Old 01-12-2020, 05:18 PM   #11
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Default Re: Auxiliary fuel line in a 2006?
Originally Posted by adam7118 View Post
https://imgur.com/a/sNv1YJ3
Here is a photo of what I have. Did the previous owner remove the heater?
Adam,
Download your Data Card from https://www.lastvin.com/ and look for:
HZ9 Heater booster
KL1 Sender uni (fuel) for auxiliary heater
The first is the eSpar heater and associated wiring, the second is the fuel line tap for the heater. You may have KL1 without HZ9.
Keith.
36,000 miles from New
Old 01-12-2020, 09:03 PM   #12
chrisinflight
Tap in a couple of inches below the existing espar fuel pump using 6mm 90 degree 3 way brass tee. I've just installed mine like this.
chrisinflight is offline   Reply With Quote
Old 01-13-2020, 03:54 PM   #13
adam7118
Originally Posted by Cheyenne View Post
Adam,
HZ9 Heater booster
Keith.
Cheyenne,
I downloaded the Data Card and did to find either one of those numbers. is this normal?
This is the full card:
Code Description
172 FUEL PREHEATER
494 VERSION FOR USA
580 AIR CONDITIONER
910 No code designation available
AC6 AXLE RATIO I = 3.727
BB0 BRAKING SYSTEM WITH ABS/ASR OR ABS/ETS
C42 STABILIZER,REAR AXLE UNDER THE FRAME
D03 HIGH ROOF
D50 PARTITION PANEL FULL-WIDTH
E88 CIGAR LIGHTER
EE8 12V BATTERY 100 AH
EF7 RADIO SOUND 30 W. SINGLE CD PLAYER AND 2 SPEAKERS
EK1 TERMINAL STRIP FOR ELECTRICAL CONNECTION
ES5 INSTRUMENT PANEL CHARGING PACKAGE
F61 INSIDE REARVIEW MIRROR
F68 HEATED AND ELECTRICALLY ADJUSTABLE OUTSIDE MIRROR
F76 GRAB HANDLE CO-DRIVER SIDE
FG7 STORAGE BOX AT CO-DRIVER SEAT
FG8 CUP HOLDER(S), FRONT
FS4 LEFT AND RIGHT AUXILIARY MIRRORS NOT HEATED
FY6 CENTRAL LOCKING WITH RADIO REMOTE CONTROL NAFTA
FZ9 TWO ADDITIONAL MASTERS
G40 AUTOMATIC TRANSMISSION
H01 HEAT INSULATION CARGO AREA/PASSENGER COMPARTMENT
H04 HEAT INSULATION DRIVER CAB
H21 ALL-RND.HEAT ABSORB.GL.W.BAND FLTR ON FR.WINDOW
H22 HEATED REAR WINDOW
HH9 SEMI-AUTOMATICALLY CONTROLLED TEMPMATIC A/C
IL2 EXPORT CODE
J11 SPEEDOMETER MPH AND KM/H
J61 HYDRAULIC BRAKE TEST CONNECTION
J64 MAINTENANCE INDICATOR FOR DRY AIR FILTER
J65 OUTSIDE TEMPERATURE INDICATOR
JA1 INDICATOR LAMP FOR WIPER FLUID LEVEL
JW0 BACKUP WARNING SYSTEM
JW6 ASSYST SERVICE INTERVAL INDICATOR
K60 TAIL PIPE LEADING STRAIGHT TO THE REAR
KB0 MAIN TANK 100 LITER
KL5 FUEL FILTER WITH WATER SEPARATOR
L16 HALOGEN FOG LAMPS
L62 READING LAMP
L65 COURT. LIGHTS F. TRUNK/PASS. COMP. W. DOOR CONT.
L94 ELIMINATION OF PARKING LIGHT
LB5 CENTER HIGH-MOUNTED BRAKE LAMP
M35 14 V/115 A ALTERNATOR
M96 FUEL PREHEATER
MC0 ENGINE OM 647 DE 27 LA 115 KW (156 HP) 3800/RPM
MF2 ENGINE REGISTERED FOR "CARB STATES"
P47 MUDFLAP FRONT
P48 REAR MUD FLAPS
R65 SPARE WHEEL CARRIER UNDER FRAME END
R87 SPARE WHEEL
RF1 TIRE MANUFACTURER CONTINENTAL (10)
RG0 195/70 R15 TIRES
RM0 ALL-SEASON TIRE
RM9 TIRE MAKE SPECIAL REQUEST
RS2 DROP CENTER RIMS 5.5J X 15
S22 DRIVER'S SEAT ARMREST
S25 CO-DRIVER'S SEAT ARMREST
SA5 AIRBAG DRIVER SIDE
SA6 CO-DRIVER'S AIR BAG
SB1 DRIVER SEAT, COMFORT
SB2 PASSENGER SEAT, COMFORT
SS4 SANTOS FABRIC
T11 DOOR REINFORCEMENT IN AREA OF LOCK
T16 SLIDING DOOR RIGHT
T85 ENTRANCE GRAB AT CORNER PILLAR AT LEFT REAR
T86 ENTRANCE GRAB AT CORNER PILLAR AT RIGHT REAR
V25 CARGO AREA SINGLE CLADDING UP TO BELT RAIL
V43 WOOD FLOOR
V50 ELECTRIC WINDOW LIFTER, 2-WAY
W17 RIGHT FRONT WINDOW,FIXED IN SIDE WALL/SLIDING DOOR
W51 REAR-END DOOR, DOUBLE-WING WITH WINDOW
W54 REAR-END DOORS, DOUBLE-WING, OPENING TO SIDE WALL
W73 REAR-END DOOR STEP
WM0 SPRINTER FACELIFT 2003
X42 PLATES / PRINTED MATERIALS ENGLISH
X92 COMPANY LOGO (MERCEDES-BENZ) DELETED
XC8 VIN VISIBLE FROM OUTSIDE
XY6 MODEL YEAR 6
Y11 BRACKETS USED FOR WARNING TRIANGLE
Y17 PRE-FITTINGS FOR FIRE EXTINGUISHER
Y43 HYDRAULIC JACK
Z41 APPROVAL AS TRUCK
Z75 BODYSHELL REINFORCEMENT
Z81 TIE-DOWN EYES
Z90 UNDERBODY CONSERVATION DELETED
ZB6 PRODUCTION PARTS KIT
ZU8 USA COUNTRY VERSION
ZX8 DODGE EXECUTION
adam7118 is offline   Reply With Quote
Old 01-13-2020, 05:06 PM   #14
sparkplug
Yes, that is perfectly normal.
