Go Back   Sprinter-Forum > VS30 Sprinters > VS30 Write-Ups
VS30 Write-Ups Help other VS30 owners by posting your experience working on your Sprinter.
Old 01-12-2020, 05:49 PM   #1
AirborneRGR
Default Replacing the stock horn without having to pull the grill out.
Replaced the stock scooter horn with the horn kit from Agile Off Road
https://youtu.be/7BLQnJ0WTWM
AirborneRGR is offline   Reply With Quote
The Following 6 Users Say Thank You to AirborneRGR For This Useful Post:
CAsprinter4x4! (01-13-2020), DCgasman (01-13-2020), FlaJoe (01-14-2020), lndscpe (01-14-2020), NoSoupForU (01-15-2020), Surveillance Van (01-12-2020)
Old 01-12-2020, 10:16 PM   #2
my_vw_sucks
Default Re: Replacing the stock horn without having to pull the grill out.
Need to do this. Can’t deal with the Herbie the love bug horn.
my_vw_sucks is online now   Reply With Quote
The Following User Says Thank You to my_vw_sucks For This Useful Post:
AirborneRGR (01-13-2020)
Old 01-13-2020, 02:56 PM   #3
CAsprinter4x4!
Is the “chirp” sound you hear when you lock your van come from the horn?
When you replace the horn does it also effect the “chirp” sound you get when you lock your van?
Thanks
CAsprinter4x4! is online now   Reply With Quote
Old 01-13-2020, 04:43 PM   #4
djmroberts
I replaced the herbie toot horn in my 2017 144 with dual 150db air horns (sounds closer to a Mac truck) and it does not sound off when I lock the van. Was a challenge fitting it in behind the grill but had to do it...
djmroberts is offline   Reply With Quote
Old 01-13-2020, 05:50 PM   #5
Bobnoxious
Bobnoxious's Avatar
I like everything except the part of clipping the factory harness and would've used a factory connector.
The Following 2 Users Say Thank You to Bobnoxious For This Useful Post:
AirborneRGR (01-13-2020), hein (01-13-2020)
Old 01-13-2020, 09:00 PM   #6
chriszep
I have been thinking about doing this, but not clipping the factory harness. I wonder if you disassembled the factory horn itself you could get to some clean wires and tap into those... I hate the idea of cutting a factory harness off knowing how tricky the MB techs can be about "voiding the warranty"
chriszep is offline   Reply With Quote
Old 01-14-2020, 05:28 PM   #7
mdbrown
Thanks
I installed the Agile kit and it chirps just like it used to, but now it sounds normal.
mdbrown is offline   Reply With Quote
The Following 2 Users Say Thank You to mdbrown For This Useful Post:
AirborneRGR (01-16-2020), NoSoupForU (01-15-2020)
Old 01-16-2020, 10:07 PM   #8
GLJones
I replaced my horn with a 150db train horn I got on Amazon. Removing the grille is no big deal. Three screws, two side clips and the camera. They all pop out really easily, in fact the camera will pop out on it's own if you pull on the cable too hard.
Reassembly is easy as putting the camera back in its mounting area, it clips right in, and pushing the grille back in place and replacing 3 screws. Literally, the hardest part is removing the 3 screws.
Here is what mine looks like before I put the grille back on.
GLJones is online now   Reply With Quote
