Old 07-21-2015, 04:53 PM   #11
fog cutter
Default Re: FAQ: Batteries
lacking extensive electrical skills and even at this juncture a clear need for the amount of technology i want to be burdened, i'm leaning towards a "plug 'n' play" system. is there a general consensus, whether for technology, endurance, or simply good customer support (located in the US), for either of these power blocks?
#1. Goal Zero 400
#2. Blue Sea
#3. ArkPak
i would prefer future additions be like manufactures for consistency. tried a search but came up dry.
thanks
fog cutter is offline   Reply With Quote
Old 07-21-2015, 08:23 PM   #12
icarus
The only thing I can say is BlueSea, in general makes very good products. Can't Opine on the others.
Icarus
Old 06-28-2017, 03:51 AM   #13
NavionIQ
The group 49, H-8 replacement batteries have changed their size in 2016 and I cannot find a replacement battery for my sprinter RV that will fit in to foot well! It is a really tight fit and previous attempts have resulted in burning a hole in the floorboard. Everything is 7 1/2 " tall and 7 1/4 is my max. Any thoughts?
NavionIQ is offline   Reply With Quote
Old 06-29-2017, 12:57 AM   #14
Daystar
Could you file 1/4" off the terminals? Also, some battery manufacturers give the option of different style terminals. Some may be shorter. Or, you could build another battery cover that gives you more clearance.
Daystar is offline   Reply With Quote
The Following User Says Thank You to Daystar For This Useful Post:
Aqua Puttana (06-29-2017)
Old 06-29-2017, 02:58 PM   #15
Along similar modification thoughts...
Use a large socket or pipe nipple as a die with a ball pein hammer to "dimple" the area above the terminals. I would then line the dimpled area with some tough plastic sheet for insulation.
Added: Cut out the areas above the terminals and use some clear epoxy with fiberglass cloth to rebuild the cover high enough. That would make some good tough electrical insulation. (I wouldn't use JB Weld. I believe it contains enough metal that it could be conductive.)
Old 08-10-2017, 04:04 AM   #16
Anthony 340B
Well I'm having trouble finding the answer to using the vehicles stock alternator or buying and higher output secondary alternator to produce a voltage and frequency that is compatable with charging a lithium battery. Someone or everyone tell me how bad of an idea this is. Just buy some decent amp/hr agm deep cycle batteries for under the hood, use the stock alternator (for now) run a cheaper (non UL) inverter and an actual Li battery off that. That way when I'm driving it's charging and when I'm it's off. Perfect profile charge. Say the charger was a 30-45a charger. Can an agm transfer that much amperage? This way in can trash my under the hood agm ($200-$300) and throw them away in 18 months. Please geek out on me. I'd rather not ruin a $3k Li.
Anthony 340B is offline   Reply With Quote
Old 08-13-2017, 04:38 AM   #17
Eka
Eka's Avatar
Well, not me geeking out, but read... https://marinehowto.com/lifepo4-batteries-on-boats/
Eka is offline   Reply With Quote
The Following 2 Users Say Thank You to Eka For This Useful Post:
4wheeldog (01-26-2018), Boxster1971 (08-16-2017)
Old 08-13-2017, 04:20 PM   #18
Nightpanda
2016 4x4 144 premie
Nightpanda's Avatar
This is an excellent write up. Thanks for posting
Scott
Nightpanda is offline   Reply With Quote
Old 08-16-2017, 03:08 AM   #19
Boxster1971
2012 Sprinter 3500 Ext
Boxster1971's Avatar
Good stuff! I hadn't been to the Compass Marine site in a while. Nice to see he has reorganized it nicely.
-- Mike
Old 01-26-2018, 04:50 PM   #20
4wheeldog
Wow! That convinced me to stick to AGM.
