Old 01-15-2020, 01:21 PM   #21
john61ct
Default Re: Renogy Gel Battery
Originally Posted by EvanS View Post
You could also get an isotemp water heater and hook it up like Hein and I have. Free hot water.
So confused.
Do they make something for off grid use? What is the energy source?
I thought they only make units fed off AC power, so you'd need to run the genset to take showers.
john61ct is online now   Reply With Quote
Old 01-15-2020, 01:22 PM   #22
EvanS
Originally Posted by john61ct View Post
So confused.
You use engine coolant. When you drive it heats up the water. Look for heins write up.
EvanS is offline   Reply With Quote
Old 01-15-2020, 02:35 PM   #23
john61ct
So you just mean not a heater, just the tank / calorifier / heat exchanger part of it.
Not much use for those camping days and weeks off grid without driving.
Old 01-15-2020, 03:23 PM   #24
EvanS
Do you have a lot of experience doing that? We live in the van so max time spent not driving is a weekend or so. Water stays hot for 24 hours in cold climates, longer in moderate.
Also, isotemp has 120 volt option to heat it too.
I can't tell you what the best option is for your case all I can do is advise what others have done.
If you have to have hot water there is isotemp, your Bosch water heater, Rixen system, solar heated PVC pipe on roof, propane or electrically powered tankless hot water heaters. Go research them and let us know what fits your needs. We can advise from there.
Old 01-15-2020, 03:57 PM   #25
Using a diesel fired coolant heater to heat water is not unusual.
Running electric heaters off solar/battery can be done, but the quantity of water, and the frequency of use will be significantly limited.
Old 01-18-2020, 09:21 PM   #26
stag7882008
I also have the 100 AH Renogy Gel Battery for my 2003 Sprinter under passenger seat install. First one went bad within 4 months and they replaced it. I would normally charge it with a smart battery charger but I was using the AGM 12v setting. Found out later I was supposed to use the normal 12v charge setting. It also charges by alternator when driving. I hope this new one I installed will last longer.
stag7882008 is offline   Reply With Quote
Old 01-18-2020, 11:30 PM   #27
john61ct
Read my #3 post, slowly in the middle
The Following 2 Users Say Thank You to john61ct For This Useful Post:
stag7882008 (01-19-2020), svskyus (01-20-2020)
Old 01-19-2020, 02:03 PM   #28
stag7882008
I don't know if I ruined the battery by alternator charging, charging with the AGM setting or a combination of both. The battery itself coulda had a bad cell in at at time of manufacture.
Old 01-19-2020, 02:13 PM   #29
john61ct
Yes even top quality GEL needs precision charging to get good longevity, very sensitive chemistry.
For robust withstanding of normal abuse, can't beat those FLA GCs above
Old 01-19-2020, 02:43 PM   #30
Typical AGM profiles are too high a voltage for GEL batteries. Gels can also be damaged by high C rate charging, but thats probably not an issue unless you have a pretty big charger. Typical alternator voltages are below 14.2V, and won't be an issue.
