Old 01-14-2020, 09:54 AM   #11
Mickyfin
Mickyfin's Avatar
Default Re: 2011 Dome Light Issue
Ive been struggling with the very same issue as the op.
My van is a 170" WB High Top 2012 Volkswagen Crafter 2.0TDi, which was built in the very same German factory as the Mercedes Sprinter of the same year.
Mickyfin is offline   Reply With Quote
Old 01-25-2020, 05:35 PM   #12
sparkplug
I've been having unrelated issues which made me go and learn a bit about my fuses and relays.
I came across this website
https://fuse-box.info/mercedes-benz/...uses-and-relay
While reading through it I couldn't help but wonder if any of the 'dome light' issues people have been having might simply be related to fuse 17 on fuse block F55/2
It might not help, but it's a quick check and an easy fix if it is just that....
MWB 2008 Mercedes Sprinter 311 CDi (UK RHD) in the faster DHL Yellow colour
sparkplug is offline   Reply With Quote
The Following User Says Thank You to sparkplug For This Useful Post:
Mickyfin (01-25-2020)
Old 01-25-2020, 05:37 PM   #13
Mickyfin
Mickyfin's Avatar
Thanks for that, I've made a note if that, and will check tomorrow and report back.
Sent from my Nokia 9 using Tapatalk
Old 01-26-2020, 03:22 AM   #14
Burkilimo
I had this problem in one of our sprinters - no dome light when opening the drivers side door. Noticed that if you close it - but not actually close it - if that makes any sense - and then push it open again - the light turns on. Never really bothered fixing it - as this “fix” seemed to work when the drivers needed it
Burkilimo is offline   Reply With Quote
The Following User Says Thank You to Burkilimo For This Useful Post:
Mickyfin (01-26-2020)
