#1 |
06 T1N Can
Is anyone using a browser that is NOT IE (Internet Explorer)?
If yes, can you please... ...clear your browser cache. ...delete your cookies. Log into Sprinter-Forum, and click on the link below... http://sprinter-source.com/forum/showthread.php?t=543 Do you see the 1st picture or do you see something similar to this?... Name: DSCF0002.JPG Views: 88 Size: 69.5 KB Packed up and ready to go. I can't see the photo unless, I right click it and choose view image (it'll ask me to log in), I relogin, see the picture, and every thread thereafter, I will be able to see images. Essentially, I have to log in twice if the cache or cookies are cleared. Thanks, Seek |
#2 |
Happy Little Vegemite
Hi Seek this happens on fire fox as well its common though I found it usually happens when the server is busy
![]() Richard
![]() ![]() AU..Tasmanian time ![]() There is a peaceful solution.It's called a peace Revolution. No Shalam - No Shalom Now lets take back the - Sprinter-Forum. Of course I'm being totally biased.
Driving my life Away in a 313 Cdi Mercedes-Sprinter |
#3 | |
06 T1N Can
![]() Quote:
![]() This is actually not good. I've tried on konqueror (linux), mozilla (linux), and firefox (xp) and they all exhibit it. Only IE6 doesn't do it. It should not be the server, because there's not enough people online to cause this to happen and we have a lot of bandwidth. I'm trying to get some help from vB on this issue. Thanks, Seek |
#4 |
2005 140" low roof
well, I'm not the admin ;-) so here's what I see:
happens in safari and firefox OSX Cheers George
2005 316CDI Graphite Metallic Low Roof 140" wheel base passenger van, VW Multivan T5 floor-group and seats with aluminum tracks, Aluminum galley with fridge microwave and sink, 2 Powersonic 75AH gel-cel, Xantrex XM1800 Inverter, 18" G-Wagen "Ashtaroth" wheels Cooper Discover H/T Plus 265/60 R18, Koni red shocks, MaxxFan Deluxe.[SOLD June 2013] http://sprinter-source.com/forum/sho...+camper&page=6 Last edited by georgetg; 02-23-2007 at 11:04 PM. Reason: added browser |
#5 |
06 T1N Can
Thanks George:
You have to log in though. I don't see you logged at the upper right... Looks like this... view.jpg The picture is suppose to show up, but it doesn't. Only the stats show up. Thanks again, Seek |
#6 |
Example if you put in one photo or four separate photos from attachments
as photo one indicates these will some time not show up as a photo but as the reference to it as Seek has showed. If you use the latter from attachments insert all they are not an issue unless there a five of them the last sometimes does not appear but the reference to it does remain so right click to view. It seems to appear when some one else is replying to a thread elsewhere on the forum sending say the message or with an attachment, then the server slows down This happened last night I saw it as I use triple computers at work for separate purposes I just happened to have two of the three on to the same link, one showing who's on line the other was showing todays posts. The system slowed on sprinter source I also noticed six spider bots viewing attachments on postings as well. One of my servers was running explorer beta 7 , the other running Firefox with turbo boost. Jut to add to the confusion ![]() 400px-Skull_and_crossbones.svg.png example one.jpg example 2.jpg RichardAttachment 1190 Attachment 1193
Driving my life Away in a 313 Cdi Mercedes-Sprinter Last edited by Altered Sprinter; 02-23-2007 at 11:24 PM. |
#7 |
2005 140" low roof
ok now I know what you are talking about...
logged in, this is what I get: click on the icons reloging and everything is good... could it be a clock/time issue? I've seen this with other vB forums Cheers George
2005 316CDI Graphite Metallic Low Roof 140" wheel base passenger van, VW Multivan T5 floor-group and seats with aluminum tracks, Aluminum galley with fridge microwave and sink, 2 Powersonic 75AH gel-cel, Xantrex XM1800 Inverter, 18" G-Wagen "Ashtaroth" wheels Cooper Discover H/T Plus 265/60 R18, Koni red shocks, MaxxFan Deluxe.[SOLD June 2013] http://sprinter-source.com/forum/sho...+camper&page=6 |
#8 |
06 T1N Can
Thank George!
![]() Hmmm, it's a problem with other vB forums, huh. I was thinking it might be a cookie issue where only the second cookie setting decides on whether you see the inline images. I guess I gotta go complain to vB. Seek |
#9 | ||
06 T1N Can
![]() Quote:
Another is if you do NOT insert pictures as [attach]number[/attach], and let the forum insert the pictures after your text, then you will not have any problems seeing. Most of George's posts/threads are like this so I can see the pictures without logging in the 2nd time. Quote:
Thanks, Seek |
#10 |
Hi seek
I run three PC's at once quite often, information guru ![]() If for instance last night, yesterday there were six spiders on the prowl one was viewing attachments two members and one was writing a reply on my end I used another PC to see what was being posted as the server at your end blimps momentarily in less than a half second. The thread was indicated on todays post as sent through for all to view OK. Sometimes the forum slows right down and it is slow to respond between photos or say switching from post to post in browsing, between the forums. This is not because my system has a heavy use on the Mbps because of community use in my area as if I switch to another forum! Whatever say blog one and blog tow it's running at the normal response times. There have been the odd time outs where it did not go to another program on our sprinter-source forum, this can mean an issue at your end with server speed, in peak period or whatever. It can also mean slow response flickering on the screen from my end means you may have a corrupt spy testing your box to see how strong it is before breaking the code to get into it. This also is exactly what happened with another program in Canada using the same sytem you have and it was crashed, slowed down in the same manor as from What I was viewing last night, of course this is from this end, and your sytem should be showing speed downtime and or security alerts as to a possible bug issue or hacking going on. But it's a thought just that. as to how I've viewed an attacker doing it looking in. PS My system runs dual servers in series as to other uses, no comment on that, so speed and downtime is not an issue with me as Iknow what is being maintained and if I have a possible attack on the system at this end, virus well they go with the day and they get sorted anyway. Again a possible thought no way of supporting the theory bit it has happened. Richard
Thread Tools | |
Display Modes | |
