Old 07-30-2012, 07:46 PM   #21
dukepilot
Custom Spooling USA
dukepilot's Avatar
Default Re: "BDP" was Re: DPF delete by my friend
Gary, I'm interested in hearing your friend's results. Keep it coming!
Originally Posted by gary 32 View Post
Bob, Our NCV 3 fueling systems would not live well on straight biodiesel either.
Friends results after installing empty can dpf:
-Dpf core was clean, but it seemed to be in almost constant passive regen, had high egr flow and 10-20% mpg decreases from historical with power cuts for high egt's.
-Before tail pipe was rust colored with almost no soot. After pipe is black with almost no soot.
-Power and response are improved.
-With just the tune: 19 mpg average.
-Same tune and dpf core removed: 10+% mpg increases but only with a light foot otherwise mpg is unchanged.
-No codes or cel with tune and empty can.
-Egt's are reduced 70-100 degrees, 150 degree reduction @ idle
-Results will follow for dpf/egr delete written into existing tune only if there is positive interest.
2008 144" NCV3 HiTop, 3.0 CRD OM642, Performance/Emissions Tune by CustomSpooling, Progressive Water/Methanol Injection, 3.92 Axle, Koni Shocks, 235/85-16 Cooper S/T Maxx Tires, Kicker Speakers/10" Sub Woofer/Boss 800 watt amp
If it causes trouble, delete it! If you want improved reliability, performance and economy, get a Customized Tune for your Sprinter! Contact peter@customspooling.com or go to www.customspooling.com and visit our Facebook page at www.facebook.com/customspoolingusa
dukepilot is offline   Reply With Quote
Old 08-02-2012, 07:49 PM   #22
gary 32
07 ncv3 pv
gary 32's Avatar
Default Re: DPF delete by my friend
1 week later, Friends results after installing empty can dpf with a performance tune:
-Very light soot film in rear pipe, no observable airborne soot, light bleach smell, no smoke.
-No turbo lag, better throttle response, healthier engine note, moving more air at all rpm's.
-10+% city and highway mpg increases with a light foot; otherwise mpg is unchanged.
-Egt's are reduced 70-100 degrees, 150 degree reduction @ idle.
-200 miles, still no codes or cel with performance tune and empty can.
-Loader arrived yesterday ($206.47 shipped), my friend wants to drive it without the ($400.00) dpf/egr delete tune for a couple weeks, tuned results in a few weeks.
gary 32 is offline   Reply With Quote
Old 08-06-2012, 04:44 PM   #23
flman
Fast and sloppy typist
Hey Gary, I am wondering if it coasts any better considering the DPF might act like an exhaust brake?
Old 08-10-2012, 06:58 AM   #24
4wheels
Empty can DPF ? Is it for sale ? Where can I buy it ?
4wheels is offline   Reply With Quote
Old 08-14-2012, 03:42 AM   #25
Texas Diesel Guy
I haven't found anyone who sells a "kit" for sprinter dpf deletes, they are all over the web for Ford/Chev/Dodge. When I took the one we removed to a muffler shop he measured the pipe and told me it was metric... guess I shoulda seen that coming but I never thought about metric pipe sizes. So he just took a slightly smaller pipe and expanded the back end so it would fit in the existing slip coupling and put what he called a "Buick ball" just a kind of flare on the other end to match up with the coupler they use at the front.
This was geniunely done as an experiment because DPF is an EXPENSIVE call, and you don't want to misdiagnose and say oops over thousands of dollars.
Really, removing the DPF can be done with hand tools in a few minutes. The "ball" at the front comes off just like a regular band clamp and its just a plain slip coupler at the back. There are 3 17mm nuts, 2 at the front, one for inlet pres thats just a hollow tube, and one for inlet temp sensor and one at the back thats an outlet pres, just another tube. Then just slide it out of the hanger and your done. While its out, take about a 3 foot masonry bit, and drill holes right down the throat of the thing and replace it.
The computer monitors differential pressure, meaning pressure on the inlet vs outlet to determine DPF load. All the computer will see is less differential, meaning more flow, but as long as theres some differential the computer is none the wiser. Call it a DPF compromise rather than delete.
Texas Diesel Guy is offline   Reply With Quote
The Following 3 Users Say Thank You to Texas Diesel Guy For This Useful Post:
nblizzard (07-23-2015), Red Eye (11-24-2012), Smiling (06-14-2014)
Old 08-14-2012, 05:54 AM   #26
sterling
'03 3500 T1N
sterling's Avatar
Location: somewhere on I-10 between San Antonio & the Santa Monica Pier
Originally Posted by Texas Diesel Guy View Post
Dude, are you serious? an "integral part of the emissions system", really? Its a cold start aid and doesn't have anything to do with the DPF or anything part of the engine after its running.
DPF is the one of the dumbest ideas dreamed up yet. This is how I think that started...
