Closed Thread
Old 03-15-2015, 01:25 PM   #11
Default Re: Some 2004 Espar Heater Notes
I've noticed some comments about the dash temperature settings being related to the Booster Heater and Aux Heater operating. To my knowledge the Espar doesn't care what positions that the OEM Cabin fan/heater controls are in.
Once the Espar heaters are enabled and fired up the temperature control is maintained by a coolant temperature sensor contained within the Espar heater module. Given proper coolant circulation the heater will run until the coolant temperature reaches setpoint.
There are 2 ea. control setpoints. The first lower temperature will trigger the Espar to go to low power output. The higher (167F if memory serves) will trigger a shutdown of all firing. There is an even higher over-temperature limit, but that shouldn't come into play when proper coolant circulation is maintained.
Except for the Espar dedicated dash controls, the OEM cabin temperature controls do not affect the Espar operation once it is enabled.
Aqua Puttana is offline
Old 03-18-2015, 11:17 PM   #12
1/4 tank Espar Disable
I have seen quite a few references to the "1/4 tank or more" for the Espar to run. Yesterday I used my Booster Heater for the first time since returning from Florida. With well below 1/4 tank showing on the gauge I could hear the heater blasting happily along until it suddenly stopped. At the same time my low fuel warning light came on. The engine temperature was below 145F by the OEM dash gauge so not hot enough to shut down the Espar.
My conclusion.
The T1N low fuel light logic is what triggers the Espar disable for low fuel. It makes sense to use an already established low fuel circuit. I've found nothing in the schematics which shows any reference to a 1/4 tank signal. The "Above a 1/4 tank" in any documentation is probably just an easy reference.
Goofy foot (08-19-2017), Jonny Cut Corners (12-01-2017), Oilburner (03-19-2015), seans (07-29-2015)
Old 12-07-2015, 05:16 PM   #13
January 19, 2014
I believe that now I have enough information to end my recent obsession with all things Espar in my 2004. (Just my latest obsession of many?)
The Booster heater is working fine. It is wired to pre-heat the engine. I know what specific burner part number will work.
2 seasons of successful operation on my Espar heater since my repairs.
Yesterday I removed my heater for general cleaning. It was smoking out the muffler a bit more than usual at startup. I thought that maybe the screen on the D shaped igniter hole had plugged a bit with soot.
Actually there was little soot. I flushed it well with carburetor cleaner as to not disturb the metering screen assembly and re-assembled the heater. A bit less smoke now on startup, but not as little as I recall before. Maybe my memory is optimistic as to how much smoke there was?
Some comments.
In 2015 I repaired the burner screen which I dug out/damaged. I did that by pushing a bit of asbestos cloth yarn up into where the screen terminated in the fuel supply. The asbestos fiber acts like a wick to meter the fuel down on to a fairly coarse nickel screen which I put over it to hold the fiber in place.
The wick and screen looked fine after 2 seasons. There was a bit of soot that easily flushed off the screen by using carburetor cleaner. I really didn't want to disturb my repair at all in case by dumb luck I hit the Goldilocks Zone "just right" combination when I installed the fibers and screen.
The main burner, glow pin, and flame sensor didn't have any real buildup of soot at all. It all appeared generally clean. I didn't disturb the burner coolant chamber O-ring seal. I was able to re-use the graphite composition burner gasket.
Even though I used anti-seize compounds on the screws, some had corroded to the point of being immovable. The one was on the top cover which protects the heat sensors. I deemed that of no real consequence because my warped cover already needed some sealant anyway.
The other was the short screw which locks the burner to the exhaust port. After trying many different removal methods I just drilled that one out. It also was deemed not worth replacing. The other 3 screws will hold that assembly together well enough.
So... if you live in the ugly road salt Northeast it may be worthwhile to open your heater up for cleaning every 2 seasons or so. That may help with keeping fasteners from seizing up.
The anti-seize which I used on the aluminum intake tube allowed that to be removed without issue. The ss exhaust tube was stuck a bit even after using anti-seize, but came off intact with some patient slight twisting and moving about. (The exhaust pipe retaining screw doesn't line up and hasn't been installed for a couple years now.)
