Old 06-23-2019, 07:17 AM   #21
IPT
Default Re: easy fix for water leaks on side body panels
Wow, third try at posting.....do I understand correctly that this can be slipped into place without removing the trim (with some trimming here and there)? Any particular source for the gasket?
IPT is offline   Reply With Quote
Old 06-23-2019, 11:09 AM   #22
feynmanfan
The gasket (extrusion on my world) is from 8020. That said, note that they offer a few versions depending on the aluminum extrusion system. The original video (OP) used 2115 and that is what I used. Others have used different profiles with success. I can not comment on which is best/easier to work with. I can point out that I did not trim. I did notice the van's panel clips were close to the trim so a longer trim leg may need trimming. I attached a few profiles for ref. Also note the TPE (thermoplastic elastomer) versus silicone decision. It I get ambitious, I may buy a section of everything that makes sense and perform a "review".
feynmanfan is offline   Reply With Quote
Old 06-25-2019, 07:03 AM   #23
IPT
Stumbled on this today - seems that he's using the same product.
Old 11-25-2019, 06:01 PM   #24
Legwound
does anyone have a Canadian supplier for this or a similar gasket?
Legwound is offline   Reply With Quote
Old 11-25-2019, 10:28 PM   #25
hein
Van Guru
We have some in stock and would be happy to ship it to Canada. Please reach out to Kim.
All the best,
Hein
DIYvan.com
541 490 5098
P.S. We do have the silicon version which 8020 said would do better in the weather.
2010 MB 3500 RV conversion.
Old 11-25-2019, 10:40 PM   #26
OrioN
2008 2500 170" EXT
OrioN's Avatar
The 8020 trim is not UV resistant and its operating temperature rating is 0C - 40C. Depending on where you live, it may not last very long.
Old 11-25-2019, 11:46 PM   #27
GeorgeRa
2013 Sprinter DIY 144WB
GeorgeRa's Avatar
I sealed at the sources of leaks, the holes where fasteners go into the sheet metal 6 years ago. It is fixing the weak point of the problem and it works. This method is immune to UV, to highway driving in pouring rain where water splashes from everywhere.
I used 80/20 silicone seal between panels and 80/20 15 series profiles to prevent vibration so I am familiar with this product.
George.
https://goo.gl/photos/2NCR3teXLSwNYSwN8
GeorgeRa is offline   Reply With Quote
