Old 05-06-2019, 04:39 AM   #61
HighPockets
Default Re: 170ext land yacht
I see you have toe space under the cabinets. I tried to configure that with 8020 but decided the extra cost wasn't worth it. Kudos for yours.
Gene
'07 CRD 144" high top, Koni Reds, Hellwig stabilizer bar, 276K miles, new paint, Pioneer SS with two amps, 11 speakers, at work on RV build-out.
The Following User Says Thank You to HighPockets For This Useful Post:
vannoob (05-12-2019)
Old 05-12-2019, 07:18 AM   #62
vannoob
Gene
Thanks Gene,
I fought with the idea for a while then just ended up coming up with a design that I thought would work. Certainly not the best but we'll see how it pans out once it's all buttoned up.
Allen
4x4 170 ext. soon to be tinyish... home
vannoob is offline   Reply With Quote
Old 05-13-2019, 04:31 AM   #63
vannoob
The infamous "it's done" aka I'll find something I forgot or need to change in a week or so
The bar leaned up against the fresh tank will bolt to the two post with plusnuts in the top. It will then have a Shelf stretched across to the expansion tank mounting bar with justtt enough clearance for the cap! I made that bar removable so if I ever needed to remove the tank for some reason I wouldn't have to drain and take out that elbow. Just kill the ball valve that will be shorty after it, remove bar tilt out and lift up... some day I'll see if it was worth the time and effort
The Following User Says Thank You to vannoob For This Useful Post:
royce (05-13-2019)
Old 05-13-2019, 04:33 AM   #64
vannoob
The Following 2 Users Say Thank You to vannoob For This Useful Post:
royce (05-13-2019), SD26 (06-15-2019)
Old 06-15-2019, 01:02 PM   #65
SD26
2012 NCV3 3500
Originally Posted by vannoob View Post
Getting things situated so I can button up the fab on the services cabinet
How many gallon tank is that, and where did you source it?
Thinking about going upright myself.
SD26
2012 Sprinter 3500 170EXT
2004 Sprinter 2500 158, totaled by deer 5-2019
SD26 is online now   Reply With Quote
Old 06-21-2019, 06:03 AM   #66
vannoob
It's a 20gallon tank from plastic mart.com I went with the 'custom' fitting configuration.
Haven't measured but with where the fittings are im guessing I'll get 17-18 gallons in there
SD26 (06-21-2019)
Old 08-15-2019, 06:02 AM   #67
vannoob
Final epoxy coat is cured. It has its imperfections but damn happy with the turn out
Mickyfin (08-15-2019), Surveillance Van (08-15-2019)
Old 08-15-2019, 10:13 AM   #68
royce
That looks great
royce is offline   Reply With Quote
The Following User Says Thank You to royce For This Useful Post:
vannoob (08-18-2019)
Old 08-18-2019, 03:03 AM   #69
vannoob
Default 170ext land yacht
Subfloor is finally a finished product a year later. I'm absolutely miserable at starting and finishing things in an organized order. Never having built something so technical is proving quite the learning experience
There is 1.5" pink hardboard insulation underneath along with a series of joists. I was willing to loose head space since I'm short
Next up will be the motion window install before winter hits and while it's warm/ dry enough to paint the edge after the cut
Old 08-25-2019, 04:52 AM   #70
vannoob
Smooth sailing on the install hopefully it doesn't leak!
Mickyfin (08-25-2019), royce (08-25-2019)