Old 01-18-2016, 01:59 PM   #14
Some general information for the Espar heaters.
All this information is out in other threads. I am repeating. A search can be your friend.
The basic Espar heaters are a small self contained oil burner furnace as to firing. The heaters can be installed stand alone in boats and vehicles. The little furnace has a built in combustion control module for the ignition, blower speed, flame monitoring, operating temperature control, and overtemp safety monitor.
To just fire up, the Espar furnace needs a fuel supply (pulse pump), combustion air (internal fan), and an ignition source (glow pin). The native combustion controls are just sitting there waiting for your Sprinter to wake it up properly.
The basic external requirements to fire up are:
Constant 12 volts to pin #1.
A proper negative ground connection pin #2.
A connection (wire) out to the dosing pump pin #4 (It is a conditioned signal. Not just 12 VDC.).
A 12 volt enable signal to pin #6.
A 12 volt enable signal to pin #7.
Pin #5 is for communication. It is not required.
The circulation pump is not required for the heater to fire up. The Espar control has no idea what the MB aux electric coolant pump is doing, or not doing until the heater goes to over-temperature. Without proper coolant circulation the Espar heater will shut down on overtemp safety in a short time.
The Espar heater does run through an internal system check before firing. If there is a problem with the glow pin, flame sensor, blower, etc, then that will prevent the Espar heater from getting to startup. (There may also be some sort of verification for an external relay component. I say that because there have been reports of the Sprinter Espar throwing a coolant pump code failure. That is even though the MB Aux Electric Coolant Pump has no connection to the native Espar controls. The Aux Espar with two electrical connectors may have a direct connection.)
Here is a basic diagram.
Added: As Vanski pointed out, the Espar coolant type heaters can even be test fired with no coolant. I wouldn't allow it to run for more than a very short time without coolant though. It will very quickly over heat and stress components.
Old 01-19-2016, 07:26 PM   #15
Program Timer
I found this guy's comments helped me to easily operate and program my Espar timer.
RESET METHOD
Apparently a reset can be accomplished without a scan tool or control head communication. Thanks goes to SkyGypsy.
Originally Posted by SkyGypsy View Post
If the unit doesn't start, then you can clear and reset the unit by powering it up, then pulling the fuses underneath the driver seat. I have done this several times and gone from no response to startup in moments.
I have done a full overhaul on my unit. I should post a write up on it. I have the factory manual, maybe I will post it on my website for others to download.
I have not tried the above.
Old 11-18-2016, 01:35 PM   #16
Note: One expert I've communicated with warned that Bio-fuel is a problem with the Espar heaters. He even cautions against 5% and suggests installing a "Day Tank" and running the heaters on Kerosene. I can't disagree, but installing a day tank with easy fill capability is likely easier said than done. He mentioned that a coffee colored residue which is harder to clean than the normal black soot is one evidence of bio-fuel rlated problems. ...
I was recently made aware that the NAS aka NAFTA T1N models have the fuel fill body metal chamber on the passenger side. Thanks Dick.
That area may provide a place to add a fill port to an Espar day tank mounted under the Sprinter.
Another use for that chamber might be for an external potable water fill port.
Some possible parts.
http://www.discountskitubesandgear.c.../?locale=en_au
https://www.starmarinedepot.com/whit...s/pzz4528.html
Old 11-19-2016, 02:39 PM   #17
Some Condensed Information from this (same) thread http://www.sprinter-source.com/forum...ad.php?t=30384 that may help with troubleshooting.
All of the information is from my Some 2004 Espar Heater Notes thread so take the time and go back for pictures and schematic references. This is not a "How to". Some basic multi-meter and other troubleshooting techniques will be needed.
At some point you may just need to bite the bullet and remove the Espar for testing and cleaning. It isn't that difficult.
