Old 01-12-2020, 01:14 AM   #1
adam7118
Default Auxiliary fuel line in a 2006?
Hi guys,
Im in the process of doing the diesel heater install on my 2006 3500. Does anyone know if there is an auxiliary fuel line on this van? If not, what is the best way to tap in?
adam7118 is offline   Reply With Quote
Old 01-12-2020, 01:18 AM   #2
markxengineering
Default Re: Auxiliary fuel line in a 2006?
Do you have the factory hydronic option? If so, many people T off that line.
2006 Hi Top Window Van 140"
The Following User Says Thank You to markxengineering For This Useful Post:
Mickyfin (01-14-2020)
Old 01-12-2020, 01:25 AM   #3
Zundfolge
1-2-4-5-3
Zundfolge's Avatar
...before the factory espar fuel pump. (Just so the info's here)
Do you have a little button on the right side of your dashboard with 3 wavy horizontal lines?
'06 Sprinter ~270K
'83 Mercedes OM617 manual
Old 01-12-2020, 01:38 AM   #4
adam7118
Yes I do! is that good? I have no idea what that is
Old 01-12-2020, 02:22 AM   #5
ranchworld
'06 158 2500 Passenger
Up front in the engine compartment under/behind the driver side headlamp is a factory Espar hydronic heater. This is awesome for a couple reasons. It was desinged to help warm the engine up faster. Even in the mild Seattle climate where I live I regularly use it to get the temp up on short drives. Start the van, push the wavy line (bacon) button and a cloud of smoke should come out from under the driver door area where the exhaust is. You may not get a smoke cloud the first time you fire it up, I sure did. The original owner never used the feature so it had sat for 8 years when I got the van... Anyway once you have used it a few times it will not smoke, it will warm up your engine ASAP.
As far as your heater install goes, if you get under the van and look forward of the fuel tank and follow lines you will see the main fuel line going to the engine and a smaller fuel line going to the factory Espar. Use ONLY the smaller line going to the factory espar to "t" into. Lots of treads on that here. Just google "espar fuel line t T1N sprinter".
This is how I did mine; https://sprinter-source.com/forum/sh...4&postcount=48
See page 131 of this owners manual for factory Espar operation.
002 Owners manual.pdf
The Following User Says Thank You to ranchworld For This Useful Post:
Old 01-12-2020, 02:29 AM   #6
adam7118
THIS IS AWESOME!!!! Thank you!
Old 01-12-2020, 02:54 AM   #7
marklg
Yep, I had my Sprinter for two years before I realized I had an Espar. Was looking underneath and wondered what the muffler was. It even gets cold in the mornings here in AZ. I couldn't wait till this winter to try it. It works great.
Regards,
Mark
Old 01-12-2020, 04:28 PM   #8
adam7118
Attachment 123675
What year is your van? I cannot find that existing pump on mine for some reason?
Old 01-12-2020, 04:30 PM   #9
adam7118
In fact I'm not being a factory heater behind the headlight either
Old 01-12-2020, 04:42 PM   #10
adam7118
https://imgur.com/a/sNv1YJ3
Here is a photo of what I have. Did the previous owner remove the heater?
