Old 01-11-2013, 01:03 AM   #31
416cdi
04 LWB 416cdi T1N OM612
Default Re: Alternator 416cdi T1N
Originally Posted by Oldfartt View Post
Also this.
Cheers
Ross
Very cool movie. Makes me think maybe I can do it too.
I didnt know you could post movies here? Is it just a matter of copy & pasting the link (web address)?
Based in Sydney Australia 2004 High Roof LWB 416cdi T1N OM612 2.7Ltr 5cyl 210,000kms Sprintshift full of rust with double rear wheels, double sliding doors and all options.
416cdi is offline   Reply With Quote
Old 01-11-2013, 01:09 AM   #32
416cdi
Originally Posted by nathanhdunn View Post
416cdi, I've got an electronics trade cert, and have repaired alternators in the past. I could have a look at it for you. How are you at carpentry or shower enclosures?
Cheers,
Nathan
Thanks for the offer Nathan, very kind of you. I appreciate the offer.
My skills are in flooring, carpet, vinyl etc. I do know a shower screen/glazier guy who can help with your shower enclosure.
If you have time this weekend lets catch up. Private message me for details.
Russell
Old 01-11-2013, 01:27 AM   #33
Oldfartt
Oldfartt's Avatar
Originally Posted by 416cdi View Post
Do you happen to know if I will be able to drive my van without the alternator attached? I want to "attempt" removing it but dont know if that means I would be stuck without wheels. At the moment I just charge my battery every night and drive short distances as required.
You can drive it OK without the alternator so long as the battery volts does not drop below about 11.5V as the computers will get confused and throw a lot of codes, particularly when starting. As the alternator is not contributing at the moment and you have been driving the van for short distances now, so long as you charge it up over night you should be fine. Disconnect a battery terminal before removing alternator.
Ensure to insulate the alternator leads after removal.
To insert a web address into a posting just copy and paste it into your posting.
Cheers
Ross
The Following User Says Thank You to Oldfartt For This Useful Post:
416cdi (01-11-2013)
Old 01-11-2013, 03:58 AM   #34
Amboman
You can run a car engine without an alternator but on a Mercedes Sprinter you may be asking
for trouble due to the computer complexity and if it goes into Limp Home Mode it will cost a trip
to the dealer to unlock it, myself i just wouldn't do that, it needs to be looked at by someone
who knows what there doing.
Old 01-11-2013, 10:50 AM   #35
Eric Experience
Eric Experience's Avatar
416.
You must not start the motor without the alternator. You will have no cooling no steering and as other have said you will set a code. There are instructions on here for the alternator removal.it is very similar to the belt change procedure. your brushes should not be worn out at that K's, they are probably just stuck in the holder, a probe hooked under the brush lead can pull the brush back a little from the slip ring and free it up. A spray of WD40 on the brush holder will allow it to move down against the slip ring and if your lucky you may get another 100kKs out of it. Eric.
416cdi (01-13-2013)
Old 01-11-2013, 07:24 PM   #36
Oldfartt
Oldfartt's Avatar
Silly me!
I completely forgot about the drive belt! No you should not run the vehicle without an alternator, going or not going. Eric is right about the brushes possibly sticking. A light tap on the alternator might free them up but the usual cause of sticking is worn brushes.
Cheers
Ross
416cdi (01-13-2013)
Old 01-13-2013, 12:55 AM   #37
416cdi
Im getting some conflicting advice and misinformation from a few guys here saying;
- I can not or should not drive my van with out the alternator.
- If I do so my steering and cooling systems will not work.
- My van may go into LHM (Limp Home Mode).
This may be true for some models of Sprinter but it does not seem to be the case with mine.
I have had no alternator operation (it is still attached) for the last 10 days and I have been driving my van with the steering and cooling systems working as per normal and I have not gone into LHM during this time.
Each night I put my battery on charge and when I do drive somewhere it has only been short distances. If my battery was to be drained whilst driving I have the Jump starter battery pack that I can connect to get me home again.
I am not criticising the advice I am receiving here, I appreciate all your help.
When I get to work tomorrow I may put it up on the hoist and try to remove it then.
Old 01-13-2013, 02:35 AM   #38
Oldfartt
Oldfartt's Avatar
416CDI
If you remove the alternator then the drive belt which runs the fan, steering pump, aircon, etc will not have the pulley to run over and so will not be under tension and therefore will not operate the said devices.
Cheers
Ross
416cdi (01-13-2013)
Old 01-13-2013, 03:57 AM   #39
416cdi
416CDI
Cheers
Ross
Thanks for the clarification.
Old 02-07-2013, 03:55 AM   #40
sparkie
sparkie's Avatar
Any progress?
My stealthy Sprinter!
sparkie is offline   Reply With Quote
The Following User Says Thank You to sparkie For This Useful Post:
416cdi (02-16-2013)