Some other 2004 Espar Booster Heater threads which I've posted are here:
Remove Espar Heater from T1N
http://sprinter-source.com/forum/showthread.php?t=30427
General Espar Heater Wiring Information
http://sprinter-source.com/forum/showthread.php?t=30191
Cabin Fan Resistor Circuits
http://sprinter-source.com/forum/showthread.php?t=30286
T1N Booster Heater Wireless Control
http://sprinter-source.com/forum/showthread.php?t=30512
First: The Varnish Sniffers across the pond have been busy revealing interesting information about the Espar heaters since I last visited their site. Visit the site.
http://www.letonkinoisvarnish.uk/Ebe...r_Intro_1.html
My Espar start overview.
What I learned after it fired.
The earlier times that I thought it was firing it was just burning fuel in the glow plug chamber which produced white smoke and did not ignite the main chamber. Actually evaporating might be a better term than "burning".
The faulty operation sequence as I recall it.
The engine noise at idle makes it hard to be certain of some noises. After starting the engine the Espar combustion fan would cycle for a quick ramp up. After a short fan run cycle to purge the combustion chamber the fuel would pulse in. The heater would begin pouring out white smoke. I thought that meant it was firing because the combustion fan would ramp up. After ramp up I'd see even more white smoke. Then the fuel pump would stop, the fan would ramp down, raw diesel fuel would drip out the exhaust (I later learned that my muffler packing was soaked with fuel.), the fan would run a while (combustion chamber purge) and then slow down. After (if?) the first start fails, the blower runs on a low speed into a 2nd start attempt. If the 2nd start fails, the blower continues to run through a standard cooldown cycle and then locks out for no more attempts until a power down reset.
Each failed ignition attempt dumps about 1 1/2 teaspoons of unburned (raw) diesel into the combustion chamber. No ignition at all = x2 start attempts = approx. 3 teaspoons of fuel. The combustion fan carries that fuel to the exhaust system. Once the muffler stuffing is saturated the fuel will spill out from the exhaust system.
I learned that when the heater actually fires off there was just a little white smoke and then the Espar would begin to roar. You will recognize the roar as opposed to just the fan ramping up. It sounds like a low rubble not just a whine. The whine is just the fan turning up to very high speed. For each start attempt the fan will run and the fuel pumps until the flame sensor kicks into the circuit and realizes that there is no main flame. It then stops the fuel and the fan ramps back down, but not shut the fan down right away. As I said, the white smoke I saw is just the glow plug chamber fuel burning (evaporating?) and not actually igniting the main burner.
Firing correctly = A little white smoke then No Smoke. Not enough air = Black smoke. Unburned fuel = White smoke.
I've read that Espar heaters "Lock out" after some failed start/ignition attempts. I don't find that true with my 2004.
Originally Posted by Kubbie View Post
Isn't it true that after a number of failures to fire, the Espar locks itself out and needs to be reset with an MB star tool?
I've read that. From my research that may be the mode of a native Espar diesel fired heater. I've read that after so many start attempts the native Espar heater locks out and needs to be reset using the proprietary Espar access scan tool. OR maybe the permanent lockouts are related to specific component failures which are monitored by the Espar computer and people assume it has locked out related to a couple start attempts.
My experience:
My 2004 heater main burner never fired for the first 6+ years that I owned my van. I tried it more than a few times over the years. Each time the most I would get was white smoke = unburned fuel. The Ignition Air Duct was plugged solid so the main burner never fired. When the button was pushed the red dash LED would light, the heater would try to start two times in succession and then would lock out, but not permanently. After an engine shutdown and restart it would again give two white smoke cycles.
After I cleaned the burner and screwed up the screen "wick" metering into the glow plug chamber I tried many more x2 white smoke cycles. There was never a permanent lockout. The heater runs fine now.
So, my experience shows that the Sprinterized Espar control module doesn't lock out after a failed ignition sequence. The 2 x start tries are allowed and then it prevents any further starts until power off/on. That is not as described for the native Espar control.
This thread has some good info.
Espar Booster Heater Not Starting - Info near Write-up Status
http://sprinter-source.com/forum/showthread.php?t=18131
Espar D5 Fuel Quantity Test
Fuel Quantity Test
The fuel Quantity should be tested if the heater has difficulty
starting or maintaining a flame.
