Old 03-04-2019, 12:06 AM   #11
Aaroniac
Default Re: diy rear door spare tire carrier
Is there any reason you didn’t build the carrier with the wheel reversed and mounted flat against 80/20 (on a flat plate attached to 80/20) ?
Aaroniac is offline   Reply With Quote
Old 03-04-2019, 02:38 AM   #12
floydturbo
Folsom, CA 2015 w170ex i4
floydturbo's Avatar
Purely cosmetic. I wanted the nice side of the wheel pointing outwards to look nice.
2015 170ext i4/7sp
floydturbo is offline   Reply With Quote
Old 03-04-2019, 02:53 AM   #13
Aaroniac
That makes sense. I have two more questions.
What material did you use between the outside door and the small column 80/20 spacers you cut (looks like a circle of black plastic)?
How tall are your 2 80/20 vertical sections?
Old 03-04-2019, 02:55 AM   #14
floydturbo
floydturbo's Avatar
They are large rubber washers
2015 170ext i4/7sp
The Following User Says Thank You to floydturbo For This Useful Post:
Aaroniac (03-04-2019)
Old 03-13-2019, 05:26 PM   #15
Mrprez
Anyone think of a reason this wouldn't work on a 2006 Sprinter? N/M, ordered the Sureco.
Mrprez is offline   Reply With Quote
Old 03-15-2019, 05:49 PM   #16
Aaroniac
I have been using three types of 80/20
1515
1515 light
1515 ultra light
Do you know which one you used for the tire carrier
I included a pic of all three
Old 03-15-2019, 06:35 PM   #17
floydturbo
floydturbo's Avatar
I use the 40 series. 40mm
2015 170ext i4/7sp
Old 03-15-2019, 07:00 PM   #18
Aaroniac
the 40 series also comes in the three weights. Are the triangular corners hollow or solid?
Old 06-22-2019, 04:18 AM   #19
patineto
I'm borrowing your idea to install my spare tire on my FORD E350
have you notice any deformation on the door shell, stress risers, etc...??
I plan to connect my 80-20 and create more of as "Square" So the 80-20 is "independently structural" (stable on a fix plane) to diminish the load transfer into the door..
Tip: In the old school Range Rover world is a guy, a really nice guy name John Gadd, that has millions of range/land rover parts (Usually the engine fail, but the rest of the parts are very good)
Roverdude" AT "sbcglobal" DOT "net
patineto is offline   Reply With Quote
