Old 11-07-2013, 02:54 AM   #1
pacman_34
Default Sprinter Specific Tools
I've needed specialty tools to remove stuck injectors, broken glow plugs, and to install timeserts for stripped injector bolts. I've found that its easier and probably cheaper to buy these tools than to rent them.
Injector puller. Did its job perfectly. Bought on ebay for $60 shipped.
http://www.ebay.com/itm/331019205374...84.m1497.l2649
Injector Bolt Timesert Kit. Around $100 if I remember correctly. Worked Perfectly
http://www.timesert.com/html/misc.html
Its the M6x1.0 Extended kit
Broken Glow Plug Kit. I have not used it yet.
I bought this glow plug removal kit on ebay instead of renting it. It cost me around $120 shipped.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=251366756425
here is the link on how to use it.
I think this would be a good thread to list sprinter specific tools, where to buy, and to review if they worked or not.
pacman_34 is offline   Reply With Quote
The Following 6 Users Say Thank You to pacman_34 For This Useful Post:
Aqua Puttana (11-08-2013), dickknapp (11-07-2013), glasseye (11-07-2013), hardy (06-17-2014), MillionMileSprinter (11-24-2013), Oilburner (11-08-2013)
Old 11-08-2013, 12:11 AM   #2
Default Re: Sprinter Specific Tools
Good info.
I agree. There's some information already in the thread below, but not specific descriptions and reviews. vic.
http://sprinter-source.com/forum/sho...ighlight=tools
Old 11-13-2013, 07:43 PM   #3
pacman_34
MILLER TOOL 9543 COMPRESSION TEST ADAPTER 2.7L DIESEL on ebay. Paid around $25
http://www.ebay.com/itm/MILLER-TOOL-...831f82&vxp=mtr
Very useful. I tried to do compression tests but couldn't read the gauge i used effectively. This however worked perfectly for leak down test. Used a ratchet on the crankshaft bolt and pressurized each cylinder. This allows you to determine if you have bad rings, cracked piston, bad valves etc.
Sealey Diesel Glow Plug Socket Set 4pc 3/8"Sq Drive. Paid around $32 on ebay.
http://www.ebay.com/itm/121201372964...84.m1497.l2649
I haven't used it yet but I think it would come in handy if needed.
Old 11-13-2013, 11:46 PM   #4
NetDoc
NetDoc's Avatar
Good stuff! I love buying tools.
Pete 'NetDoc' Murray
2005 Freightliner 2500 140"
www.ScubaBoard.com
Solo otro día en el paraíso!
Mechanics always start what they finish!
NetDoc is offline   Reply With Quote
Old 11-24-2013, 09:11 AM   #5
wooffi
wooffi's Avatar
Default
Great post, thanks. I also had to purchase the injector puller, but got and original from the UK. I guess the Chinese copy works as well. Either way a great tool, forget the Miller fork and slide hammer, they may work for newer sprinter models but not for my 2003 one.
I ran into this post looking for the stripped hold down bolts, mine seem to have had either already an insert in it that stripped when I tried to tighten them or I just messed up.
Either way, thanks for the link, $102.00 it was however on the time sert no cheaper copy for that tool.
Wolfgang
2003 Dodge Sprinter 2500 Cargo Van
OM 612 LA CID 164 (sold for scrap) by by Sprinter
1997 Isuzu Rodeo (still running)
2017 RAM ProMaster Cargo Van
Off the Grid Solar Home since 1990.
1900 Watt panels, 4KW Xantrex Inverter
24 Volt Forklift Battery Bank 1500 AMPH
4 KW Kubota Diesel Backup Generator
(Any questions about this ask!)
wooffi is offline   Reply With Quote
Old 07-07-2014, 12:31 AM   #6
pacman_34
I purchased the otc 6735 tool set from amazon to remove the ball joints on 02-06 sprinters.
http://www.amazon.com/OTC-6735-Joint...ter+ball+joint
This tool works perfect to get the knuckle off the lower control arm. It will not work to get the ball joint out. I cut a 2-3/8" fence pipe and used that in a shop press to get the ball joint out and press the new one in.
Overall the tool was worth buying because I couldn't remove the knuckle with anything else.
Old 11-17-2014, 02:42 AM   #7
pacman_34
Just purchased the tool set to swap out the alternator pulley. Paid $40 on ebay.
http://www.ebay.com/itm/13pc-Alterna..._Tools&vxp=mtr
Old 11-27-2015, 05:27 AM   #8
misterbond10
misterbond10's Avatar
This one is extremely important for those tough repair jobs, I highly recommend it:
http://www.ebay.com/itm/261569101502...502%26_rdc%3D1
2006 Dodge Sprinter 2500, 140" WB, OM647 Engine 2.7L
misterbond10 is offline   Reply With Quote
The Following 2 Users Say Thank You to misterbond10 For This Useful Post:
IMAC (03-16-2016), krisinak (01-05-2016)
Old 11-27-2015, 02:12 PM   #9
I can review this one.
Extremely useful.
Caution!!!
Improperly applied it can get you deeper into trouble quicker than it will get you out of it.
Old 11-30-2015, 09:35 PM   #10
NetDoc
NetDoc's Avatar
if this one doesn't work, try this one...
[spoiler][/spoiler]
www.ScubaBoard.com
