Old 11-27-2019, 06:39 PM   #1
Joeralph123
Question Sprinter 213 gear shifter variants
Hello
I have a 02 sprinter 213 LR SWB and my gears are very stiff especially when van is cold and they crunch when I change gears, the clutch pedal makes no difference until clutch is up and if not engaged will grind so I have to wait for the gear to engage and slot in before lifting clutch and can take 10seconds.
I have swapped the diff and gearbox oil twice and also adjusted the cables multiple times and also replaced the snapped gearbox mount! since owning it and it has got much better since but still there.
Next to try will be a new gear shifter as there is a lot of play atm but all the gear shifters I can find seem to be the A0002600109 which looks different to mine and has a circular bit to the right?
The one I need is the OEM NO : A 0002600009
I have found a website below showing the item needed but appears they have no stock and was wondering if anybody can help source one or knows any that are compatible?
Thank you for your help
Joeralph123 is offline   Reply With Quote
