Old 08-16-2019, 10:40 PM   #1
ManWithDog
Default 02-03 Turbo Actuator
Hello
I have a 2002 Freightliner with approx 225k miles, original turbo, new hoses, new turbo exhaust manifold and gasket, new catalytic converters, clean egr
I suspect i may have a bad turbo actuator
The van runs great after you start it, if you allow it to idle for more than 20 seconds, the turbo stops working completely, and i must restart the engine for it to work again. very frustrating
I have searched for the vacuum actuator and found very little information. I've spent a few thousand dollars trying to fix this and after saving for a year, I'm ready to spend some more money again. So.... Does this sound like a turbo actuator?
ManWithDog is offline   Reply With Quote
Old 08-16-2019, 11:20 PM   #2
Godzills14
Godzillas14
Default Re: 02-03 Turbo Actuator
Does the arm move on startup? If you donít let it idle does your turbo work?
Godzills14 is offline   Reply With Quote
The Following User Says Thank You to Godzills14 For This Useful Post:
ManWithDog (08-16-2019)
Old 08-16-2019, 11:57 PM   #3
ManWithDog
the arm on my turbo? yes it moves at start up. it'll freeze and be unmovable if i don't take off qucikly after i start it up however.
if i don't let it idle and keep moving, the turbo works non stop.
i'll start it up right before a ramp to the highway and stay at 80mph non stop and can drive for hours
the second the rpm comes down to around idle, the turbo stops working, the arm in the middle of the turbo wont go up or down.
Old 08-17-2019, 12:17 AM   #4
MillionMileSprinter
Formerly Type2Teach
MillionMileSprinter's Avatar
Are there any error codes that pop up?
If not, then it's pretty classic on that engine to have the turbo actuator go bad but not register with the ECU.
Here's a link to it on my website:
https://www.millionmilesprinter.com/...2002-2003-only
Sprinter Mechanic
Joel Sell
For HELP, SERVICE and MORE
MillionMileSprinter is online now   Reply With Quote
The Following User Says Thank You to MillionMileSprinter For This Useful Post:
billintomahawk (08-19-2019)
Old 08-17-2019, 12:26 AM   #5
ManWithDog
million mile sprinter, the description on your web page is exactly what is happening to my van. but the turbo doesnt surge on the highway. no check engine light. Is it difficult to install?
Old 08-17-2019, 01:39 PM   #6
ManWithDog
Okay, so it could be my actuator. What should I check before ordering it?
Old 08-17-2019, 04:07 PM   #7
lindenengineering
I tell,you what --Don't shotgun.
The system communication is by rubber type vacuum tube ,something like "5 tirtytoots" diameter.
Rubber tube gets soft with age & oil contamination.
When it gets soft it collapses under vacuum activity, vacuum cant operate the actuator so it "no pulsey it no workee!
Pull out the air cleaner box and inspect the vacuum hoses. If in doubt replace them by buying lengths of the correct size vacuum hose from some autoparts store like Advanced for a few paisters.
Then try again.
The Following 3 Users Say Thank You to lindenengineering For This Useful Post:
billintomahawk (08-19-2019), hkpierce (08-17-2019), ManWithDog (08-17-2019)
Old 08-21-2019, 12:58 AM   #8
ManWithDog
Today i pulled my airbox out and checked the actuator. The hose from the actuator to the bottom of turbo looks new however all the other hoses look 17 years old. The old hoses also look like i would need to special order them. I took some photos. Ill post them in a few
Old 08-21-2019, 01:01 AM   #9
ManWithDog
https://ibb.co/BPbsK1z
https://ibb.co/2WrFLZc
https://ibb.co/V9m8nNz
Old 08-21-2019, 01:08 AM   #10
ManWithDog
Should i replace all the hoses?
And Million Mile Sprinter, does your actuator come with those hoses?
Also, if it were just the hoses, wouldnt the van always run crappy? It runs great when i first start it, but after sitting at low rpm for 20 seconds or so, the turbo quits and i must restart the van to get it running good again.
If i tie the arm in the middle of the turbo all the way down, it runs great no matter what.