Note: Measure the fuel quantity when the battery is
sufficiently charged. At least 11V and at
most 13V should be applied at the control
unit during measurement.
Preparation
• Remove metering pump cover in the cases of SC versions.
• Pull the fuel line off the combustion chamber and insert
into a graduated measuring glass
• Switch the heater on, when fuel delivery is uniform
(approximately 40 seconds after switching on), the fuel
line is full and bled.
• Switch heater off
• Empty measuring glass and replace
Measurement
• Switch heater on
• Fuel delivery stars automatically approximately 40
• Hold the graduated measuring glass at the glow pin
height during measurement
• After 90 seconds of fuel delivery, it will shut off
automatically
• Switch heater off.
• Read off quantity of fuel delivery in the graduated
measuring glass
Evaluation
Nominal value
Diesel
Hydronic D5W SC
8.6 cm3 / 90 seconds - Maximum Qty
7.5 cm3 / 90 seconds - Minimum Qty
7.5 ML = approx. 1 1/2 teaspoons
I found that an old Baby Medicine Dosing Spoon worked perfectly to measure the fuel output. The output from my pump was at the 7.5 ML low end of the specification. (Note that the 90 second test includes a combination of low pulse and high pulse pump operation. Low pulse = ignition cycle. High pulse = ramp up until no flame sensor cutoff.)
Attachment 56483
http://www.maxiaids.com/products/143...FclcMgodQAIAoQ
The fuel doesn't "pump" out it more trickles out. You can feel the fuel line pulse as the fuel is "pumped".
These Sprinter wire colors and function are deciphered from a few different technical sources and schematics. You will not likely find this info in many places. MB doesn't make it easy to track down using just their Service Manual schematics. The MB OEM controls are a step child to Espar that they have no interest in.
Sprinter OEM Espar Plug Info
Chamber (Pin) - Cross section/Colour - Function
Pin #1 - 1,5 red - plus supply, terminal +30 Sprinter = Orange? (Red/? - Heavy Wire) - All (8W-42-11)
Pin #2 - 1,5 brown - minus supply, terminal –31 Sprinter = Brown (Heavy Wire) - All (8W-42-11)
Pin #3 - 0,5 black/red - not in use? Sprinter = Blue/Yellow - Program Timer Only - Fan Stage 1 Relay = REST Low Spd (8W-42-08)
Pin #4 - 0,5 green - plus signal, dosing pump Sprinter = Dark Green - All (8W-42-11)
Pin #5 - 0,5 blue/white - diagnosis Sprinter = Blue/Red - All (8W-42-10)
Pin #6 - 0,5 blue - terminal 15 Sprinter = Blue - Program Timer, Black/Blue/Orange - Except Program Timer (8W-42-10, 8W-42-11)
Pin #7 - 0,5 yellow - D+ dynamo Sprinter = Yellow - Program Timer. Blue - Except Program Timer (8W-42-10)
Pin #8 - 0,5 black/white - not in use?? Sprinter = Blue/Yellow (8W-42-09)
Pin #8 Clarification Note:
Cabin Heater Module aka Program Timer = Circulation Pump Relay - Cabin Heater Module (Relay Block)
REST System aka Except Program Timer = ATC Module - No Relay, Direct (Heater Booster Mode) (8W-42-09)
Note:
*The Dash Inset Control aka Program Timer will have a Circulation Pump Relay and a Stage 1 (Low Spd) Fan Relay under the driver seat.
* The Booster Heater aka Except Program Timer doesn't have any related relays under the seat.The ATC module does the logic/control for the Booster Heater/REST pump and fan.
Have fun.
outbound (11-19-2016)
Old 11-23-2017, 03:25 PM   #18
I have not tried the above. It did work. I pulled the 25 amp fuse under the seat.
More info from SkyGypsy.
I don't know how it's different, but that is the procedure. And it has worked for me on several occasions.
My heater tests returned these results at 92F. I have the workshop manual somewhere but I'm on my phone now. It's easy enough to find.
Test results
Glow pin - 0.6 ohms
Flame sensor - 1132 ohms
OH sensor - 7.25K ohms
Temp Sensor - 7.25K ohms
They were all within spec.
