Old 04-30-2017, 11:47 PM   #171
Default Re: Nag1 TECH ALERT
Originally Posted by fsneeringer View Post
- P2203 Speed sensor '3' is faulty (this is what I had before.)
- P2602 The voltage supply of the valves is faulty
- P1926 CAN communication is faulty
- 2225-1 Fault of control module A4 (ETC [EGS] control module) The voltage supply of the speed sensors is faulty
- 2224-1 Same as above
Thanks,
Frank
A problem with the regulated power supply voltage(s) could result in various codes, but they might all trace back to the voltage not being correct.
Are there any aftermarket electronics tagged on to the Sprinter electrics?
Sorry I can't offer more.
Old 05-01-2017, 02:35 AM   #172
Dougflas
DAD OWNER
It might be a good reason to call Silver Star transmissions in OK. They do answer questions and give advice.
2005 TIN Sprinter 2500
Located in Beverly Hills, Fl.
Old 05-16-2017, 10:26 PM   #173
Neil2
Neil
Neil2's Avatar
Originally Posted by kurt View Post
Good question:Upscale (highly recommended on many forums repeatedly) price for transmission service was 1/2 from Ron Tonkin quote,big mistake on my part """"very sorry""""
I can't tell if you mean Upscale was twice Tonkin's or vice versa.
[FONT="Comic Sans MS"]Neil
2007 2500 SH Passenger 144" Sprinter (Bessie)
Neil2 is offline   Reply With Quote
Old 05-18-2017, 09:00 PM   #174
fsneeringer
I don't know of any aftermarket electronics.
As of a few days ago, I have replaced the electrohydraulic unit, filter, and filled with new fluid and have had no problems at all since the change out - although I've only driven about 50-60 miles. The problem was manifesting itself quite quickly though. I will update if I experience symptoms again.
Thanks again to everyone for all of your help.
Frank
Frank
05' T1N 158" ~130k miles
Converting a cargo configuration to toy hauler/RV
fsneeringer is offline   Reply With Quote
Old 11-07-2017, 01:45 PM   #175
Yendormiller
I hope this isn't a dumb question but should I clean the transmission conductor plate, solenoids, sensors, etc. with a certain product or with brake parts cleaner/carb cleaner/mass air flow cleaner? And how do I go about cleaning? Thanks so much
Yendormiller is offline   Reply With Quote
Old 11-07-2017, 03:26 PM   #176
Other posts have indicated that some members have used brake cleaner and some have used carb cleaner. Personally I wouldn't choose/go to mass air flow cleaner, but maybe it would be fine. It must be ok for plastic and electrical parts.
And how do I go about cleaning? ...
I my opinion, that may be the dumb question. (No offense intended.)
Unless you have symptoms my recommendation would be to leave things alone. There are possible pitfalls to messing with the conductor plate and cleaning. Even Doktor A backed away from his periodic cleaning recommendation.
If you have no symptoms I would do a TC/pan drain, filter, and refill with proper transmission fluid.
CrispysonofA (11-24-2017), Dsalley (06-07-2018)
Old 11-08-2017, 05:02 AM   #177
abittenbinder
Doktor A (864-623-9110)
Yes! Save the cleaning of the speed sensors and electrical board for serious symptoms only.
Doktor A
The Following 2 Users Say Thank You to abittenbinder For This Useful Post:
CrispysonofA (11-24-2017), turbodave (11-11-2017)
Old 11-26-2017, 04:53 PM   #178
buckeye dualsporter
Help Doctor help! My 2003 sits a lot. I took it out for a warm up drive of about 200 miles. I had a slight rumble as I stopped. When I pulled out it did not downshift. I was 60 miles from, home and on limited access road. It came up to speed slowly as I did not want to screw anything up. It would not shift with the paddle. I got home. Turned off the motor. Restated and everything worked. Drove a little and did it again. Did the same drill, off and on, then was okay again. I bought used and have never had the transmission serviced. Could I expect that service is the issue?
buckeye dualsporter is offline   Reply With Quote
Old 11-27-2017, 03:34 AM   #179
abittenbinder
Have someone with a high end diagnostic tool communicate with the TCM. There will be a fault code(s) that was generated by your repeated recent transmission LHM.
If the code(s) involve issues related to low fluid levels, service the transmission and replace the harness socket connector which may be seeping fluid during your prolonged periods of unuse.
Doktor A
The Following User Says Thank You to abittenbinder For This Useful Post:
CrispysonofA (12-05-2017)
Old 01-09-2018, 02:28 PM   #180
rustdogbrown
What are considered "serious symptoms"? Maybe a better question is, what are the symptoms that this tech alert will address?
Would a compromised speed sensor cause a hard shift? Hard downshift? Hard upshift? Specific to one gear?
Is there a shop in Seattle that is familiar with this procedure?
rustdogbrown is offline   Reply With Quote
