Old 09-13-2018, 02:54 AM   #41
Jodean
Jodean's Avatar
Default Re: Air Recirculation system broken actuator parts - DIY fixes
mine just popped out again, still not broken just slipped out somehow again, i didnt fix it, i wired it closed, no need for fresh air on this thing!
If i realy need fresh air, ill open hood and pull wire off.
2004 Dodge Sprinter 2500 140"wb
Jodean is offline   Reply With Quote
Old 09-15-2018, 03:29 PM   #42
Aqua Puttana
Poly - Thread Finder
Aqua Puttana's Avatar
Originally Posted by Jodean View Post
??? the door is normally open.....pushing the button closes it
so said conversion door would normally be closed, as in key off, better for your rodent idea!
That may be correct.
I might have been thinking about when the actuator linkage assembly is broken which allows the diverter door to swing in the breeze finding some mid position. In that case there is definitely easier rodent access.
Old 07-17-2019, 02:03 PM   #43
SAM_PGA
I'm going to use the wedge or wire my recirc door shut as well. Can anyone please post a pic of how they wired the door shut? I'm sure its pretty simple just curious as to what works.
Thanks!
SAM_PGA is offline   Reply With Quote
Old 07-18-2019, 04:36 PM   #44
SAM_PGA
After turning on the engine and turning on air recir, I used a wire (from a wire hanger) and hooked one end around the pivot/door lever, ran the wire forwards and underneath the air box, wrapped around the air box counter clockwise back to the door lever (starting point), snipped and trim the length of the excess about 3" past the pivot, worked the tail end underneath the pivot and bent the excess wire back hooking the door pivot once again. The wire is pulling forward and upwards and after turning the air recirc off, the recirc door still has a good seal.
THEN I removed the cabin air filter and clean the inside (of what I could reach). Now with the top vents closed and the flow switch on dash only I can feel the air blowing all the way to the back of my concept sales van. The amount of air on high coming from the vents is ridiculously good!!! Fingers crossed it still works well during our heat wave in Tennessee.
Old 08-06-2019, 03:01 PM   #45
addy6
Originally Posted by bc339 View Post
Since I wrote this, the belcrank on mine broke. Dodge, MB or Valeo (that's who makes the air distribution system) do not offer the small bits and piece parts. By happenstance, I found a company that 3D printed a replacement belcrank for me. It's a perfect fit and has been installed for several months without any problems.
Working on it isn't hard, but it is time consuming because you are mostly working by feel due to the location of the parts.
The actuator is held in by two screws, a vacuum line and an electrical connector. Remove the fasteners first, then you will have better access to the actuator to remove the connector and vacuum line.
The belcrank is notched on the actuator end at a location that keeps it from becoming disengaged.
Here is how I installed replacement belcrank and actuator:
The actuator has to be fully retracted during installation to give you the necessary room. I used safety wire to keep it fully retracted until it is fully installed and the flapper arm is installed onto the belcrank pin. The full retract position is also the recirculation position - flapper door closed.
Install the belcrank onto the actuator end. Carefully install the belcrank/actuator assembly onto the belcrank shaft. Do not try to fit the pin into the flapper lever - it gets installed as the last step.
After the belcrank is in place on the shaft, install the actuator fasteners, connector and vacuum lines.
Using a long screwdriver, long thin yard stick - push/deflect/slightly bend the flapper lever enough to fit over the pin on the belcrank. I would recommend applying heat from a hair dryer to make it more pliable.
If I could have easily removed the flapper lever, I would have. I believe it is held into the flapper door by lock tabs, but I didn't want to risk any damage.
Remove the safety wire from the actuator and test operation.
Hope this helps.
Bruce
Bruce,
I was wondering how your replacement belcrank is holding up and could you provide a contact for the 3D company that printed yours?
Thanks,
addy6
addy6 is offline   Reply With Quote
Old 08-06-2019, 11:26 PM   #46
KGB Pilot125
I think the part is on thingiverse, I have seen a few sprinter HVAC items on there. They also provide a printing service, I used a couple of them before I got my 3D printer.
