Go Back   Sprinter-Forum > Sprinter-Based RV's & Conversions > Sprinter-Based RV Brands > Leisure Travel Vans > Serenity
Old 07-26-2017, 02:10 PM   #1
jolderco
Default Refrigerator Cooling
Dometic Help
2014 LTV Serenity. Dometic Refrigertor having problems cooling with gas only, works well with 110V. I have cleaned vent, burner, orifice. Getting a flame. The flame seems to start fine when it should...just hardly cools at all. With the 110 working well I feel the refrigeration system is working, must be something with gas, strength of flame?
Any thought appreciated.
jolderco is offline   Reply With Quote
Old 07-26-2017, 05:02 PM   #2
icarus
Default Re: Refrigerator Cooling
Check the gas pressure at the oriface with a manometer. Should be 11-13" W.C. Ensure that the flame is crisp, blue, even and steady. Remove the baffle, clean the baffle and the flu.
You are right, if it cools well on 120 vac it should cool even better non L/P. Gas is it's best mode.
Icarus
Old 07-26-2017, 05:30 PM   #3
jolderco
If the pressure is low, I assume it needs new regulator, do you have link to getting one?
Old 09-21-2017, 01:14 AM   #4
Ancote
Ancote's Avatar
Originally Posted by jolderco View Post
Dometic Help
Mine was not cooling good on gaz and couples monts later the prop was missing at the firs 2 minutes so I replace the regulator and every thing is working very good now, fridge is going around 39 -40 on level 3 so it is just perfect now. :
thumbup:
Ancote is offline   Reply With Quote
Old 09-23-2017, 09:51 PM   #5
aljimenez
'13 LTV Serenity on '12 3
aljimenez's Avatar
I just had regulator replaced for this same issue. I had it done at an experienced RV repair shop. I do not recommend changing this yourself unless you are very knowledgeable with propan and gas safety. It only cost me around $100 to have it done.
'13 LTV Serenity on '12 3500
'05 PleasureWay Plateau on '04 2500 before