And more:
... However, recently my unit stopped working for me and the fuse reset wasn’t bringing it back to life. The start up sequence wouldn’t even turn the fuel pump on.
I took it to the local thermo king (4 hours away) and they ran diagnostics. Turns out my flame sensor set off multiple codes.
Not that this matters. Your fuse removal reset was probably still clearing the Espar. (Thanks for that tip by the way. )
The Espar was likely not getting past the flame detection verification of the combustion module pre-start safety routine. That should throw it right back to lockout.
...Unfortunately, the tech didn’t not read the full description of the troubleshooting guide for that code, which is to short the sensor and see if that throws the proper code to verify it is indeed the sensor and not the ECU. oh well. It will cost about the same to just order the part as it will to drive back down there. ...
Another good piece of information.
...Anyway, my point is you probably have an error in the start up sequence and that is why you’re not hearing your fuel pump. Run the diagnostic wire. You’ll know what you need to do, and you can also use that to unlock a locker out heater, if the fuse truck doesn’t work.
Good advice.
I'm unlikely to be proactive enough to add the Data Link enable wire to my 2006 console control now, but the first sign of odd Espar issues will have me install that feature.
Some additional detail for the Fuse Pull Reset Trick from Drew502.
Originally Posted by drew502 View Post
The Espar is back in action. In and effort to add to the knowledge base of the forum, the following is a summary of sorting the Espar DW5Z in my 04 T1N Sprinter and some other lessons learned.
Recap:
About 4 years ago, I replaced a bad Flame Sensor and the Espar has worked w/o issue since then. I ran the Espar about 5 months ago to exercise it as some have indicated that they need to operate regularly. A couple of months ago I tried to do another maintenance run cycle and the Espar would not start (or do anything) and the cover over the temp sensors looked somewhat warped.
Data Points:
I removed the Espar and checked the following; hardware appeared operational and values in range.
[Ambient Temp of 70 degrees]
Glow Pin resistance = .9 Ohms
Flames sensor Resistance = 1.1 K/ohms
Cold Sensor Heat Exchanger - 9.27 K/ohms
Hot Sensor Heat Exchanger - 9.03 K/ohms
Espar Fan spins freely with 9 volts applied
Intake and Exhaust hoses are free of obstruction
Disassembled burner chamber and sprayed carb cleaner into the D-chamber / fuel wick.
I have not heard of dosing pump failures so I just made sure that it was connected and did not test it. Given that the Electronic Control Module had made it this long, I guessed/hoped that it was ok, but did not rule it out as the culprit.
Hypothesis: Given the failure rates of the Electric Circulation Pump, the fact that mine was the stock unit, and the warped plastic cover, I speculated that the ECP had failed causing an overheat fault and corresponding lockout. However, the vexing part was that I could hear (and feel) that the ECP was still working with the REST function on but I questioned whether it was actually moving sufficient coolant (I did not disconnect the hoses to confirm). Even more vexing; generally speaking, the Espar does not require the Electric Circulation Pump when the engine is operating. Given that my Espar ONLY operates with the engine on (i.e. no bypass or 7 day timer), then why would failure of the Electric Circulation Pump cause the Espar Hydronic to overheat?
Theories:
Aqua Puttana - "The mechanical coolant pump output varies. I believe that engine speed is a factor. Idling too long without the Electric Pump operating may reduce flow in the Eberspacher heater enough to cause overheating.”
Midwestdrifter - "The heater is designed around having coolant flowing through it. If it starts up and gets to temp with no coolant flow, it is entirely possible for the burner temp to overshoot by a significant margin before the temp sensor catches it. Plus even if it sees the overheat and cuts the fuel, there is still a fair bit of fuel in the vaporizer/burner which will still keep making heat for 10-15 seconds. It is possible that the heater might shut down due to overheat with just the engine circulated coolant. However it would not be likely to overshoot, and would restart once it cooled down."
"Depending on how the heater is oriented, there may be a air/gas bubble around the temp sensor if there is no coolant flow. Such a gas bubble could prevent accurate temp sensing. That is not an issue if there is any coolant flow, which would likely purge the bubble.”
