Closed Thread
Old 10-15-2009, 07:47 PM   #1
bikergar
bikergar's Avatar
Default Assyst reset and results
This locked thread is for displaying actions and results when delving in the reset screens and menus. I will start another thread for suggestions and reporting results (Suggestions and Results for Reset Assyst). It is for vehicles with and without steering wheel buttons.
When entry into the screens is discovered for vehicles with steering wheel buttons I will post it.
I would caution all that the results of actions we take while in these screens is for the most part unknown to us at this time. We are all TEST PILOTS. BEWARE!!!
1. Put the key in the ignition and switch it on without starting the engine.
2. The ASSYST mileage will show, when the mileage shown returns to the vehicle mileage, hold the O button down till you hear a beep (could take a while)
3. As soon as you hear the beep, press the M button repeatedly and a number of reset menus will appear. Select "reset 51" (don't know what the other reset menus are for)
4. At reset 51 press the O button until a number 2 appears, release the O button, then press it twice and the LCD should show "display reset done"
Keep Doing What You Did, and You'll Keep Getting What You Got...
2008 2500 CRD 144 inch High Roof Crew Van
bikergar is offline
The Following 20 Users Say Thank You to bikergar For This Useful Post:
boardster (10-15-2009), Bobnoxious (05-18-2016), Dan Holm (03-28-2010), djmadore (04-19-2010), D_Rhynard (02-28-2010), Fulcrum (04-26-2012), HappyFamilyVan (02-22-2010), Hikinginpdx (04-02-2010), JohnY (02-06-2013), Kat (10-10-2012), Kitemaui (12-09-2011), lgalko (03-30-2011), maher01 (05-05-2010), MichaelsES (04-10-2010), Micktesla (02-22-2012), roadrunner158 (08-11-2010), shanemac (02-20-2010), stevenz (05-12-2016), twinndub (01-26-2011), vantastic adventure (12-14-2016)
Old 10-18-2009, 04:42 PM   #2
bikergar
bikergar's Avatar
Default Re: Assyst reset and results
Still no joy on vehicles with steering wheel buttons, but several members continue to work on this issue. If there is a way I feel confident they will find it.
bikergar is offline
Old 10-19-2009, 08:58 PM   #3
bikergar
bikergar's Avatar
We need some help on this screen issue also.
bikergar is offline
Old 10-20-2009, 06:23 PM   #4
bikergar
bikergar's Avatar
Default Compare...US vs Canadian models
Thanks go to member March for taking the time to post the Canadian pictures.
There are differences in some of the screens and other than volt, fuel icon, and oil quantity screens no one knows why …Yet
Still waiting to hear from our European members.
US vehicle man date Mar 2008
CAN vehicle man date Oct 2007
bikergar is offline
Old 10-22-2009, 03:28 PM   #5
bikergar
bikergar's Avatar
bikergar is offline
Old 02-10-2010, 01:34 AM   #6
bikergar
bikergar's Avatar
Thanks to HappyFamilyvan for this as of know untried ASSYST reset for vehicles with steering wheel buttons.
High line cluster Workshop Menu access
–Ignition “on”
–Arrow button up until “Service scope in XXX”appears
–Press “O”button on IC and hold, release after the beep
–Press lower left steering wheel button “Menu back”once
Stop here if you want only the work sope menus
otherwise continue ....while still in the Worksope menus...
–Select “Service scope in XXX”with arrow buttons
–Press “O”button on IC, menu “To be Done" appears
–Select “Compl Serv”using + and –buttons
–Confirm with upward arrow (used as enter button)
–“Oil Type”menu appears:
•Select 229.31 or 228.51.....229.51 is not an option
•Confirm with upward arrow button
–Press “O”button on IC for 3
bikergar is offline
The Following 7 Users Say Thank You to bikergar For This Useful Post:
EBH (07-20-2013), ebnelson (12-29-2012), gadibbleiii (04-06-2010), HappyFamilyVan (02-22-2010), jb-eng (05-28-2010), sabardell (11-16-2010), Tundra168 (02-21-2010)
Old 02-22-2010, 04:06 PM   #7
bikergar
bikergar's Avatar
Thanks to HappyFamilyvan for more information and pictures about Sprinters with steering wheel bottons.
bikergar is offline
The Following 3 Users Say Thank You to bikergar For This Useful Post:
jb-eng (05-28-2010), puzoter (04-17-2012), sabardell (11-16-2010)
Closed Thread
