Old 03-18-2016, 12:53 AM   #1
Wasaabi
Sprinter Westfalia #133
Wasaabi's Avatar
Default Help... Destroyed our sink
A concentrated tiny bottle of CitraSolv (citrus based cleaner) spilled on our bathroom sink. By the time we got to it, it was too late. Yellow colored surface drips, deep etching, and plastic that is so soft you can dent it with a nail. I tried to get the stuff off but it is now part of the sink plastic. Don't know if it will do further damage.
We are on the road for another month. What to do? I need to first of all prevent further damage, and then figure out if there is any way to repair this. It's ugly! :(
Thanks for any ideas.
Wasaabi is offline   Reply With Quote
Old 03-18-2016, 02:20 AM   #2
OldWest
T1N Westfalia
Default Re: Help... Destroyed our sink
Ideas at your own risk--need to check for chemical compatability.
1. Cat litter, baking soda, sawdust, other absorbent clean-up if any spilled citrus concentrate left (plug drain before dumping absorbent stuff in sink).
2. If citrus concentrate is water soluble, run tons of water all over sink to dilute any residue. Would empty graywater tank immediately and continuously as you don't need holes in your tank. If this stuff is really concentrated, may not want to dilute into graywater tank (could take off sink drain and jerry rig a drain to outside/bucket so don't get stuff into graywater tank).
CitraSolv website says not recommended for plastic, etc., as may dissolve/mar (but they have multiple products).
Short-term fix.
1. If sink turns out okay except for discoloration, maybe a whitening solution of vinegar and baking soda, or toothpaste might work (after there is no citrus stuff left).
2. If a hole pops up in sink, use a plastic weld epoxy glue on underside to keep sink together or an adhesive roof sealing tape on underside. Just make sure any adhesive is not sent down drain.
Old 03-18-2016, 02:29 AM   #3
OldWest
T1N Westfalia
I was either wearing sunscreen or bug spray when I accidentally brushed against the gray hard plastic trim near the sliding door. Tried everything to get rid of the stain/spot, but was left with a 3" square shiny spot. Months later, the stain/spot disappeared by itself (maybe evaporated or migrated further into plastic).
The bathroom sink is not that sturdy. I have small hairline cracks near the corner edges where the bolts are. Someday, might look around to see if a refinishing layer can be sprayed on (like the commercials for refinishing bathtubs). That might be a possibility--might pick a darker color than white (maybe 60's orange).
Believe Discus replaced his bathroom sink with a Corian countertop and stainless steel bowl sink. The Corian countertop has same dimensions as original sink so sliding door remains (so must have groove in the underside of the Corian countertop).
So this might be an opportunity for you to upgrade the bathroom sink.
Old 03-18-2016, 02:42 AM   #4
OldWest
T1N Westfalia
After all the cleanup, want to continue diluting/absorbing/leeching.
Plug up drain, fill sink with water, and let sit. Hopefully, will dilute. Any stuff on outside of sink basin, cover with wet towels/sawdust/etc. to absorb.
Later, could try some whitening chemicals (but caution re any residue mixing and any adverse reactions from new chemicals). Old standbys include vinegar and baking soda, hydrogen peroxide, or bleach (may be too caustic)--each a separate option--don't combine and create a toxic cloud.
Commercial chemicals might include SoftScrub, etc.
To be on safe side, lots and lots of ventilation.
Good luck and let us know what works and what doesn't. At least it doesn't sound like anything spilled on the walls or shower pan, just the sink.
Old 03-18-2016, 02:46 AM   #5
OldWest
T1N Westfalia
http://www.amazon.com/gp/aw/d/B00T82...ub+Spray+Paint
Old 03-18-2016, 02:52 AM   #6
OldWest
T1N Westfalia
http://www.surface-repair.com/refini...aerosol-spray/
Old 03-18-2016, 06:45 PM   #7
Wasaabi
Wasaabi's Avatar
Default
Thanks for all the great ideas. What I did so far after trying my best to remove what was there with water was get a bunch of different wet sandpaper pieces. I sanded by hand down from 220 to 1200 grit. I was able to remove some of the yellowing, but most of it remains because it has fused to the plastic and created it's own texture. At least I think I accomplished removing the substance enough that it won't be causing further damage.
