Old 08-01-2016, 10:19 PM   #1
jmoller99
Own a DAD ODB2 Unit.
jmoller99's Avatar
Default Fixing a broken plastic dash vent louver
The plastic dash vent louver pieces pop up too easily and I seem to break off one (or both) of the tabs, so I can't get them back in.
Here is how I fix it once I've broken off a tab (in this case 2 of them - one on each end).
I ordered some 10mm long watch band spring units (on eBay, with free shipping, that amounted to 99 cents). These are 1.5 mm in diameter (1/16 of an inch drill bit is slightly wider, so it works).
I drill out approx 8 mm deep into the plastic louver on the side that I'll ease into place (so it only sticks out as far as I can compress it all the way). The other side sticks out further (I put that end into the assembly first), so I don't drill it out that deep. If you are only replacing the one tab, its simpler.
I used a short length of metal coat hanger to get behind the snap on so I could pull the louver snap on piece together and then slide reattach the louver (like you do with a watch band).
I was never fond of how this part goes together (it's too easy for it to come apart during disassembly and reassembly). I have 3 louvers repaired in this way on my dashboard. I recently had this one pop out, so I captured a few photos of how I addressed it
The Following 28 Users Say Thank You to jmoller99 For This Useful Post:
Andy in NH (08-03-2016), autostaretx (08-02-2016), bcolins (07-29-2018), bobmac (04-18-2019), derekhski (08-03-2016), DesertAdventures (07-30-2018), dickknapp (08-03-2016), DougE (08-02-2016), Garandman (04-04-2019), GaryJ (08-02-2016), garyo (09-14-2018), hkpierce (08-16-2016), Ho-Hum (05-26-2019), indigoE (07-30-2018), kayakkingoz (12-29-2016), Kimcantri@gmail.com (10-24-2017), krisinak (08-12-2016), lindenengineering (08-03-2016), MeRob (08-02-2016), mrcolin2u (05-25-2019), MXHauler (11-23-2016), ranchworld (08-03-2016), ReGULT51 (04-11-2019), sikwan (08-14-2016), Skippy and Emu (08-02-2016), SprinterSnale (11-02-2016), stroud_omnibus (08-04-2016), Thanasis (08-14-2016)
Old 08-02-2016, 02:08 PM   #2
rjz5400
rjz5400's Avatar
Default Re: Fixing a broken plastic dash vent louver
Nice writeup, thanks for the idea!
2003 140" 3500 om612, 255,555 mi. and counting!!
rjz5400 is offline   Reply With Quote
Old 08-02-2016, 03:10 PM   #3
DougE
Way to go! That is inspired. I have a vent I broke and just put a dab of glue on to hold the vane in place. Of course it won't adjust now. I will definitely copy your method.
2005 Leisure Free Spirit 210B on 2004 Chassis
DougE is offline   Reply With Quote
Old 08-02-2016, 03:16 PM   #4
Skippy and Emu
Skippy and Emu's Avatar
Excellent fix !
At this stage my actual louvers are ok. However, the lever in the middle that adjusts the louvers angle is so loose that it will not maintain the louvres in my preferred position. The airflow moves the louvers! My temporary fix at the moment is a tissue stuffed into one of the openings.
I shall be be forever greatful if anybody has fix for this particular issue ?
2003 313cdi MWB, High Roof, Manual, ECB Bullbar, Windows all around, Rear Aircon, Swivel Passenger seat, 580 watts solar, 150 amp alternator, Fiamma f45s, Carr Mega Step, Chinese 2kw diesel heater, 228000 kms.
Skippy and Emu is offline   Reply With Quote
Old 08-02-2016, 05:27 PM   #5
LuckyDawgz Jim
LuckyDawgz Jim's Avatar
That's a really nice solution.
I had repaired the louvers on my 2002 initially using brad nails clipped down to size, but the "floppy-ness" finally got to me and treated my Sprinter to OEM assemblies for both the passenger and driver sides.
Knowing how fragile that louvers are, I will keep your fix handy.
Thanks,
Jim
2002 Freightliner C2500 SHC 158WB 113k
RV Conversion... Known as the "T1N TeePee" or "White Whale"
LuckyDawgz Jim is offline   Reply With Quote
Old 08-03-2016, 04:09 AM   #6
I never thought to actually buy the pins.
Glad to hear that they are cheap.
So Man's Best Friend put his paw through my louvers. Canine 3, Vent 0.
I had some old watchband spring pins and figured I'd try those. Worked very well for installation. I set in the up/down clip first, then set the pin and let it spring back into place. The smaller pin end is probably a bit more sloppy in the vent side hole than the brad method, but is good enough for my use. Very easy to install.
It is a bit of a pain to keep the drill aligned correctly. FWIW. vic
Old 08-03-2016, 05:12 AM   #7
glasseye
glasseye's Avatar
Brilliant!
Old 08-13-2016, 05:14 PM   #8
teamtexas
A Dad owner with a '03
teamtexas's Avatar
Very clever. Thanks for sharing!
Old 08-14-2016, 06:01 PM   #9
jcmadeintheshade@gmail.com
An even better replacement for these cheaply made vents would be a 3d generated vent facsimile out of a more durable material. Carbon fiber? Bring it on. Anyone that comes up with a better idea will have an instant market niche.
I replaced two of mine years ago from a used parts site in Ok?, but since then a couple of the others have not held up.
3d printer aficionados out there in sprinterland, come on down. You will have an instant market advantage. Replacing these vents with the same prone to failure parts is nuts. That old saying about the fine line between sanity and insanity applies here.
The Following User Says Thank You to jcmadeintheshade@gmail.com For This Useful Post:
Old 08-15-2016, 02:37 AM   #10
I hear you.
My used 2006 came with missing vent parts. Unfortunately the center operators are missing too. Otherwise I could probably cobble some replacements together out of folded aluminum flashing.
Actually I've become pretty good at ignoring the missing vents. They really don't seem to be required for my general comfort. It sure looks tacky with them missing though.
Added:
Maybe something like this?
http://www.instructables.com/id/Maki...board-AC-Vent/
