Old 01-17-2020, 06:21 AM   #1
ddunaway
Default repair broken Espar connector wire
So I was adding a remote temperature sensor to my Espar D2. That went fine. In the process of this I broke a wire off a connector leading to my EasyStart Select. the heater is not working now.
Off course it is a very weird connector. I was able to push out the white locking plug. However, I cannot figure out how to get the pin out. It seems like a very particular pin too. Not sure if I can find another one.
Any suggestions on how to remove and repair the pin? I suppose if I can get the pin out I can try and re-attach a wire to it...tricky. Alternatively, I suppose I could cut off the whole connector and find a new one to attach the wires.
2015 High Roof 144WB Crew 4x4
ddunaway is offline   Reply With Quote
Old 01-17-2020, 08:18 AM   #2
sparkplug
Default Re: repair broken Espar connector wire
I did exactly the same thing.
Couldn't find a similar connector so just noted the wire positions, disconnected the battery and snipped off the original connector and replaced it with a generic one from Amazon (or maybe eBay)
It's worked absolutely fine for about a year now.
MWB 2008 Mercedes Sprinter 311 CDi (UK RHD) in the faster DHL Yellow colour
sparkplug is offline   Reply With Quote
The Following User Says Thank You to sparkplug For This Useful Post:
ddunaway (01-18-2020)
Old 01-17-2020, 12:52 PM   #3
JFloFoto
Here's what I used:
kweiny Auto Terminals Removal Key Tool Set Car Electrical Wiring Crimp Connector Extractor Puller Release Pin Kit (18 Pieces) https://www.amazon.com/dp/B07K1PZVW6..._f3AiEbV5VEJEN
(25 Pair) Molex Male & Female... https://www.amazon.com/dp/B072KTD2ZJ...p_mob_ap_share
Sent from my Pixel 3 using Tapatalk
The Following 2 Users Say Thank You to JFloFoto For This Useful Post:
ddunaway (01-18-2020), Midwestdrifter (01-18-2020)
Old 01-17-2020, 01:43 PM   #4
In addition to the locking insert, there are 1 or 2 locking tabs on the pin itself. I have had luck with fine tweezers or a jewelers screwdriver. The pin release tools are also a good option.
You could also just bypass the espar connector and use some spade terminals instead. Not elegant, but it will work.
Old 01-18-2020, 01:46 AM   #5
ddunaway
I dragged an expert in from work. Got the pin removed. We even happened to have more of the exact pin in the lab. We even have a super pro tool for crimping. Hopefully, I should be able to fix it now.....as long as I did not mangle the plastic part too much. Thx for input all.
Old 01-18-2020, 05:49 AM   #6
ddunaway
The heat is on!
The Following User Says Thank You to ddunaway For This Useful Post:
HarryN (01-18-2020)
