Old 01-21-2016, 05:59 AM   #1
OldWest
T1N Westfalia
Default Shower Pan for Cassette Toilet
http://www.ermel-freizeitmobile.de/aktuelles/
Think this German repair shop is saying it has obtained and now sells a shower pan for T1N bathrooms with cassette toilet. May be expensive to ship to U.S.
The Following 2 Users Say Thank You to OldWest For This Useful Post:
ecobon (01-24-2016), onemanvan (01-21-2016)
Old 01-21-2016, 06:30 AM   #2
OldWest
T1N Westfalia
Default Re: Shower Pan for Cassette Toilet
And a roof repair or replacement. Can't get Google to translate so don't know if they patched or obtained a whole new roof.
http://www.ermel-freizeitmobile.de/u...k-reparaturen/
Old 06-26-2019, 10:56 PM   #3
OldWest
T1N Westfalia
Too late for AutoCamp and others who rebuilt their Westies with a Thetford cassette toilet, but the James Cook Friends Forum has a thread on the shower pan (DIFFERENT than our NAFTA Westies).
Can't wait to see the proposed metal replacement.
Note that our drainpipe is also different although location may or may not be the same.
AutoCamp and others chiseled out the raised NAFTA Bravura toilet riser portion while RobertFoster (for a composting toilet) and others just made a platform on top.
http://forum.james-cook-freunde.de/v...hp?f=16&t=6671
And poster Ciril took detailed measurements. PDF is below.
The Following User Says Thank You to OldWest For This Useful Post:
grozier (07-12-2019)
Old 07-21-2019, 07:58 PM   #4
OldWest
T1N Westfalia
There is a photo of the stainless steel? Metal shower pan for a cassette toilet in the first post of this James Cook Friends Forum thread. Looks really nice. Another poster suggests it came from eBay but need more info.
http://forum.james-cook-freunde.de/v...hp?f=16&t=6721
Old 07-22-2019, 12:49 AM   #5
OldWest
T1N Westfalia
EBay info using Google Translate:
https://www.ebay.de/itm/Sonder-Dusch...1-7e72fb7b1e59
Sonder Duschtasse 638(668)x780(810) Rand 15mm 1x Ablaufloch INNEN Schliff K320
EUR 195,00
(inkl. MwSt.)
EUR 163,87 (exkl. MwSt.)
EUR 195,00/Einheit
Without shower box 638 (668) x780 (810) Edge 15mm 1x Ablauflochen INEN Schliff K320
Info about this article
Item condition
New
product type
Tub drip tray
Selected search filters
stainless steel
brand
Shipping metal
Manufacturing Country And Region
Germany
material
Brushed / ground, 304, V2A, Nrio, 1.4301, stainless steel, stainless steel
material thickness
1.5mm
Stainless steel tubs folded, corners welded, surrounding edge 20mm
The offer is without siphon, (hole 40mm)
Tubs made of stainless steel, single folded, single-sided with ground joint K320
depending on the selection available in different thicknesses and sizes.
The dimensions given are external dimensions. Should you have different dimensions
(Intermediate dimensions), so this is of course possible.
You simply order the next larger size, which we then charge you.
Manufactured from high quality stainless steel [1.4301]
The visible surface is foiled and will only be removed by you during assembly.
The production takes place in the blank in the corners notched and
then bent 90 °. The corners are welded and stained electrically.
Dimensional tolerances: Width +/- 0.5 mm Length +/- 0.5 mm
Further tubs can be found in our
Last edited by OldWest; 07-22-2019 at 03:03 AM. Reason: Add more translated text from eBay listing
Old 07-22-2019, 02:59 AM   #6
OldWest
T1N Westfalia
On the eBay listing, there are three photographs: (a) the dimensions of the fiberglass type shower pan provided by Ciril, (b) photograph of the stainless steel drain with dimensions and (c).cross-section dimensions of the drain.
You may want to copy the photographs before they disappear.
Don't know how to interpret the dimensions of the stainless steel drain. It seems a lot smaller than ours and the cross-section dimensions are confusing (likely for a small cup-type drain but numbers for height or depth of 35mm and a flange width of 20mm seem weird???).
