Old 07-31-2016, 07:19 PM   #31
jmoller99
Own a DAD ODB2 Unit.
jmoller99's Avatar
Default Re: Window Regulator Fix
The plastic part is attached in such a way that you can't replace it (its riveted in place). I have made up parts like this from 1/8 inch aluminum that work fine (install with the notch side facing down). Liberally smeared with lithium grease.
Keep in mind that the manual crank doors use an all metal riveted in part, not using a plastic slider at all.
The Following 4 Users Say Thank You to jmoller99 For This Useful Post:
alexk243 (04-29-2018), vanski (07-14-2018), Whhite Whhale (08-14-2016), wrpeterson (01-14-2017)
Old 08-01-2016, 02:17 PM   #32
jmoller99
jmoller99's Avatar
Here are some pictures of the actual plastic slider part with a ruler on it.
The part looks to be approximately 3 cm X 1.5 cm. It has a 6mm hole in the center.
The 1/8 inch thick aluminum part I make is 2x longer (1 3/4 inches) X 5/8 inches. I taper the ends slightly.
6.35 mm = 1/4 inch - so I use a 1/4 inch drill to make the hole and grind out the notch (you could cut it with a hack saw too).
The Following 2 Users Say Thank You to jmoller99 For This Useful Post:
Old 08-01-2016, 04:58 PM   #33
alexk243
KulAdventure
alexk243's Avatar
Default
Awesome! Thank you! Going to try and make it tomorrow
Sent from my HTC One using Tapatalk
2004 T1N Passenger 140" (Conversion in Progress - Build Thread)
My Website/Blog with Projects and Write Ups on my Van
alexk243 is offline   Reply With Quote
Old 08-03-2016, 02:12 PM   #34
alexk243
KulAdventure
alexk243's Avatar
Default
Made my version of the fix based on jmoller's idea. Working great so far and wasn't terrible to make. I like that you don't to do any permanent changes to the regulator or track.
The Following User Says Thank You to alexk243 For This Useful Post:
Old 08-03-2016, 02:13 PM   #35
alexk243
KulAdventure
alexk243's Avatar
Default
Old 02-28-2017, 08:24 PM   #36
digitalfx
Originally Posted by Lojack72 View Post
While my '02 has had the shower door roller on the driver's side for a few years, thought I'd share this here:
http://www.thingiverse.com/thing:683339
I'm getting ready to drop the hammer on a $350 Printrbot 3D printer, love that someone has already created the CAD file for this part.
Well this thread just saved me, my window dropped and I discovered the broken guide clip. Called dealer and they dont sell just the plastic guide, they wanted $350 for the entire mechanism. Now I undertstand why they dont sell the plastic guide, as it cant be installed...what a poor design.
Thanks for all the excellent info in this thread and especially the link above I was able to 3D print the part. I then used a hybrid of all the techniques here. I drilled out the exiting post and replaced it with a 1/4 x 1 carriage bolt, a washer and nut...O and some locktite. I then used a dremmel to shave off the excess, added some grease and its now like new.
Thanks everyone for sharing.
Here is the results:
https://youtu.be/QNMZ6-q4Z6M
digitalfx is offline   Reply With Quote
The Following 3 Users Say Thank You to digitalfx For This Useful Post:
cacaw (06-11-2019), Mindy (07-13-2017), PATECO (02-13-2018)
Old 04-27-2017, 02:25 PM   #37
caseylentz
caseylentz's Avatar
When you printed this how did you get it on ?
caseylentz is offline   Reply With Quote
Old 05-19-2017, 09:43 PM   #38
Jodean
Jodean's Avatar
I just put a 1/4 20 bolt in there with proper washers the size of the channel, and a nylon lock nut
had parts in the bin
cost might be $1 if you go to ace hardware
Jodean is offline   Reply With Quote
The Following User Says Thank You to Jodean For This Useful Post:
SondraRose (10-16-2017)
Old 06-24-2017, 10:59 PM   #39
wdbarn
Yes,LAM_PARK..was the Dormon74442 solution a success and how did you secure the guide?Thanks
wdbarn is offline   Reply With Quote
Old 06-24-2017, 11:19 PM   #40
wdbarn
ZEB,Thanks, the photos were helpful,hope it's holding up.