Before painting, I'd like to try to restore the surface if possible. Theoretically I should be able to sand down the damage and then sand it to a shine. However, the thinness in some areas might make that impossible.
In some areas there are some pretty deep crater-like depressions in the plastic which is quite thin to begin with. It's clear that to improve things further requires a power tool. I am thinking about getting a headlight repair kit from 3M (which worked great on my headlights BTW) and using it with the drill when I get home.
Also, being in Austin at the moment, it turns out there is a Sportsmobile factory here. We're going to take a trip up there today and see if they can fabricate a replacement sink top that fits the cabinet and then potentially do the stainless steel sink idea, which I love.
Will keep you posted...
Old 03-18-2016, 09:59 PM   #8
OldWest
T1N Westfalia
Wow--that concentrated cleaner really was strong.
Another sink idea is to put the sink bowl on top of the countertop versus inside the countertop. That way, you'd get a higher sink and more storage in cabinet. Would need a different faucet.
Sink bowl could be stainless steel or a glass bowl (several glass artists attend the Westyfests).
As this is a wet bath, water spilling onto sink countertop and then floor wouldn't be a big deal but you could still add a lip to the edge of the countertop.
Old 03-19-2016, 05:38 AM   #9
Wasaabi
Wasaabi's Avatar
Default
The irony is that CitraSolv is supposed to be an "eco" cleaner. Hmmm...
So Sportmobile had nothing to offer. They said they are 14 months out on builds for van customers and can't take a technician away to deal with this.
As an aside, I always wanted to tour their facility. They are nice folks and probably the best in the business this side of the pond. That said, I toured several of their vans and was extremely disappointed in their designs compared to Westfalia. They were cramped, used unattractive materials (fake wood), poor use of space, cabinets in your face, no thought to crash safety, claustrophobic... basically somewhere I wouldn't want to spend any real time. There is simply no comparison to the Westy. It was a shocking difference and I came away telling my wife that we are keeping Westy on the road forever.
Meanwhile, the chemical damage has stabilized and we have dumped the tanks as a precaution. Next step is to try the headlight restorer stuff on the current sink. Need to locate a drill. Will get to it, either on our current trip of when we get home. Perhaps some sort of resin or epoxy first, to fill in deeper gouges?
Thanks for the continued ideas. I did replace the faucet just recently with the original model (found via eBay), so it would be nice to keep it. Also, it seems a round sink would be much smaller than the current shape, but this might actually be an advantage for soaking things or shaving and using less water.
Old 03-20-2016, 10:57 AM   #10
discus
GA Westy
The original sink is very thin. Mine was completely brittle and cracking near the sink drain so I decided to replace it rather than do a fiberglass recovery since even the fiberglass resin did not stick very well.
I decided to use a 8" round stainless steel bar sink on mine. The existing sink sits on a frame and the upper track is attached to that one so you don' t need to worry about the door. Once you have the sink removed, you can use that as a template.
I got the corian from solidsurface.com. They have many brands other than corian and if you go through the list, sometimes they will have small pieces on clearance for dirt cheap. You have to cut the new top about 1/2" bigger than the existing sink and use a router with ogee bit or half round to finish the edge.
You clamp the old sink upside on the countertop and use that as the guide for the router. Do shallow cuts to get a feel of it once you are ready, reposition your sink guide to the final place.
One of the benefits of the countertop is it seems to make the door track better. The entire cabinet is more rigid and now I have place to put down stuff on either side of the round sink.
discus is offline   Reply With Quote
The Following User Says Thank You to discus For This Useful Post:
OldWest (03-20-2016)
