Old 07-19-2016, 06:50 PM   #21
GrayGhost
GrayGhost's Avatar
Default Re: Toy Hauler Build
I doubt your van will see much abuse or twisting, but you might consider some gussets or metal angle brackets for your cabinets. They add lots of strength, and they prevent "racking" during a crash. I used 2 of these brackets in the corners of my galley, and then put a bolt/rivnut to secure the bracket to the van wall.
Will do , I plan to add some aluminum angle anyways to my three mounting points. I will make sure to make a few corner braces as well.
GrayGhost is offline   Reply With Quote
Old 07-19-2016, 09:58 PM   #22
GrayGhost
GrayGhost's Avatar
When your rollover couch bed comes in but you drove your Prius to work.
File Type: jpg IMG_20160719_152844229_zpstjaegvqy.jpg~original.jpg (167.0 KB, 68 views)
Old 07-19-2016, 10:16 PM   #23
Ooh, I like where this build is going. Is that going on drivers side aft, or?
Old 07-19-2016, 11:07 PM   #24
GrayGhost
GrayGhost's Avatar
Sofa bed is going behind the drivers seat along that wall. Behind that will be a small bench/day bed with storage. Passenger wall will be galley, closet , shower from front to back.
File Type: jpg IMG_20160719_211721_zpslk1faoqr.jpg~original.jpg (102.9 KB, 63 views)
Old 07-20-2016, 03:28 AM   #25
dynaco1
dynaco1's Avatar
Which brand and model Rollover Couch Bed did you buy? What is the overall height of the back rest when upright?
dynaco1 is offline   Reply With Quote
Old 07-20-2016, 03:58 AM   #26
GrayGhost
GrayGhost's Avatar
They are made by Newhouse, sold by blazinbelltech.com / moduline cabinets / rb components
Old 07-25-2016, 12:20 AM   #27
GrayGhost
GrayGhost's Avatar
Today's progress. These rollover sofa beds are made to be mounted to the wall. I thought outside vans were on to a great idea when they built frames instead. With space at a minimum, I decided to panel the front of mine and hide battery bank and all electrical underneath. (To come later).
After I verify all will work, these will be removed and powdercoated.
Old 07-30-2016, 03:13 AM   #28
GrayGhost
GrayGhost's Avatar
Today finally saw some additional progress. Pulled the walls back down to run wiring, installed the maxxair fan (cutting the second is easier like most have said), dicor'd all the roof seams, and installed the two 100 watt solar panels. We used stainless 6mm bolts instead of the self tapping screws they sent. Generous Dicor on those as well.
Old 07-31-2016, 05:55 PM   #29
d_bertko
Did you leave a big enough air gap under the solar panels?
Old 07-31-2016, 06:12 PM   #30
GrayGhost
GrayGhost's Avatar
No clue,
