Old 01-14-2020, 04:11 PM   #21
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Default Re: Auxiliary fuel line in a 2006?
Originally Posted by adam7118 View Post
I just find it strange that I have the button on the dash for the factory auxiliary heater. Lights up when you push it too.
What does the button look like? I thought the two switch options for the factory fit eSpar where the central horizontal bar of the round heater control OR the 7 day timer.
Could the switch you are referring to be something like the rear heater control?
I wish there was some way to tap in without dropping the tank.
Have you looked at the front of the tank for a very small diameter nylon or rubber hose heading forwards. If it was there from the factory it may have a small electric dosing pump mounted to the chassis rail.
Originally Posted by Mickyfin View Post
My H12, aka D5 Hydronic is mounted near the exhaust of the unit under the drivers position floor.
Micky,
Your 2012 is an NCV3 and has the eSpar heater in a different location to that on a T1N.
Keith.
36,000 miles from New
Old 01-14-2020, 04:39 PM   #22
adam7118
https://imgur.com/a/LsxPOuW
This is the button Im referring to
adam7118 is offline   Reply With Quote
Old 01-14-2020, 05:08 PM   #23
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
That looks like heated rear screen!
Yep, here's one for a Vito... https://www.ebay.co.uk/p/MERCEDES-VI...307/1713881303
Old 01-14-2020, 05:12 PM   #24
adam7118
ah ok that makes sense. Thanks!
Old 01-14-2020, 11:52 PM   #25
adam7118
Micky,
Keith.
Keith,
I will check this in the nm to see if that hose is there.
Old 01-16-2020, 11:45 PM   #26
adam7118
Micky,
Keith.
I did find two lines comping from the tank. Id guess one is a fuel line and one is a return. Im not too sure if I can tap into these. They are not rubber. Here is a photo
https://imgur.com/if99aKZ
Old 01-16-2020, 11:59 PM   #27
adam7118
My other thought was to drill directly into the diesel fill and slide the tube down and apply caulk. I don't believe this needs to be airtight.
Old 01-17-2020, 12:03 AM   #28
Zundfolge
1-2-4-5-3
Zundfolge's Avatar
A few things:
1-Those steel lines are your engine fuel supply and return lines. UNDER NO CIRCUMSTANCES do you tap into those!
2-Your Vin did not return the heater option correct? If you don't have the factory espar you have exactly one option: run the fuel to almost none, then drop the tank and install a standpipe into the fuel pickup/pump cartridge. NOT DIRECTLY INTO THE FUEL TANK! I believe this has all been mentioned?
Yeah no
So the only way to tap in is to drop the tank?
Yeah yeah
'06 Sprinter ~270K
'83 Mercedes OM617 manual
Old 01-17-2020, 12:15 AM   #29
adam7118
Originally Posted by Zundfolge View Post
A few things:
Yeah no
Yeah yeah
I appreciate it big time. Thought I could find a way around it. Standpipe it is
Old 01-17-2020, 12:19 AM   #30
Zundfolge
1-2-4-5-3
Zundfolge's Avatar
I understand the urge to get around dropping the tank but it truly is not as bad as it sounds. If you get hung up we'll help you. Gotta pay the price for heat, but it's worth it many times over. You know what they say, installing a heater warms you twice...
'06 Sprinter ~270K
