Supplier Info, Reviews, and Experiences Got suppliers? List them here. |
#11 | |
2003 T1N 316CDI LWB
![]() Quote:
Quote was for 100" (2.5metre) lengths. I might go and have a look at sail track. It's readily available and much more reasonably priced (despite the 'marine' tag). Anyone use this in their Sprinter? [Sorry for getting off topic]
Geoff Last edited by geoffs; 10-29-2011 at 12:55 AM. Reason: Sail track |
#12 |
I took a look at Harken and Ronstan before I did the L Track as posted above. Here in California the sailing gear was much more expensive.
The aircraft quality L track (2) 48" sections, drilled w/ stainless mounting bolts and nylon locking nuts were about $90 including shipping and 4 quick release fittings. http://www.car-truck-accessories.com/coretrax.asp
Mrdi 2008,2500, 144 Hi Cargo Surf City USA, Southern California Last edited by Mrdi; 10-29-2011 at 05:25 AM. |
#13 |
Happy Little Vegemite
![]() ![]() AU..Tasmanian time ![]() There is a peaceful solution.It's called a peace Revolution. No Shalam - No Shalom Now lets take back the - Sprinter-Forum. Of course I'm being totally biased.
Driving my life Away in a 313 Cdi Mercedes-Sprinter |
#14 |
A few L-track questions for Rob:
I see you have end caps for the flanged track. Do you have end caps for the angled and recessed track? If not, can the puck from the single stud fitting kit be cut in half to make an end cap for the angled track? Also, while researching this, I realized that in aircraft, the track between the rows of seats is covered with an extruded rubber cap. There is actually a Boeing part number for this, but I do not know what it is, and it probably works only with the flanged and recessed track. Since this is going on the bottom of the window in my passenger van, I'd like to cover the stretches of angled track that aren't in use. Any solutions? Sean
2006 Dodge T1N 158" Tall Roof Passenger Wagon w/Rear AC Last edited by seans; 11-08-2011 at 12:07 AM. |
#15 |
2003 T1N 316CDI LWB
Still looking for an affordable L-Track solution and came across some aluminium extrusion similar to the 80/20 product but, in Australia at least, a lot cheaper. It's also available in the US.
Here's the specs: At 16mm thick, it's a little thicker than LTrack. Cost for a 6metre length is $A124.
Geoff Last edited by geoffs; 11-21-2011 at 04:46 AM. |
The Following User Says Thank You to geoffs For This Useful Post: | owner (11-29-2011) |
#16 |
In Oz, this place has some L-track type extrusions...
![]() Lots of connectors and joiners too. Even has an online store, that particular profile above is $140 for 6 meters. http://www.australiseng.com.au/prodd...LS.084.102.001 |
#17 | |
2003 T1N 316CDI LWB
![]() Quote:
Geoff |
#18 |
Sean,
We currently sell a plastic filler strip that can be cut into sections that will snap into the unused sections of track. The roll is sold in 25' rolls here is the link http://www.cargoequipmentcorp.com/Wh...p/fe200751.htm As for the end caps, our 8663 end cap (only one we stock) will work with the recessed Fe751 series track. http://www.cargoequipmentcorp.com/Se...ngs-p/8663.htm The puck will not pair well with with any of the L track styles available. We have been looking into different style end caps but nothing set in stone as of yet. |
The Following User Says Thank You to Strapman For This Useful Post: | seans (08-15-2013) |
#19 | |
![]() Quote:
~Darin K~ 2013 2500 Mercedes Crew Van 170in high roof White stock color with black painted steel rims |
#20 |
Anyone still watching this thread? I want to put L-Track on the walls of my 2014 Sprinter 3500 Ext, but nobody seems to make an L-Track with the right dimensions.
This one from Rob's biz is almost right, but instead of a 1/2 inch rise up to the flange, I need about 1/8 of an inch maximum: http://www.cargoequipmentcorp.com/L-...51-100-pd4.htm (Need 1/8 so the flange will still squeeze and hold down the plastic wall pieces in place.) Or, I could make something like this work, if it were 2 inches wide instead of only 1.25. - http://www.cargoequipmentcorp.com/L-...50-100-pd4.htm Take my money, someone, please! Need to find the right track though. |
The Following User Says Thank You to RIDESprinter For This Useful Post: | jdemers90 (08-21-2017) |
Thread Tools | |
Display Modes | |
