Old 09-28-2017, 02:32 AM   #11
hkpierce
'02 140 Hi BlueBlk Pass
Default Re: Viscous Fan Clutch Replacment
While I was in the process of replacing my water pump, idlers, tensioner, serpentine belt, plastic fuel lines and rebuilt high pressure pump, I noticed that my fan's springs were quite rusty. Playing around with them a pin under the springs disappeared.
As this was the least of my troubles, I decided not to invite fate. So I bought a new Meyle fan. I note the gasket around the pin. I have no idea what the pin does.
The Following User Says Thank You to hkpierce For This Useful Post:
Aqua Puttana (09-28-2017)
Old 09-28-2017, 09:58 AM   #12
The copper colored plate is a bimetallic spring. It will invert at a specific temperature. The pin will thus be pressed inwards. This locks the clutch. The green gasket/seal prevents the viscous fluid from leaking out.
The bimetallic spring determines the lock up temperature of the clutch. Being in the radiator airflow, it will be close to the coolant temperature.
The Following 3 Users Say Thank You to Midwestdrifter For This Useful Post:
hkpierce (09-28-2017), KarinaK (08-09-2019), SprinterSnale (09-29-2017)
Old 09-29-2017, 01:22 AM   #13
bcman
bcman's Avatar
Quick question: How do I know the viscous clutch is in need of replacement? The wife and I had a couple summer road trips where the engine temp started to rise on long uphill grades with the a/c on.
bcman is offline   Reply With Quote
Old 09-29-2017, 02:11 AM   #14
hkpierce
See Post 5 above.
Old 09-29-2017, 04:04 AM   #15
lindenengineering
You might like to take the radiator core support X member off & separate the cooling pack and thoroughly clean it.
One we did very recently knocked 7 Celcius off the top pipe temp when under full load & that included a full internal cooling system system flush as well.
Old 10-01-2017, 04:47 AM   #16
cahaak
cahaak's Avatar
There is a good post on separating the cooling stacks and cleaning them. Ir really helps to have a long stiff bottle brush.
Chris
2006 140" passenger
normal roof with rear AC
Old 08-22-2018, 01:03 AM   #17
wildmanvan
1) Lift up the radiator fan shroud and pull it toward you, the front of the van - you will now be able to look down and see the head of the allen bolt that holds the clutch on.
[/QUOTE]
I just went through the process myself and found that the plastic shroud on my '05 fully encompasses the fan & clutch so even after I unclipped everything I was unable to pull it up or towards me.
Luckily/unluckily the plastic shroud was cracked so I was able to gently pull the larger part of the wishbone aside.
I am curious if you (or anybody) has pics of how they did this step without the crack in the plastic mine had.
wildmanvan is offline   Reply With Quote
Old 05-09-2019, 03:33 AM   #18
gl21133
Solid write up, though I didn't hit the 20 minute mark. Maybe 40, mostly due to figuring out how to stop the pulley from slipping. A couple additional tips:
-The drivers side clips on the fan shroud are easier to remove and replace from underneath.
-Putting the plier jaws on the rivets (I think they're rivets) on the front of the pulley makes it a lot easier to keep it in place.
gl21133 is offline   Reply With Quote
Old 06-04-2019, 07:10 PM   #19
marklg
I replaced the viscous fan clutch for the second time. The first time I used a no name knockoff. It self destructed in two years. This time I used a Febi-Bilstein OEM from Europarts with a new fan blade too. The old clutch is on the right. The bearing tore itself up and pieces fell off when I removed it. Luckily it stuck on, so I had plenty of cooling and noise!
The old fan blade was the original. The new one looks different.
Here is a closeup of the destroyed bearing on the old one.
Regards,
Mark
The Following 4 Users Say Thank You to marklg For This Useful Post:
Aqua Puttana (06-04-2019), autostaretx (06-04-2019), GPLYNCHBURG (10-28-2019), Midwestdrifter (06-04-2019)
Old 06-04-2019, 09:28 PM   #20
The original fan looks slightly asymmetric ... the blades don't appear to be spaced evenly.
(but it could simply be the slight angle of the photo)
I wonder if that's to avoid setting up some resonances?
