Old 05-03-2019, 02:17 AM   #81
alexk243
KulAdventure
alexk243's Avatar
Default Re: 2004 T1N Mountain Bike Van Build
Originally Posted by Midwestdrifter View Post
Your going to need moderator help, as your posts older than 24 hours will be locked from editing. It is a big time consumer to do, so its a hard call.
Ok, I was able to go back and edit URLs and links... should be better. Let me know if you guys notice anything like bad links or missing pictures.
2004 T1N Passenger 140" (Conversion in Progress - Build Thread)
My Website/Blog with Projects and Write Ups on my Van
alexk243 is online now   Reply With Quote
The Following User Says Thank You to alexk243 For This Useful Post:
Midwestdrifter (05-03-2019)
Old 05-05-2019, 03:28 PM   #82
Garandman
Garandman's Avatar
Originally Posted by alexk243 View Post
Got the P0336 code and a hard start, so figured before I go on my next trip I may want to just replace the crankshaft position sensor. I had it already as it was part of my spare parts kit (write up on spare parts kit here).
Thanks for posting this, want to carry the hard-to-get-on-the-road parts so Im not stuck waiting for an order.
2006 Sprinter 118 ~ 16 Rial Transporter rims ~ 235/65x16
Old 05-08-2019, 11:51 PM   #83
alexk243
KulAdventure
alexk243's Avatar
No problem, going to try and keep updating the list when I add more to it. I have had a few breakdowns on the road and its really nice to be prepared for it.
Old 06-13-2019, 03:40 PM   #84
alexk243
KulAdventure
alexk243's Avatar
Originally Posted by bcman View Post
I'm not sure how much of a threat Legionnaires' disease really is, but it's worth looking in to for any water stored above room temperature. https://en.wikipedia.org/wiki/Legion...onella_control
You might be able to chemically treat the water with chlorine, especially if you're not using it for drinking.
What concentrate/amount of bleach would you add to a 20 gallon water tank to refer it safe?
Old 06-14-2019, 05:54 AM   #85
ranchworld
'06 158 2500 Passenger
Using bleach to purify water is common in Mexico and parts south.
From the EPA; https://www.epa.gov/ground-water-and...drinking-water
From the CDC; https://www.cdc.gov/healthywater/pdf..._Flyer_508.pdf
Manuals and Service Documentation: http://diysprinter.co.uk/reference , Thanks to Jens Moller and Arnie_Oli
ranchworld is offline   Reply With Quote
The Following 3 Users Say Thank You to ranchworld For This Useful Post:
alexk243 (06-14-2019), Midwestdrifter (06-14-2019), SD26 (06-14-2019)
Old 06-14-2019, 03:34 PM   #86
alexk243
KulAdventure
alexk243's Avatar
Thanks! The EPA link had this chart for anyone else wondering:
So for 20 gallons of water the EPA says 6ml of bleach, the CDC says 15ml of bleach (if water is clear). So between 6-15ml of bleach for 20 gallons. Since this water is not for drinking and only for showers/sink I will most likely learn towards the 15ml or more to prevent bacterial growth in the tank (since it may be heated to 90 degrees F).
Old 06-14-2019, 08:25 PM   #87
ranchworld
Make sure the bleach is just plain bleach, not "low splash" or "scented".
The Following 2 Users Say Thank You to ranchworld For This Useful Post:
alexk243 (06-15-2019), Midwestdrifter (06-14-2019)
Old 06-24-2019, 06:48 AM   #88
Cwhite87
Awesome Write up thanks for taking to time to do so and share your ideas..
Cwhite87 is offline   Reply With Quote
The Following User Says Thank You to Cwhite87 For This Useful Post:
alexk243 (06-26-2019)
