Old 01-17-2020, 04:42 PM   #31
HarryN
Default Re: I overcharged my batteries
I wonder if the charger is working correctly. That is a lot of over charge.
Old 01-17-2020, 07:47 PM   #32
john61ct
I would scrap the batts in any case, not as if lead is safe once its SoH is that compromised.
Start out with a better quality set*
Then closely test & monitor the charger to see if it is behaving properly.
That Bogart's a great tool, are you also controlling solar with it?
*tbc
Old 01-18-2020, 12:36 AM   #33
rollerbearing
Yeh- they get ornery if they lose their Sense of Humor.
Old 01-18-2020, 03:29 AM   #34
billintomahawk
'02 2.7 T!N Freightliner
*tbc
Could you explain.
bill in tomahawk
billintomahawk
2002 T1N Freightliner
OM 612 2.7L
Transporter 1 Neu 154HP
2500 140"WB, low top
Tank, the repurposed van
Old 01-18-2020, 03:37 AM   #35
john61ct
SoH = State of Health, % residual capacity from new
EoL should be 75-80%, no lower than 70%.
These are long past that, weren't great shakes to start.
Lead batts can explode.
Anything else?
The Following User Says Thank You to john61ct For This Useful Post:
billintomahawk (01-18-2020)
Old 01-18-2020, 03:32 PM   #36
SkyGypsy
*tbc
I am also controlling solar with it.
I thought the Fullrivers were a good battery. Are they really that bad?
New batteries were not exactly in the budget right now :/ Any recommendations on something decent that won't break the bank?
2005 158 high roof 200k or so
SkyGypsy is offline   Reply With Quote
Old 01-18-2020, 03:35 PM   #37
Gc2 flooded, Duracell brand.
Old 01-18-2020, 03:42 PM   #38
john61ct
Yes, the best battery value by far is Duracell (actually Deka/East Penn) FLA deep cycle golf cart batteries, 2x6V, around $200 per 200+AH @12V pair from BatteriesPlus or Sam's Club. Deka labeled same batts also sold at Lowes.
Even if everything keeps working well (dream on) IRL you need to plan on replacing a deep cycling bank every few years if used frequently.
Like tires and brake pads, batteries are a consumable.
A really high-end setup costing thousands, might get 8-10 years but that's rare, usually means pushing into the danger zone, past EoL 70% SoH.
Old 01-18-2020, 03:58 PM   #39
billintomahawk
Anything else?
The explosion is a hydrogen explosion due to improper venting ie. H2 gas accumulates?
Does the battery explode itself or the hydrogen around it? Or both?
H2SO4 degrades? Leaves the Sulphate radical(SO4) on the lead plates and frees the H2 gas??
H2 is lighter than air so wants to vent up and out.
This is very interesting.
http://www.theaic.org/pub_thechemist...Article-4.html
I really like John61's idea for consideration of a house battery as a consumable. A vehicle battery less so due to it's location.
My FLA deep cycle living under the passengers seat needs that consideration.
bill
billintomahawk
OM 612 2.7L
Old 01-18-2020, 04:25 PM   #40
john61ct
There are many causes and failure modes, "explosion" is just the extreme end of "rapid decomposition with high energy release".
More relevant maybe to just say, assuming the battery starts off as high quality, and the infrastructure is sound
unexpected failure is a symptom of improper care
not testing / monitoring / tracking performance properly
and not proactively replacing the batteries early enough.
By the time symptoms of EoL are gross enough, you've passed the point of predictability.
In a well managed setup, there should be no surprises.
Just waiting to replace after complete failure is asking for trouble.
