Old 04-15-2019, 04:18 AM   #11
rpo83
Default Re: Introducing my T1N 316 4x4 :) and her first trip
I have spent a few hours stripping some stuff out of the sprinter...
Yesterday the rear looked like this..
This morning there is a little less clutter
I also removed the acoustic cover to check for black death, she looks great...
Do any of you guys run without the cover? I don't see any real reason to put it back..
The last big decision i need to make is whether i keep the roll cage or cut it out.. It fouls the front seats, limiting their position, and as i found it so uncomfortable on the drive home, i may just remove it...
Cheers
Steve
rpo83 is offline   Reply With Quote
Old 04-15-2019, 05:04 AM   #12
jaahn
Hi Steve,
Lots of suggestions. Here is my improvement to the throttle pedal position I did. Still good years later.
https://sprinter-source.com/forum/sh...ad.php?t=48790
Jaahn
PS I was not able to access any of the latest images above !!
jaahn is online now   Reply With Quote
Old 04-15-2019, 07:52 AM   #13
rpo83
Thanks Jaahn,
I'll go read your thread.
I have just logged out and as a visitor i could see them, you may have to refresh the page..
Cheers
Steve
Old 04-15-2019, 08:28 AM   #14
Aussie 2002 4x4
Aussie 2002 4x4's Avatar
yeah, I would remove the rollbar...especially that rear section. ah, those cupboards look familiar..expect to find some 'additional' wiring in that lot
Aussie 2002 4x4 is offline   Reply With Quote
The Following User Says Thank You to Aussie 2002 4x4 For This Useful Post:
rpo83 (04-15-2019)
Old 04-15-2019, 08:59 AM   #15
owner
owner's Avatar
Wow that engine top looks filthy and some corrosion there too. Ive never seen one that bad.. Your van must have seen a lot of dust/dirt roads. Mine has done 430k and you couod eat off the engine top under that cover.
Have you lifted the step covers to see if theres any rust? I'd be doing that next given the condition of the engine. Also check your engine and cabin air filter.
owner is offline   Reply With Quote
Old 04-15-2019, 11:02 AM   #16
rpo83
I was just happy that there was no evidence of black death...
It was used as a mine ambulance for the last 6 years, so it has seen its fair share of dust. The body looks very good, i have a feeling it may have been garaged most of it's life.. I haven't removed the step covers yet, there is checker plate over the main door, and the other door where the oxygen was stored, requires a lot of paraphernalia to be removed to get to the cover.
Cheers
Steve
Old 04-16-2019, 01:06 AM   #17
owner
owner's Avatar
The front steps will be a good indication of what the side steps will be like. The reason for concern is that these mine vehicles are regularly hosed down with salty water at the mines. And that corrosion on your engine cam cover suggests its seen some.
The Following User Says Thank You to owner For This Useful Post:
rpo83 (04-16-2019)
Old 05-05-2019, 12:47 AM   #18
rpo83
I removed the step today, well i partially lifted it, the roll cage limits the step from being lifted! I firstly had to remove the checker plate to get to the screws, then i started removing all the aluminium dress trims on the floor to figure out what else may need removing. I think the cage will be removed, long term i can just seeing it getting in the way.
No evidence of rust, just some dust, pebbles, nylocks and cable ties. So that has all been removed and the step refitted.
Looking at the catch, there is a spring loaded pivoting lever that looks slightly bent, or the catch outer is bent, i'm not sure... Can anyone shed some light on if this catch looks damaged?
Started by removing the checker plate.
Roll cage fouling the step.
Only dust, small rocks, screws, cable ties and nylocks, no rust..
Rear catch bent lever??
Looking at the lever pivot..
Cheers
Steve
