Go Back   Sprinter-Forum > Classifieds > For Sale (Sprinter vans Only)
For Sale (Sprinter vans Only) Post Sprinter Vans for sale here. Vans must be driveable, otherwise, they go to the parts section here.
Old 11-29-2017, 02:44 AM   #1
2011SprinterCamper
Arrow 2011 Fully Converted Tiny House Sprinter 170WB High Roof (Portland, OR)
2011 Mercedes-Benz Sprinter Van 2500
High Roof, 170" WB
V6 Turbo Diesel Engine
Freightliner White Cargo Trim
Odometer 242000 miles
This custom up-fit RV conversion featuring bright wood throughout is cozy and spacious. I built a comfortable home for an extended national park adventure. This Sprinter is now an ideally equipped RV for weekend camping or full-time living. The up-fit is insulated and features pine wood panel, hardwood floor, recessed lights, sprung queen bed frame, large drawers, aftermarket windows, running water, ventilation, refrigerator, wall storage, curtains, and an isolated house electrical system. With the option of using any favorite extra-thick queen size mattress, you may sleep on the most comfortable bed in the campground.
The countertop accommodates a standard Coleman two-burner propane stove. The sink pumps cool water (no hot water system) from a fresh water jug into the grey water jug. A spare fresh water jug also fits under the sink. The house electrical system was designed and wired by an electrical engineer. Its large battery keeps a fridge running and lights on for days between charges. The house battery will fully recharge off the van’s alternator with just 2 to 4 hours of driving. Shore power may be used when hookups are available. The interior build out was completed March 2017 and has been well maintained.
Traveling long roads is a breeze with the powerful and reliable Mercedes diesel engine. In addition to being more fuel efficient, diesel engines are expected to last twice the milage of gasoline engines. This vehicle is in excellent mechanical condition with recent oil change and service performed by Mercedes authorized shop. A previous owner preferred the Mercedes logo and swapped the cargo van front grill for a black Mercedes-Benz grill. The steering wheel and rear door feature Freightliner badges. This Sprinter has a clean Oregon title and good plates. No accidents or damage has been reported in its history.
Materials:
Rigid Foam Board Insulation in walls and ceiling with spray foam insulation to fill gaps
Pine Wood Panel on walls and ceiling sealed with water based Minwax Polycrylic
Six Recessed LED Lights in ceiling controlled by light switch on wall
Hardwood Laminate Floor installed on underlayment, subfloor, weather barrier, and insulation
Queen Bed Frame is sprung on Lonset slats to support any 60"x 80" mattress
Two Large Drawers under rear bed slide out and lock shut
One Giant Drawer under front bed rolls on wheels and locks shut
One Medium Drawer under front bed rolls on wheels and locks shut
Two Storage Hammocks and Three Coat Hooks on wall
Large Side Window, on sliding door, privacy glass, T-vent with bug screen, CR Laurence
Two Rear Windows, on both rear doors, privacy glass, CR Laurence
Powered Ventilation Fan in center of roof, Fan-tastic Fan, airflow with side window vent open
Counter Top, butcher block 20"x 56"
Sink, 12"x 10" x 6"
Electric water pump, 1.2 gallons per minute, pressure activated, with power switch, Seaflo 21 Series
Refrigerator, 12V Efficient, 18" x21" x25", Range -8F to 50F, EdgeStar FP430
5gal fresh water (x2)
5gal gray water (x1)
Baskets and Spice Rack and mounted on the kitchen wall
Two Small Storage Drawers, in cabinet under sink
Larger Storage Shelf, under counter top next to cabinet
Below Shelf Storage with curtain, porta potti curve, securely fits out of sight
Privacy Curtains cover rear windows, side window, and driving cabin partition
Stereo Head Unit Upgrade CD / USB / AUX / Radio to Pioneer DEH-X2900UI
Black Leather Wrapped steering wheel
Light Grey Carpet in Front Cabin for driver and passenger
Rear View Backup Camera, screen turns on when shifted into reverse
Windshield Sunshade is great for added insulation and privacy
Hydraulic Jack and Tire Iron original tools in compartment under passenger footwell
Spare Tire is mounted under vehicle
Owner's Manual is included
Towing Capacity 5,000lbs
Recent Oil Change and Service good for 10,000 miles
V6 Turbo Diesel Engine for power and endurance
Diesel Fuel can run better than 20 mpg
26.4gal fuel tank 500+ miles between fill ups
Rear Wheel Drive
Length 23'
Height 9' 3”
Interior Height 6’ 3"
Electrical System Specs:
200AH House Battery 12V sealed AGM, deep cycle, size 4D, PS12-230
150A Battery Isolator, for alternator power, 125A / 150A peak, WirthCo Battery Doctor :: powers house while engine is on
600W Inverter, pure sine wave, 12V battery power to 120V AC, duel outlets, 1200W surge, Power Tech-On PS1001
55A Converter, 120V shore power to 12V DC, PowerMax PM3-55 :: powers house when plugged in to shore power
15A/120V Shore Power Inlet, use standard extension cord to plug in
Surge Protector with six 120V outlets (converter uses one) wired to shore power inlet
Ammeter / Multimeter displays voltage (V), current (A), and power (W)
Battery Life Voltmeter displays the remaining percentage of house charge
Three Inline DC Circuit Breakers for house battery, vehicle battery, and the inverter
12V DC Fuse Box for low current DC systems:
Four USB Outlets, 5V DC-DC converter
One 12V Wall Outlet (for fridge)
12V, 0.75A Fridge (runs 15-20mins each hour to maintain temp)
12V, 0.80A Water Pump (pressure activated by handle turn)
12V, 0.85A LED House Lights (six recessed in ceiling)
12V, 1.3A / 1.9A / 2.6A Ventilation Fan (three speed)
Pictures are located in the attachments.
You may also visit the Craigslist post to see all 24 pictures:
https://portland.craigslist.org/mlt/...454459531.html
Please email Kevin to arrange a meeting or ask a question.
I am located in Portland, OR. Inquire about delivery.
2011SprinterCamper@gmail.com
Last edited by 2011SprinterCamper; 01-10-2018 at 02:53 PM. Reason: craiglist post url update
2011SprinterCamper is offline   Reply With Quote
Old 12-02-2017, 07:02 AM   #2
2011SprinterCamper
Default Re: 2011 Fully Converted Tiny House Sprinter 170WB High Roof (Portland, OR)
Price dropped to $37,000
Old 02-01-2018, 07:14 AM   #3
2011SprinterCamper
Reposted for 2018. This van is still on the market.
170, 2011, conversion, high roof, sprinter camper