The eBay listing seems inconsistent re 15mm versus 20mm edges?
Anyways, the James Cook drain may be smaller and different than for our NAFTA version. Location may or may not be in the same position.
K320 is type of stainless steel finish. It's apparently the most common finish.
304 is the type of stainless steel. Again, a common type.
1.4301 and V2A are apparently other names for 304.
Nrio means ???
Old 07-22-2019, 08:05 PM   #7
OldWest
T1N Westfalia
Check James Cook Friends Forum for more info on stainless steel shower pan. Key is that third photograph in eBay listing is not appicable. Also, can go 670mm wide, 810mm long, and 50mm high (external dimensions) with 65mm including drain dip.
http://forum.james-cook-freunde.de/v...p=42910#p42910
[COPIED some of the info below]
OldWest
Re: Maße Duschtasse
Post 22.07.2019 17:59
Looks very nice. Couple of questions.
1. Rather than 670mm wide, description says 668mm wide. Is this to allow for expansion and contraction?
2. Top lip flange is described as either 15mm or 20mm?
3. What is height of sides? Third photograph seems to suggest 34mm high but shower hose thread photograph looks higher.
4. In shower hose thread, you indicated you got the wrong size drain and had to cut away some portion? But shower pan was right?
5. Did you use anything to stick pan down?
Thanks!
Note: K320 is a type of stainless steel finish. It's apparently the most common finish. 304 is the type of stainless steel. Again, a common type.1.4301 and V2A are apparently other names for 304. Nrio means ???
2005 NAFTA (USA) Airstream Westfalia (2004 Dodge Sprinter) Version of James Cook
Top
User avatarCompound
Re: Size shower tray
Post 22.07.2019 18:28
Hallo Old West,
"Niro" in german means: "Nirosta" = Nicht Rostend.
In english "will Never Rust"
Best Whishes, Komposti
JC 2003 316 CDI, automatic, alaska white, yellow means 85 W PV system, rear air-assisted, AHK, moped stage, etc ...
Top
SirJames
Post 22.07.2019 18:40
OldWest wrote: ↑ Looks very nice. Couple of questions.
Thanks!
Thanks!
1. The seller recommended to order the pan some mm smaller, to make sure that it fits. But the description is wrong, I wanted to have it 1mm smaller each side (809mmx669mm). But it is not necessary, you can order it in 810mmx670mm)
2. I did not measure it, bit I think it is 15mm.
3. The third photograph is some random drawing from the seller, it is a mistake. As I said in the shower hose thread, I ordered the wrong height. I ordered 65mm, but if you look at the drawing from Ciril(first picture in ebay), 65mm is the height including the shower drain. 50mm is the right height,
4. See answer 3. The shower pan needs to be pushed under the toilet (it overlaps 10mm), this was not possible because the height of my new pan is 65mm instead of 50mm.
5. I used some random indoor glue from the DIY store and put some water boxes over night in the pan.
You are right, 1.4301 and V2A are german names for 304.
Old 07-22-2019, 09:18 PM   #8
grozier
This is a great development, especially for the poorly designed Euro pan (no side supports). A few thoughts:
- From what I can see, the drain is in the right location. If anything, the hole in the floor for our drain might be bigger than the Euro hole (larger drain) so there is more tolerance of a difference in position. And really, if you're doing this kind of surgery, moving the hole if necessary is no big deal.
- The steel will be cold and slippery. Using some sort of mat would be essential.
- Again, the biggest challenge for US people is shipping. Depending on the airline, this thing may incur an oversize baggage fee. Honestly, flying over and making a trip out of it might well be the most affordable option!
Ted
grozier is offline   Reply With Quote
Old 07-28-2019, 06:23 AM   #9
hoflix
After reading volumes about the shower pan mods, I decided to skip all that and just use the existing pan, with no modifications to the drain or anything.
Here's my setup. See attachment, I can't figure out how to insert pics in-line.
The cassette toilet is wall-to-wall exactly, it basically sits on the edges of the pan.
hoflix is offline   Reply With Quote
Old 07-28-2019, 12:39 PM   #10
Kiltym
Links are not working.....
Kiltym is offline   Reply With Quote
