youtube link immediately following the Youtube embedded link.
eg. - www.sprinter-source.com
That somehow breaks the underline command.
Perhaps this information will help to resolve the issue.
Old 01-19-2017, 07:32 PM   #2
Default Re: Underlined blue after Youtube
You can used to be able to prevent the underlining by changing the start of the YouTube address from https to http
(there's another "suggestions" thread about this)
Whoa! As the following shows, removing the "s" no longer works to 'fix' it... probably a consequence of Sikwan changing the entire forum to https
Examples: this first one has the "s" removed from (the protocol portion of) the URL:
... so this subsequent text is not underlined (unless i tell it to)
Here is a video without adjusting the URL:
... so this text does get underlined (as does my sig)
... until i follow your work-around by adding a link http://aie-services-2.net/Sprinter/ which seems to fix it.
Old 01-19-2017, 07:48 PM   #3
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
OK I'll try a test...
First your straight link with https...
and now putting two x square bracketed /url at the end...
[/url]
and we'll see if that works.
Keith.
Edit. So what did I do different as I didn't get any extra underling in either case and you can see my extra /url at the end?
36,000 miles from New
Old 01-19-2017, 10:43 PM   #4
I used both the Dick method and the Keith method of posting. There was a difference in the line spacing (extra return key hit) for Keith's.
Dick's way. (No extra line space.)
Keith's way. (Extra line space.)
Doesn't seem to matter now.
Maybe it was fixed??
Or maybe not. See my next test.
Old 01-19-2017, 10:49 PM   #5
This time I copied and pasted the above message and then pasted Dick's original 1st video above for video #1.
Old 01-19-2017, 10:52 PM   #6
The blue underline returned all the way down through my signature.
Old 01-20-2017, 01:37 AM   #7
When i posted my YouTube links, i was very lazy. I simply put them in-line with the message *without any URL tags*
(i let the forum fill them in automagically)
So i'll try that: here is an insertion, with no blank line, WITH the URL tags:
(the text appearing here seems to have no underlining issues)
Here is the same insertion, no blank line, WITHOUT the URL tags:
Now a URL to "fix" the issue: https://youtu.be/RICBu_P8JWI (if it happened)
OHHHH.... the above two YouTube address both still have the https: protocol descriptor.
If i change it down to the "http:" version, the underlining bug returns: (no URL tags)
Here's WITH URL tags, but removing the "s" from the protocol:
I get the impression that the manual insertion of (at least) the trailing [ / URL is what's fixing it.
Perhaps the "automagical" embedding isn't getting the closing /URL ???
(i'll check by Editing this posting and looking for it)(see "OOHHHH" above added after that)
So the "new" behavior is: if you have "https" it will usually NOT underline the subsequent text.
If you have "http:" it WILL underline the subsequent text.
Having the [ / URL following the insertion seems to help.
There are two flavors of that... one is to use the paperclip icon... which inserts the full URL twice ... once as an argument to the URL tag (as URL="blahblahblah" ) and then once again between the closing and opening square brackets ]here[
The presence/absence of a blank line just before the video link seems to have no effect.
Joy
p.s. sikwan has been playing with it over in another thread (4.25 hours ago)
Old 01-20-2017, 02:34 AM   #8
sikwan
06 T1N Can
sikwan's Avatar
This is true. When we migrated to https, I changed the code to reflect that. However, every "old" post that contained the http (without the s) fix will underline everything afterwards.
Since youtube will always now be https, we should not be posting any youtube links with http.
autostaretx (01-20-2017)
Old 01-20-2017, 02:48 AM   #9
sikwan
06 T1N Can
sikwan's Avatar
It should be fixed now. The auto video loader was inserting an extra </a> tag.
The Following 2 Users Say Thank You to sikwan For This Useful Post:
Aqua Puttana (01-21-2017), autostaretx (01-20-2017)
Old 07-03-2019, 04:29 AM   #10
Garandman
Garandman's Avatar
So what is the tag for embedding a video? Don’t see it on the menu.
2006 Sprinter 118 ~ 16 Rial Transporter rims ~ 235/65x16