"Hey, I know, we'll capture all the particulates in the exhaust to keep them out of the environment"
"Wow thats brilliant, but what do we do with all the crap when this capture device is full?"
"Hmmm, well lets dump raw diesel in the exhaust while the engine is running to burn it out of there"
"Right...but if we're going to just burn it out of there, why did we bother capturing it in the first place?"
"Oh it will only work a few times, then the device will have to be replaced with a new one"
"Hmmm, so let me get this straight, we're going to invent a device that captures particulates in the exhaust, sort of self cleaning by burning it out, no doubt very expensive to replace, and ensures lower fuel economy, lower performance, and higher maintainence costs, its great!"
Yeah, thats brilliant guys.
There is NO argument that DPF deletes yield better power, and better fuel economy. Why isn't improving fuel economy priority 1? If we reduce the amount of fuel we consume, demand goes down, foreign dependancy on oil goes down, prices go down, operating costs go down and less fuel is burned, thus less emissions. DPFs arent for the environment, they are for beaurocrats and big oil. And don't get me started on EGR valves!
"Hey lets reduce emissions by recirculating exhaust back in the intake"
"Wow that will very effectively reduce exhaust volume... but won't the exaust be harmful to the engine? Kind of like cuffing a fart and inhaling it to make is stink less?"
Less emissions by 5 times that of diesel with compressed natural gas...why does America not see it and embrace it?
Oh, and by the way, with CNG you don't need a DPF (whatever that is) nor a bunch of belching, stinking, polluting, carcinogenic oil refineries all over America's coastline that crack foreign crude oil into diesel bought from tyrants who hate everything America stands for. Nor would we need to fight wars over foreign crude oil that are so costly, first and foremost, in the lives of young Americans and their families as well as centrifuging our ever expanding collasal (sp) national debt....Our addiction to foreign crude oil is the largest transfer of wealth ever seen in the history of our great nation. It is crazy and hobbles our kid's and grandkid's futures.
Let's cross our fingers and hope the Arabs don't raise the price of the only thing they sell? Really?
Natural gas comes from all over America and the industry hires Americans, pays American taxes and provides an extremely clean burning fuel that can serve as a bridge to sustainables...plus we will eventually be able to fill-er up at home...clean & cost effectively. Most of us have natural gas already piped into our homes or it is out at the curb already.
American Energy for American transportation NOW! a no brainer imho
sterling is offline   Reply With Quote
The Following 2 Users Say Thank You to sterling For This Useful Post:
flman (08-15-2012), Smiling (06-14-2014)
Old 08-15-2012, 03:24 PM   #27
flman
Exactly why the DPF was invented, it is nothing more then a device so big oil companies don't have to compete with bio fuels.
I am sure some of the members with a degree would never believe this?
The Following User Says Thank You to flman For This Useful Post:
Old 08-15-2012, 06:01 PM   #28
gary 32
07 ncv3 pv
gary 32's Avatar
Bob, fairly quick acceleration then coasting betters mileage in every diesel. More so in my friends Sprinter.
Bob the dpf/egr system is a filter that needs service regularly, Chevy, Chrysler, Ford, MB, VW should all provide no cost maintenance on their systems.
More than 5% bio will mess with the injection side of crd's.
Empty can DPF? Is it for sale? Where can I buy it?
4wheels, Texas Diesel Guy, My friend says: Find a muffler shop to open the factory welds, remove the ceramic filter, weld the can back up and on 07-09 remove the rear muffler and straight pipe that section removing more back pressure.
TGD, Drilling holes is also trashing a dpf without getting all the benefits.
Old 08-15-2012, 10:54 PM   #29
flman
Gary, I thought their was a link to a food service that was running bio and had a custom spooling tune on their NCV3s? Also why should MB make a dpf equipped vehicle bio compatible, considering it is a no no with the dpf?
Old 08-16-2012, 04:26 PM   #30
gary 32
07 ncv3 pv
gary 32's Avatar
Default Re: What is cleaner than an empty DPF can
A lot of us are nearing the end of our 5 year 100k emissions warranty.
EGR valve cleaning or replacement and egr system cleaning were never listed by MB as maintenance items, yet they are. Our fuel was a given and we are not refiners so stfu MB.
Like an engine air filter, dpf cleaning or replacement would never be covered by any warranty.
Friends Conclusions: An already tuned sprinter runs better in every way with a "clean" dpf, no cel, no codes. For Icarus Orion, no it does not run as clean and no there are not significant mpg increases, but maybe egr delete will fix that.
My tenants ran (2) MB powered cr/dpf catering trucks on b100 for about 2 years, $30k later in injection repairs they now run b5 or #2 diesel.
The Following 2 Users Say Thank You to gary 32 For This Useful Post:
flman (08-16-2012), Smiling (06-14-2014)
