Old 01-17-2020, 08:28 PM   #11
Todd.Niles
Default Re: Advice ESP code, no cruise control warning
2008 Dodge Sprinter 2500, 139,000 miles
ESP light now seems to be fixed. The plunger switch, controlled by the brake pedal arm, is adjustable. Get a flashlight, look up above the brake pedal, and you will see a plunger switch. It's a white button on a black plastic housing. The white button is adjustable. Without removing the switch, press down on the brake and reach up with your fingernails and pull on the white button. It will pull out about 1/4 inch. You will hear clicks as you pull the white button out. Then release the brake and let the white button self adjust to the proper height.
Since I've done this I can't make the ESP light turn on. All seems fixed. No cost and it's very simple.
Todd from Kenosha, Wisconsin
Todd.Niles is offline   Reply With Quote
