Old 06-21-2018, 11:08 AM   #1
hapaschold
Default 2018 is here and i missed a couple things
hi all,
missed a couple things, like the rear step bumper
and I am thinking I made a mistake getting the heated windshield, for some reason I thought the option was just heated at the wiper / bottom so the snow and ice would not pile up hopefully,
but seems to be the entire windshield. all the wires create an interesting view thru the windshield at times when driving.
I d say like looking thru a cheap pair of sunglasses look.
least got the factory trailer hitch thou
'18 sprinter 144 , brilliant silver
'16 s550, iridium silver
'12 s350 , palladium silver FOR SALE , new S is here
'08 sl550 mars red
'91 560sel grey also, only 81,000 miles. a garage find nov 2017
hapaschold is offline   Reply With Quote
Old 06-21-2018, 04:05 PM   #2
sailquik
sailquik's Avatar
Default Re: 2018 is here and i missed a couple things
hapaschold,
Probably can't get the trailer towing crossmember AND the step bumper.
Lot's of receiver hitch mounted rear steps on the market.
The hitch steps work almost better than the step bumper and come in all
sorts of heights/designs/colors/finishes.
Here's the step I'm using:
https://www.autoanything.com/towing/...IaAiLrEALw_wcB
Roger
2019 Sprinter 519/907/VS30 series (3500 DRW) 170"/4325 mm wb Hi Top Short Back
OM-642 3.0 liter V6/7G-Tronic, 7 Speed manually shift-able transmission.
OEM back up camera, LED light package, fog lamps,
Had 2014 516 OM-651 I4/7G-Tronic|2010 NCV3 519/3500/144|2011 & 2012 NCV3 519/3500 170
2006 T1N 3500/158
The Following User Says Thank You to sailquik For This Useful Post:
Old Crows (06-29-2018)
Old 06-21-2018, 04:46 PM   #3
Wrinkledpants
Originally Posted by hapaschold View Post
hi all,
It took me awhile, but I got used to seeing through the heated windshield. I had a regret phase for awhile, but eventually stopped noticing it. It does come in handy quite a bit and helps keep the ice buildup off the wipers - which is nice.
2017 144WB 4x4
Wrinkledpants is online now   Reply With Quote
The Following User Says Thank You to Wrinkledpants For This Useful Post:
Old 06-21-2018, 04:48 PM   #4
bobloblaw
Ive got the heated windshield which is an option I probably wouldn't have ordered (we basically got the van off the lot). I'll say that after a while you dont notice the wires.. I dont anymore.
And, when it's snowing or icy, not having to scrape that windshield will be worth it.
bobloblaw is offline   Reply With Quote
The Following User Says Thank You to bobloblaw For This Useful Post:
Old 06-21-2018, 05:44 PM   #5
autostaretx's Avatar
We bought our T1N off-the-lot ... and had the dealer add the step bumper and two rear grab handles as part of "dealer prep".
(we already knew that doing that doubled the cost of the options compared to ordering-with-build, but them's the breaks).
As Dodge/Freightliner/MB had it, the step bumper was incompatible with the trailer hitch (which we don't have).
BUT ... clever folks here on the forum figured out how to mount the hitch despite the existence of the step bumper.
For our wants/purposes, an in-hitch step would not be anywhere near as nice as the full-width step bumper.
Old 06-21-2018, 09:17 PM   #6
Ace in the hole
I have the factory hitch and added a rear step. Took a little figuring to make it work but it can be done.
I too have the heated windshield. Took a few days to get used to it but it doesn't bother me now
Ace in the hole is offline   Reply With Quote
Old 06-22-2018, 10:18 AM   #7
hapaschold
does the heated windshield stay on until either cycled off by driver or turning off the van ?
cant wait to see what that windshield costs after getting smashed
my 2015 144 was 505 bucks, but a standard windshield.
thanks all !
'08 sl550 mars red
Old 06-23-2018, 05:23 AM   #8
Llarry
Llamasine driver
Llarry's Avatar
Since you have the tow package, you could add a step that inserts into the hitch receiver. Not as wide as the factory step and can't be used when towing, but less expensive.
Llarry
2004 P2500SHC 158"
Llarry is offline   Reply With Quote
Old 06-23-2018, 07:00 PM   #9
Although it's fed by a fuse that's hot all the time (i.e. not turned off by the key), the heated windshield itself is controlled by a relay that's (in turn) driven by the Body Control Module.
I have no idea what convinces the BCM to turn the heater on and off.... perhaps temperature?
diagram from 3rd party 2007 schematics here: http://diysprinter.co.uk/reference/0...inter-2500.pdf
Old 06-25-2018, 02:57 AM   #10
danski0224
A heated windshield is one option I wish I had.
danski0224 is offline   Reply With Quote
