Old 05-29-2009, 06:18 AM   #11
shanemac
Default Re: Rear back up camera install
For me i have not gotten that far but from the research i did on this sight you can use the terminal strip for the power wire. I stole this photo from another board member Tom McD... i made the notes.
I cut this page out too it shows the terminal strip details.
http://shane.servicetechhelp.com/terminalstrip.pdf
I'm not sure which terminal post of the three is constant power or powered when ignition is turned to accessory or if all three are powered all the time i would guess there all powered all the time.
I want to have a switch on dash (would like to use one of the factory switch locations) to turn on the camera when i wanted too. I need to research the factory rocker switch to buy.
The reverse light wire is a BLUE/WHITE wire from the few threads i read anyhow...they were taping into tail light housing i would guess.
Just wanted to show a closer detail of the Rear View wiring harness while i was making this post. A few draw backs about putting this complete harness under the drivers seat is access, such as the fuse link when the time comes and the AV cables jacks if i want to add other accessory's on the fly quickly. I would not rather remove the seat each time or gash holes in the side of the seat base for access.
The video camera wire trigger leads the white, blue, and green will have to be extended anyhow, the blue for the rear camera, the white and green for side cameras for example. I will keep working on this in the mean time
shanemac is offline   Reply With Quote
Old 05-31-2009, 07:24 PM   #12
twistyroad
twistyroad's Avatar
Originally Posted by shanemac View Post
Hi everyone, this is the beginning of my journey to install a rear back up camera system. So for today I'm just starting off the thread with the system i bought and my opinion so far about it. As my progress moves along i will update the thread as i go.
The company i went with is called RearView
This is the system i went with and according to Nick the guy who took my order this is there most popular kit they sell. Nick is a great guy and was very helpful.
I also went with this mounting bracket...once i seen it on member twistyroad's van i had to have one
Right now i can say this, the quality of this stuff is very very good, the camera assembly looks very sturdy like it can take some abuse. The monitor is light weight but looks to be well made.
All the cables and power supply wires have a nice flexible feel to them not the cheap stuff. Kit includes mounting hardware for camera and the monitor has mounting as well.
You didn't just get the same camera mount that I did... this is the same complete system as well. I'm very pleased with it.
Decided to just dry fit the mounting bracket and see ware i want to mount the monitor. To me this looks like a good spot to mount things.
Exactly where I mounted mine.
Originally Posted by aljimenez View Post
That top rear brake light will cause your camera to blank out. You might consider trying your position first in the dark. Of course this is hard since you want to see what it does to the camera's output. I positioned my camera besides the brake light to reduce this problem. Of course my '04 brake light is a lot smaller... Al
I don't know about other (cheaper?) systems, but that is NOT true of this system on this mount. On this mount, the brake light is not within the camera's field of view. During the day, there is absolutely no change to the monitor image when the brake light comes on. In the dark, the brake lights brighten the image somewhat, because the brake lamps provide increased illumination to the ground/objects behind you, but they certainly don't "blind" it.
The rear backup lamp wiring and the cyclop wiring are in the same harness running to the rear d-pillar. I would put a 12v relay on the cyclop wire that is triggered by the current in the rear backup lamp. That is when you put your gear in reverse, the cyclop turns off. (ps... you'd have to live will a dash warning lamp coming on tempararily while in reverse)
As I said, the light from the "cyclops" is not an issue, therefore this is not needed.
Well decided on the upper middle position as of now my Ram Mount came in today so did some test fitting in various spots and for the most part the upper and lower corner locations work fine too. If anyone wants more photos of anything or the mounting system just ask. In the mean time i will post back when i have more progress completed.
I modified the stock interior mirror to serve as a mount. The end result was a position much like where you're proposing. I think it's ideal.