It just means that your van was not fitted with a heater or with the aux fuel pipe at the time of manufacture.
This doesn't stop you from being able to do what you want - it just means that instead of being able to use existing fuel lines you are going to have to make some yourself.
Mine also didn't have any so I fitted a standpipe into the tank and it's worked perfectly.
I've been trying to find the thread / pictures that someone had posted showing the best positioning for the standpipe. They carefully drilled a hole into the fuel pump assembly cap.
I can't find it now. Perhaps a bit of searching or perhaps someone else can find it and help you.
I hadn't really considered it very carefully and simply drilled straight into the tank itself. While this has worked perfectly it was pointed out to me that it creates a weak point in the tank and over time it could lead to cracking.
MWB 2008 Mercedes Sprinter 311 CDi (UK RHD) in the faster DHL Yellow colour
sparkplug is offline   Reply With Quote
Old 01-13-2020, 06:25 PM   #15
brokengranite
Hold my beer, watch this
brokengranite's Avatar
Tons of threads on this subject, not alot of information on actually doing it. Many people realize that they have the aux tap and then the thread dies off.
Dennis has repeatedly commented to use Webasto part no. 5000553A and to not drill a hole in the actual fuel tank which might lead to cracking in the future, but to drill into the fuel pump lid and add the standpipe.
This is the thread that I found that had the most amount of information....
https://sprinter-source.com/forum/sh...ad.php?t=62096
A friend of mine also just installed an aux fuel tap and used this part...
https://www.ebay.com/itm/Webasto-fue...cAAOSwZ2FcQi1P
Which looks like its not an original Webasto product, but aftermarket, YMMV.
Ill be dropping my fuel tank this weekend and installing a home made standpipe.
2004 118" Low Roof
2010 144" High Roof
brokengranite is offline   Reply With Quote
The Following User Says Thank You to brokengranite For This Useful Post:
Mickyfin (01-14-2020)
Old 01-13-2020, 07:17 PM   #16
adam7118
So the only way to tap in is to drop the tank?
Old 01-13-2020, 07:44 PM   #17
sparkplug
Yes - if you don't have the aux fuel line already integrated in the cartridge then you need to drop the tank to be able to get access to drill it and fit the standpipe.
I've searched and searched and I even found a post from someone else saying that they'd seen a pic of how to drill the cartridge somewhere on these forums - but can I find the actual pic?
I'm sure I've seen it because I remember thinking that it made so much more sense than what I did and that if I was to do it again then I'd definitely be drilling the cartridge.
Maybe this thread can finally become the 'how to' one with pics!
Dropping the tank is not difficult but I would suggest that getting as much fuel out of it before you tackle the job would be very strongly recommended. If I was doing it again I would probably put a trolley jack under the tank, unbolt the securing straps and then gently lower the tank until you have good access to the fuel disconnects. Once the tank is completely uncoupled you should be able to just slide it out on the jack.
I also found the cartridge really difficult to remove initially. I applied some silicon spray to lubricate the thread and then pushed down on it as I turned it. I have no idea if it was the lubrication or the pushing down which made the difference but it was like when you struggle with the lid on a jar and then someone else just pops it off like it hadn't been put on tight enough....
Old 01-13-2020, 08:37 PM   #18
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Yes I agree with all the others, perfectly normal not to have either. It all depends on which state it was originally ordered for as 'hot' states did not seem to see the need for additional heating.
And again I agree with the others, the ONLY way to install a fuel pick up for your heater is to drop the tank and fit a standpipe through the top flange of the fuel sender unit. NEVER drill through the carcass of the blow moulded tank as you will almost certainly create a stress raiser and the risk of future problems.
One final point to make is that I believe the KL1 sender is optimised to read the fuel tank level from the float and hence will include any fuel used by the diesel heater.
Without the KL1 your T1N may only move the gauge based on the calculated fuel used by the engine and hence may not respond correctly to the amount of fuel used by the heater and hence could show you have more fuel remaining than you actually have. Others may be able to confirm or correct my assumptions.
Keith.
Old 01-14-2020, 12:54 PM   #19
adam7118
Keith.
I just find it strange that I have the button on the dash for the factory auxiliary heater. Lights up when you push it too. Stranger things have happened. Kind of a disappointment. I wish there was some way to tap in without dropping the tank.
Old 01-14-2020, 01:06 PM   #20
Mickyfin
Mickyfin's Avatar
My H12, aka D5 Hydronic is mounted near the exhaust of the unit under the drivers position floor.
My van is a 170" WB High Top 2012 Volkswagen Crafter 2.0TDi, which was built in the very same German factory as the Mercedes Sprinter of the same year.
