Old 07-15-2011, 11:31 PM   #1
Old Crows
Calypso 2014 View Profile
Old Crows's Avatar
Default Outside Storage Ideas?
Hi! Anyone have thoughts on outside storage ideas? Hitch mounted boxes, boxes on top with a ladder? Other creative ideas???
Old 07-16-2011, 12:41 AM   #2
aljimenez
'13 LTV Serenity on '12 3
aljimenez's Avatar
Default Re: Outside Storage Ideas?
http://www.sprinter-source.com/forum...ead.php?t=5794
The Following User Says Thank You to aljimenez For This Useful Post:
Old Crows (07-16-2011)
Old 07-16-2011, 12:11 PM   #3
Zach Woods
Super Moderator
Zach Woods's Avatar
Hello Old Crows -
Lots of options / discussion here: http://www.sprinter-source.com/forum...ht=storage+box
Zach
Zach Woods - zwoods65/at/gmail/dot/com
The Following User Says Thank You to Zach Woods For This Useful Post:
Old 07-16-2011, 09:52 PM   #4
treehouselab
treehouselab's Avatar
Holds fiberglass propane bottle and hoses.
treehouselab is offline   Reply With Quote
The Following User Says Thank You to treehouselab For This Useful Post:
Old Crows (07-18-2011)
Old 07-18-2011, 06:56 PM   #5
Old Crows
Old Crows's Avatar
Thanks everyone! Lots to look at and consider!!!!
Old 07-21-2011, 05:25 AM   #6
david klair
david klair's Avatar
Here is a black hose storage compartment pre-prototype. It is 31"long x 14"wide x 6" tapering down to 4"deep. It works pretty good for a mock up so I have ordered some 1/8" aluminum and will make a real prototype this weekend.
This is my macerator dump/black hose. It is 7' long, but expands to almost 30'. I wanted a spot outside the van to store it along with the other sewer adapter pieces. Under the rear step seemed like the most logical place. Shown above is the 'box' hanging from it's hinges.
The hinge is a bolt that is threaded into a 'T'bar that slides into this Bosch Structural aluminum profile, one on each side.
This allows the box to slide out for easy access
and back in for a clean look. Here you can see the aluminum extrusion. It is taped with that super high bond tape to the bumper/step support.
This is the rear view. When I get the prototype welded up and painted black, it will blend in nicely. I am still searching for a latch that can be hidden up under the step that will lock the box in the stowed position.
I don't think I will have to stretch the hose out this far too often. This retractable hose and storage box combo is much easier for me fabricate and fit under the van than a 30' hose reel.
The 'box' is located where it is because the macerator is right there.
Here is the short run from the macerator to the 'box'. I will put the fabricated aluminum box and how it all finally went together on my conversion write up.
david klair is offline   Reply With Quote
The Following 2 Users Say Thank You to david klair For This Useful Post:
bpa (06-19-2014), normrp (07-21-2011)
