Go Back   Sprinter-Forum > Classifieds > Want to Buy (Sprinter items)
Want to Buy (Sprinter items) Post Sprinter vans or parts that you Want To Buy
Old 01-06-2020, 09:41 AM   #1
Cwhite87
Default Booster heat switch
Looking for a booster heater switch for a 03-06 sprinter scoured the interwebs and cant seem to find one even in ebay..
Thanks in advance
Clayton
2005, T1N, 2500 SHC, 158
Cwhite87 is online now   Reply With Quote
Old 01-09-2020, 02:46 AM   #2
99sport
Default Re: Booster heat switch
What does the "booster heater switch" look like? The owner's manual references these two parts as heater switches
https://www.moparpartsgiant.com/part...5103853aa.html
https://www.moparpartsgiant.com/part...5103644aa.html (rightmost dial contains the "Heater booster switch")
99sport is offline   Reply With Quote
Old 01-09-2020, 05:44 AM   #3
The "boost" heat switch is the "bow tie" in the middle of the rightmost group on the AC panel.
The Auxiliary heater switch is one of the typical switches (unless you're speaking of the 7-day timer)
((and at the moment i'm not finding the Aux Heat switch or the 7-day timer in my parts catalog... i *know* the 7-day timer is in there somewhere))
--dick (parts catalogs at http://www.diysprinter.co.uk/reference/ )
Old 01-12-2020, 06:04 AM   #4
Cwhite87
My apologies I was thinking it was a small toggle above the 7 day timer. Like the ASR
Old 01-12-2020, 06:01 PM   #5
If you have the 7-day timer, there is no dash switch for the Aux Heater ... just punch the red button on the timer.
That turns it on for 2 hours.
At the end of the 2 hours you can punch the button again.
For people without the 7-day timer, there is a toggle on the dash (for which i can't find the part number)
Here's what it looks like:
And the schematic shows it to be a simple single-pole, single-throw non-momentary switch, but with the tally LED between the switched side of the circuit and ground:
I don't know if the "rear blower switch" (https://www.moparpartsgiant.com/part...5103853aa.html) suggested earlier has the tally light.
The manual shows that "underscore" under the wavy lines, which hints that the blower switch may differ.
Cwhite87 (01-18-2020)
