Go Back   Sprinter-Forum > Miscellaneous > Test Area
Test Area Place to develop your Forum skills.
Old 08-13-2017, 02:51 AM   #1
Dmenegus
Default New Stereo Install - Power Issue
Hi there, I'm new to this forum as I just purchased my first Sprinter, a 2007 Dodge Passenger 170WB. Recently I purchased a Pioneer DEH-X6800BS replacement stereo and a Scosche VW01B harness kit to replace the basic factory radio. After I hooked everything up, I could not get power to the unit. I called the audio shop that I purchased the equipment from and they said it should work. After looking online, I saw some posts about he 2007 models possibly being different than others and some other posts where the pins on the harness had to be moved. Not sure what to do. The wiring seems fairly simple and I've double checked everything. Any ideas? Thanks. David.
Dmenegus is offline   Reply With Quote
install, issue, ncv3, stereo, wiring
