Old 03-30-2008, 06:30 PM   #21
sikwan
06 T1N Can
sikwan's Avatar
Default Re: Koni Shock Install
Unless Summit raised their prices, the $622 price I quoted (for the 2500) was WITH Freight. Actually ground shipping is free, but they charged something like $11 for handling.
israndy (02-10-2011)
Old 06-19-2008, 04:27 PM   #22
kendall69
How about this little tool
http://www.tirerack.com/suspension/koni/koni_faq.jsp
2007 144" Diesel
Old 06-19-2008, 07:13 PM   #23
sikwan
06 T1N Can
sikwan's Avatar
Originally Posted by kendall69 View Post
Do you mean the white one in this picture?
You will only be able to use it on the fronts and when the shocks are unmounted. Plus, the direction of firm is going the wrong direction.
Old 11-04-2008, 05:48 AM   #24
AircooledJohn
Last weekend I installed Koni's on the rear of my 2006, which has 45k miles.
OEM Shocks were noticably softer than the Konis. I set the Koni's at 50%, the install took 30 minutes.
I hadn't even driven 30' out the driveway and I felt the improvement! We have a water-ditch where the driveway joins the road, it used to rock back and forth and result in yelling from the kids in the back. Speed bumps did the same unless you hit them squarely. NO MORE
John
AircooledJohn is offline   Reply With Quote
The Following User Says Thank You to AircooledJohn For This Useful Post:
riabreed011 (06-15-2011)
Old 05-21-2009, 07:01 AM   #25
rlent
rlent's Avatar
Just thought I'd pass this along ..... I purchased front and rear Koni's awhile back, installed the rears a couple of months ago.
Yesterday I started the "replace-the-front-ball-joints-and-install-the-front-Konis" project .... got the drivers side done and noticed while I was adjusting the the struts that when I compressed them, the rod would not stay in the shock ... it would push back out about 5 or 6 inches (repeatedly) ..... this did not happen with the rear shocks.
Dunno if they changed to low-pressure gas or this is something else ..... I got these from Summit about 2 months ago.
Old 01-03-2010, 06:33 PM   #26
elysium
Quick question: to replace the rear shocks, a) can I just remove/replace the shocks _without_ raising/jacking the sprinter up or b) do i need to use a jack to raise it?
elysium is offline   Reply With Quote
Old 01-03-2010, 08:22 PM   #27
georgetg
2005 140" low roof
No need to jack for the rear install
You can do the front without removing the wheel but you need to jack it up a little IIFC
Cheers
George
georgetg is offline   Reply With Quote
The Following User Says Thank You to georgetg For This Useful Post:
sprinterpirate (08-04-2013)
Old 02-18-2010, 02:25 AM   #28
chris118
chris118's Avatar
Today I installed koni's on the front. Thanks so much for this post it went pretty smoothly.
The step by step gave me the confidence to actually try something like this.
I'm mainly just a oil change/very minor repair guy.
I got couple of questions-
First, I was able to torque the bolts to the correct # on everything except the driver's side top bolt.
The shaft kept turning with the nut and I have a ratchet clicker torque wrench. Is there a trick to torquing in a situation like this?
I ended u p just using the allen wrench to hold the shaft and then bolted the thing down to till it matched the passenger side in terms of threads showing. The passenger side shaft stayed put once the bolt got tightened and I was able to torque it to the 74# needed.
Also, the front tires now seem to have a slight angle to them, as if there wasn't enough weight in the front. I set the shocks to the firmest setting then backed off 3/4 of a turn. Did I set them too firm? do they "break in" and settle down. see attached photo. I am probably being paranoid as the difference is slight.
I drove on them for about 40 miles today and I no longer have that roller coaster feeling when driving on the downtown potholed streets of san francisco!
chris118 is offline   Reply With Quote
Old 02-18-2010, 02:51 AM   #29
sikwan
06 T1N Can
sikwan's Avatar
Chris, I think you should be fine. But if you really want to be sure, you need to do the same thing using the allen wrench and attach a crows foot...
...to your torque wrench.
I can't tell by the picture, but the shocks should not have any affect to the angle, unless it wasn't bolted on right or there's a manufacturing defect on the angle of the hub bracket of the shock.
I have mine set to full firm.
chris118 (02-18-2010)
Old 04-13-2010, 01:43 AM   #30
my splinter
my splinter's Avatar
hi its me my splinter,,,can you send me the name and address of where you perchesed the front shocks for the 2006 sprinter..at.
my splinter is offline   Reply With Quote