The wiring harness included in kit has been kinda a challenge, they only made the monitor cable so long off the main harness so if i want to mount it high and in the center in the rear view mirror area, the rest of the harness for the power feeds and such will be in a very award position in cab will not reach under seat plus the bundle of extra AV cables ends and fuse block in harness needs to be accessible . The only other option would be to get there extension cable of 5 feet and that would make things a bit better.
I too came up a bit short on cable/harness length... I ended up going with their camera cable extension.
The posts under the "consumer terminal strip" in your picture are:
Blue/Yellow wire: on when engine is running.
Red/Gray wire: always on (direct battery power).
Black/Yellow wire: on with ignition switch.
I spliced the reverse wire into the wire harness going to the backup lights. Here's where I put the fuseholder:
The pic below puts the fuseholder in better perspective. The wires are still just "roughed in." The added green and red wires running down the B-pillar are power wires to accessories (including the rearview system) from the "consumer terminal strip" or the aux battery.
Hope this helps. Enjoy your new upgrade!
Rock
You're only young once, but you can remain immature indefinitely.
twistyroad is offline   Reply With Quote
The Following User Says Thank You to twistyroad For This Useful Post:
barnjit singh (11-28-2010)
Old 05-31-2009, 09:32 PM   #13
shanemac
twistyroad thanks for your input...i was also wondering were the best place to buy automotive wiring from... napa? any other places i can get this wiring from?
Old 06-01-2009, 02:18 AM   #14
twistyroad
twistyroad's Avatar
I got most of my automotive (read: non-sound-system) wiring supplies here.
Old 06-01-2009, 04:45 AM   #15
shanemac
Old 06-01-2009, 09:04 PM   #16
James-G
James-G's Avatar
I decided to skip the bit i can't do and just add a cigerette lighter plug for power, i'll get some professional to wire it in properly some time.
I think a switch is the way to go as opposed to using the reverse option, my camera also has sound and i can invisage wanting to switch it on some time while i'm not in reverse.
My system came with three brackets i settled on the least invasive of the three, which is the stick on option, I settled on having the screen near the side mirror to avoid too much looking around while reversing.
the wire shortcut, just to get me up and running really, i can leave it plugged in and just use the power button on the screen.
I'm very happy with the build quality of this system http://www.svencamerasystems.com/
James-G is offline   Reply With Quote
Old 06-02-2009, 02:54 AM   #17
qualityair
'09 144" Cargo
James, well done! Could you show us some more photos of your camera mounting ?
Tks, Charles
qualityair is offline   Reply With Quote
Old 06-08-2009, 07:44 PM   #18
James-G
James-G's Avatar
Tks, Charles
sorry been busy
here's a couple
Old 09-10-2009, 02:35 AM   #19
shanemac
Well i decided to start doing some more work with install i managed to get the monitor powered and my new extension cable for monitor came in too. I'm real rusty with automotive wiring and need some clarification. I decided to install a manual toggle switch to turn on the rear camera when i want rather than taping into vans wire harness for the reverse light. I don't need the camera to come on every single time i reverse plus i wanted the option of turning the rear camera on when I'm moving just for the hell of it.
hear is a crude sketch
The rearview camera instructions says to connect the green wire to the switched positive + power output terminal of the "R"(reverse) gear for CAMERA
so 12vdc feeds + on toggle switch when i turn i switch that will feed dc to rear camera, ground the switch to a chassis ground....sounds to easy. I'm i way out in left field? i should fuse the toggle switch too?
Old 09-10-2009, 03:03 AM   #20
bikergar
bikergar's Avatar
Shane
You don't need the ground. All you need is 12v on one side of the switch. On the switch you are displaying you could put 12v on one side to turn the camera on and off as desired and 12v reverse gear power on the other side. This would turn the camera on when you go to reverse. If you just want simple on and off don't use the terminal on the other side. No ground...It will get that thru the camera when turn the switch on.
gary
Keep Doing What You Did, and You'll Keep Getting What You Got...
2008 2500 CRD 144 inch High Roof Crew Van
bikergar is offline   Reply With Quote
camera
