Old 07-18-2014, 02:49 AM   #61
Graphite Dave
Dave Orton
Default Re: Orton DIY - Misc.
Originally Posted by aroc View Post
What size of drill bit are you using? I tried 1/2" with my 5/16 Rivnuts and its a bit tight.
I did not use Rivnuts. Used Penn Engineering inserts. Drilled 11/32" hole.
See post 11 "orton diy - ceiling" for more information.
Old 06-20-2016, 11:01 PM   #62
Suza
Leveling:
A way to determine how many Lynx plastic leveling blocks are required to level van. My van has a 144" wheelbase. Made a wood block that is 1/16 scale for the wheelbase and tread of the van. 144/16 = 9" long. Did the same for the tread width. The plastic blocks are 1" thick so I used 1/16" thick flat washers. Wood block has a two direction bubble level screwed to the top. I put wood block on the sink counter and then add washers to the corners until the block is level. The number of washers tells me how many Lynx levelers are required to level van.
Thanks for sharing your awesome, and scientific, method. I can see how this would eliminate hit-or-miss, trial and error shots at leveling. Get it right and go do something fun! Now I just need to convince DH
Suza is offline   Reply With Quote
The Following User Says Thank You to Suza For This Useful Post:
Graphite Dave (06-21-2016)
Old 06-21-2016, 06:35 PM   #63
Boxster1971
2012 Sprinter 3500 Ext
Boxster1971's Avatar
Default
I use the iWoMoSet app on my iPhone. It calculates the amount you need to add under any given wheel to get level. Choose between inches or centimeters. I think the iPhone app was about $3, not sure if it's out for Android phones.
- - Mike
2013 Airstream Interstate on 2012 Sprinter
-- Mike
Boxster1971 is online now   Reply With Quote
The Following User Says Thank You to Boxster1971 For This Useful Post:
Suza (06-21-2016)
Old 06-21-2016, 07:22 PM   #64
Suza
- - Mike
Unfortunately, our dumb phones won't do this, but I will add this to my list of reasons to get a smart phone (thus far, not a very long list).
Old 06-27-2019, 04:35 AM   #65
SunshineinSLO
Since I did not want any exterior indication that my van is an RV, my fresh water tank is filled by opening the sliding door to access the fill opening. I needed a hose end with a control valve. Being old I remembered the old valves used at gas stations to fill the radiator. Bought it from Benford Fueling.
Oooh! YESS! This is EXACTLY what I need! Thank you!
SunshineinSLO is offline   Reply With Quote
The Following User Says Thank You to SunshineinSLO For This Useful Post:
Graphite Dave (06-27-2019)
