Old 08-08-2015, 03:17 AM   #1
FloJoSprinter
Question Tire suggestions? I'm a Newby
Any suggestion for tires for my recently purchased 2008 Pleasure-Way Ascent TS. I will use it as everyday driver but need tires that will travel well in all weather & conditions for long vacation trips. Currently the tires are the orginal Continental Vanco 4 Season. Yep they are 8 years old but only 15,000 miles. Just not confortable with how old they are even tho I have been told they still look good. Thanks for the help.
FloJoSprinter is offline   Reply With Quote
Old 08-08-2015, 03:41 AM   #2
sailquik
sailquik's Avatar
Default Re: Tire suggestions? I'm a Newby
FloJoSprinter,
Get the Michelin LTX MS2 tires in the 245/75R16 Load Range E size.
Here's Mfg's suggested tire size per the Tire Rack.com website for a 2008 Dodge Sprinter 170" wheelbase:
Original Equipment Wheel Diameter: 16"
245/75-16
Load Range E
The Michelin LTX MS2's are pricey, but these tires provide the best overall traction in all conceivable traction situations
and they have at least a 60,000 mile tread wear warranty.
I have dual chains for winter driving, but have never had to use them since I put Michelin LTX M/S2 tires on my Sprinters
(2010/2011/2012/2014).
I've done several hundred miles in snow without any problem.
Hope this helps,
Roger
2019 Sprinter 519/907/VS30 series (3500 DRW) 170"/4325 mm wb Hi Top Short Back
OM-642 3.0 liter V6/7G-Tronic, 7 Speed manually shift-able transmission.
OEM back up camera, LED light package, fog lamps,
Had 2014 516 OM-651 I4/7G-Tronic|2010 NCV3 519/3500/144|2011 & 2012 NCV3 519/3500 170
2006 T1N 3500/158
The Following User Says Thank You to sailquik For This Useful Post:
FloJoSprinter (09-04-2015)
Old 08-08-2015, 06:44 AM   #3
3mbusa
What he (Roger) said. We have the Michelin LTX MS2 on our 2013 MB 3500/Pleasure-Way and they are super -- improved the handling noticeably.
MB Sprinter 3500 2013 Pleasure-Way Plateau TS, 2009 Mercedes E350 Wagon, 1999 Mercedes SL500
3mbusa is offline   Reply With Quote
Old 08-08-2015, 02:48 PM   #4
Aggie
2010 Roadtrek SS Ideal
Replaced my Continentals this spring with Michelins, 6000 miles since and have no faults. An earlier thread on this topic warned that the Michelins hold gravel in grove till thrown off at high speed. I noticed this but maybe wouldn't have if someone else hadn't pointed it out. Haven't had snow or mud experience but did have lots of rain and wet road conditions with no noticeable lack of traction.
Aggie is online now   Reply With Quote
Old 08-08-2015, 09:32 PM   #5
bl_smith25
I'm on my second set of Michelin LTX tires. The first set was the original that came on it and they were the M/S. I drive mine daily and they lasted great for almost 9 years. It was time to replace them and I again chose the Michelin LTX but this time, the M/S2 was the replacement since the original wasn't made anymore. They're great and from other owners reports, you'll notice a big difference going from the Continentals to the Michelins. Everything from more stable to a quieter ride and longer lasting apparently. I'm glad mine came with Michelins and I would not change them to anything else.
B.L>
2006 PW Plateau
2005 3500 Cargo
2.6L 5cyl OM647
Brooklet, GA
bl_smith25 is offline   Reply With Quote
Old 08-09-2015, 12:14 AM   #6
FloJoSprinter
Wow Thank you everyone! I have been taking sneak peaks at other Sprinters and noticed majority are using the Michelins. Looks like I have found a winner. Thanks again!
Old 08-09-2015, 01:03 AM   #7
boatmangc
I have used both Kumho and Michelin in South Florida so I have nothing to offer about ice/snow. However, on my T1N I did an experiment using A pair of Kuhmos and a pair of michelins . Equal wear on each pair, regular rotation the Kumho is an equal in my heavily loaded application. For roughly 50% less initial cost it's a no brainier for me.
My new 2015 came with the Kumhos as original equipment
boatmangc is offline   Reply With Quote
The Following 2 Users Say Thank You to boatmangc For This Useful Post:
FloJoSprinter (08-09-2015), NelsonSprinter (08-09-2015)
Old 09-01-2015, 08:26 PM   #8
FloJoSprinter
I finally saved the money and purchased the Michelin LTX M/S2 tires. Now the questions are... 1) I seem to get more slight swaying or fishtailing like feeling and is this because of the new tires tread? 2) They filled the tires in front with 47lbs. and rear with 70lbs. I'm being told by "others" to make sure all tires are at 70lbs. I'm a bit confused with all this?? Sorry but I can't seem to find much in the forum about this. Then again
I am such a newbie. Thanks for any help & suggestions.
Old 09-02-2015, 06:08 PM   #9
bl_smith25
The tires are too low. Look on your drivers side door sticker for the correct tire pressure.
The back should be at 80 and the front about 55 or so. Your numbers should be similar.
You'll get a little squirelliness at first, but it wears off quickly I found on mine.
Also, if you have air bags, make sure they're properly inflated, but right now, it sounds like your tires are too low.
B.L>
2006 PW Plateau
2005 3500 Cargo
2.6L 5cyl OM647
Brooklet, GA
Old 09-02-2015, 07:52 PM   #10
FloJoSprinter
Thanks for your reply bl smith25. the inside door says 70 rear & 47 front. Visually they look a bit low. As for the airbags I have them set to 50lbs for daily driving & for trips I'm guessing we inflate them
so the rig is level after everything has been added (cargo tray bikes clothing water (1/2 tank) diesel lpg)? Any knowledge to share about the airbags would be great appreciate.... Thanks again :-)