KGB Pilot125 is offline   Reply With Quote
Old 12-28-2019, 09:23 PM   #47
doug022984
Doug
doug022984's Avatar
Originally Posted by doug022984 View Post
I thought I'd toss in my low-cost repair for this lever / belcrank or whatever you want to call it. Mine was also broken and looked almost identical to bc339's in post #12 of this thread. I didn't want to spend $50 on a 3D-printed one nor did I want to whittle one from a block of Delrin I had laying around (although I did think about it). I was inspired by Aqua Puttana's mention of using a nail. I mic'd the OD of the good pin at exactly 5.0 mm (knowing Mercedes would use metric everything) or 0.196". I wanted something close to that diameter but couldn't find any nails that size and didn't have any M5 metric bolts with shanks laying around. A #10 bolt shank is 0.145" diameter, so a little small. I settled on a 3/16" diameter (0.187") drive nail anchor (pictured) for $0.33 at ACE hardware.
Then I had to drill a 3/16" hole in the arm. I didn't trust myself using a drill accurately without messing up, so I used a 3/16" endmill since I'm fortunate enough to have access to a machine shop.
Hacksaw off both the ends of the drive nail anchor after measuring the length you need, leaving the head on; insert it in the hole from the back side and then Q-bond the $%&@ out of it for reinforcement. You're left with a pin that's stronger than the plastic one on the other side. If you've never used or heard of Q-Bond, GET IT! I haven't found anything better for repairing/reinforcing little plastic auto parts.
UPDATE: after almost 4 years of use, my bellcrank repair was still functioning, but since I had to remove my ventilation housing for another repair, I inspected it and noticed a lot of the superglue Qbond material was gone and the pin was loose. I'm now trying 2 part epoxy to hold the pin in place, which will hopefully last longer.
ALSO A TIP (since it wasn't obvious to me the first time): my original repair was done trying to work my hands in on the side of the ventilation housing with it installed in the van. This required some blind work, lots of hours and swearing. Having recently removed the ventilation housing, I recommend doing this for any repairs to the recirc door mechanism. Contrary to what the service manual appears to say, the ventilation housing can be removed simply with 5 nuts and a couple electrical plugs. The wiper fluid reservoir, all refrigerant lines, coolant lines, and even the turbo heat shield can all remain in place to remove the ventilation housing and then working on the recirc door mechanism is so much easier.
2004 Freightliner-badged 2500 Cargo High Roof, 140wb, 16" wheels, OM647, 234K miles.
doug022984 is offline   Reply With Quote
The Following 3 Users Say Thank You to doug022984 For This Useful Post:
Aqua Puttana (12-28-2019), gilee (03-20-2020), peteinohio (02-06-2020)
Old 03-20-2020, 04:05 AM   #48
gilee
2005 Sprinter Van 2500
Hi Doug, I am also having problem with my recirculation, and will need to remove the housing to fix the recirc door mechanism.
It is great to see your TIP, and looking at the service manual (attached below), it only shows 4 nuts.
Thanks again!
2005 Sprinter 140" SHC 2500 OM647 Camper
gilee is offline   Reply With Quote
Old 03-26-2020, 02:05 AM   #49
owner
owner's Avatar
Originally Posted by owner View Post
Has anyone thought about somehow reversing the bellcrank/actuator/spring mechanism so that the door is open when the button is pressed, and is in recirc by default? I though about doing this by swapping over the actuator to bellcrank pivot. It would require a slight re-mounting of the actuator, but other than that it should just work*.
I have actually done this now, and it has been working fine for 6 months. So its solidly in recirc mode all the time even with the engine off. In fresh air mode it opens the flap blade about an inch, so its not a true 100% fresh air solution, but it works for me.
I guess it could be made to work better, because all I did was hack off some plastic and re-mount the vacuum actuator so it worked in reverse. Crude but totally effective for want I wanted.
owner is online now   Reply With Quote
The Following User Says Thank You to owner For This Useful Post:
Aqua Puttana (03-26-2020)
Old 03-26-2020, 02:57 PM   #50
Aqua Puttana
Any chance for a picture(s)? Others may want to copy what you did.