Based on the foregoing data, theories, and the medical diagnostic adage “when you hear hoofbeats think horses not zebras” (i.e. go with the odds)- I elected to replace the Electric Circulation Pump since it is a high failure rate item. After a fuse pull reset, the Espar fired up.
Lessons learned:
1. Apparently, the ECP can still appear operational (sound/vibrating) but have insufficient flow for the Espar such that it causes it to overheat even though the engine is running.
2. The Espar did not fire up until I got the fuse pull sequence correct. The Espar fuse pull reset requires:
a. Start the vehicle
b. Turn on the Espar with the bacon button.
c. Pull the #1 and #6 fuses
d. Turn the Espar off
e. Replace the fuses
f. Turn the Espar back on and wait a minimum of 3-4 minutes
3. When you first turn on the ignition and the ECP starts up, it makes a loud buzzing sound until the coolant reaches the pump.
4. A diagnostic tool would be worth it's weight in gold if you plan on keeping a stock Hydronic Espar unit.
*Bonus points - Working on the Espar and or Electric Circulation Pump is a great time to do a coolant service if you are due. I removed the Espar and ECP after draining the radiator. Based on refill volume 2+ full gallons (1 gallon Zerex G5 and 1+ gallon distilled water) it appears that a near total evacuation was accomplished w/o the hassle of removing the block drain plug.
**Double Bonus points - If you have not done so already, changing your Glow plug Relay module is easy while the grille/headlight assembly is out and you are messing with the Espar etc.
Thank you all for your input!
An Espar Aux Timer Control possible hack.
If the console dash timer/controller fails there is a temporary, maybe permanent hack.
A mechanical thermostat or twist timer can be wired from 12v+ to the yellow enable wire. A simple switch would also work, but perhaps a temperature/time control of some sort is wanted.
An example of a mechanical stat.
https://www.walmart.com/ip/White-Rod...ostat/37528790
An RV style mechanical stat will also work. More $$$.
As an aside for northern home owners who travel:
I used this stat as a backup freeze protection addition to my home programmable thermostat.
https://www.amazon.com/gp/product/B000E7PZUY/
Most programmable stats are NOT fail safe = no freeze protection. A cheap thermostat will provide that protection. The lowest temperature on the above stat is 50F. That was great for my freeze protection (No off switch. I set 55F.), but will need an off/on switch for the Espar hack use.
A twist timer example.
https://www.homedepot.com/p/Intermat...2HWK/205478810
Old 02-10-2018, 01:23 PM   #19
There is no Flame Sensing proper with the Espar combustion control
An answer to a recent PM.
Ho boy. It's cocktail time in the Keys and I just ran across your questions.
Using my poor memory.
To my knowledge, the T1N OEM Espar combustion module doesn't use a flame sensor proper. The established flame feedback is provided by the temperature sensors which are clamped into the heater housing.
Once initial pre-ignition system tests have been passed, the combustion control looks for a rise in housing temperature, not a flame. If that rise isn't verified, the Espar shuts down. [Note: The fuel pump output ramps up (faster tapping) after each start attempt whether flame is established or not.]
I believe that what you refer to as a flame sensor is the glow pin heater which inserts into the "D" shaped opening. For certain the glow pin ignites the fuel in "D" chamber. Once flame is established I'm a bit sketchy on how the main combustion chamber is fueled. I believe that some sort of vortex is created to keep the fuel/air mixture firing. As I said... sketchy.
Anyway, the 2004 glow pin did screw out. You'll need the glow pin with integral leads [because you have a burner with integral fuel pipe].
Some info should be here.
https://sprinter-source.com/forum/sh...601#post278601
There is more info in post #1 which may help.
I hope this helps.
kkanuck (10-26-2018), outbound (02-15-2018)
Old 11-13-2018, 02:15 PM   #20
This operation sequence chart was recently posted by Nautamaran.
https://sprinter-source.com/forum/sh...611#post709611
Mickyfin (11-13-2018)
Closed Thread
espar info
