SubForums: Events Scanners
Old 09-21-2019, 01:14 AM   #1
yimmortal
Default Fix it or not???
My 2006 sprinter blew the engine. Bad piston or rings. Iím in Vegas and the average price is about 11k for a reman engine and install. Iíve converted it into a camper and have about 20k in the conversion.
What does everyone think? Should I replace the engine or just buy a brand new something and switch all the interior over to a new one?
Iím concerned that itís becoming a money pit and something else is just around the corner. 193k miles
Opinions please?
yimmortal is offline   Reply With Quote
The Following User Says Thank You to yimmortal For This Useful Post:
tomd4s (09-23-2019)
Old 09-21-2019, 02:01 AM   #2
OrioN
2008 2500 170" EXT
OrioN's Avatar
Default Re: Fix it or not???
Go for the reman @$11k....
Worry abooot the other stuff breaking when it occurs.
sailquik (09-21-2019)
Old 09-21-2019, 02:31 AM   #3
Zundfolge
1-2-4-5-3
Zundfolge's Avatar
Good used takeouts are also an option, especially with such a high investment in a conversion. $4000-$6000 range? If I were in your shoes (but still carrying my wallet) that's the route I'd go. I know Dennis (lindenengineering on here) sometimes keeps them around for exactly your scenario. Worth considering IMHO.
Edit: if "not" is chosen there's very little chance you'll recover any appreciable value from your old van...
'06 Sprinter ~270K
'83 Mercedes OM617 manual
ē
https://nicktavasieff.smugmug.com
Zundfolge is offline   Reply With Quote
Old 09-21-2019, 03:45 AM   #4
BrennWagon
Pete
Just so long as the body and subframe are in decent shape, fix it. Swapping out your build to another van will be much more expensive once you consider the time to swap added to the cost of the replacement van.
Good luck
BrennWagon is offline   Reply With Quote
Old 09-21-2019, 04:04 AM   #5
NelsonSprinter
Former Nelson BC Sprinter
NelsonSprinter's Avatar
It depends.
Did you regularly maintain and monitor your old engine?
If not, expect something similar could recur from bad injectors or wrong oil use
Previous owner of '02 FL 2500 140WB Cargo door windows, 15" Alloys, LT235/75R15-E Nokian Rotiivas, Nokian Hakka C studded winters, Curt 4 hitch, 3.72 rear with 30MPG Cdn GDE ECO Tuned. . .
I am NOT a MECHANIC, I just play one online.
'02-'03 Fuel filter leak fix http://sprinter-source.com/forum/sho...ix+fuel+filter
15" tire options http://sprinter-source.com/forum/sho...t=tire+options
NelsonSprinter is online now   Reply With Quote
Old 09-21-2019, 12:32 PM   #6
lindenengineering
AH hah!!
The rules of THUMBbellina again.
If the van is worth more than 70% of a new/factory rebuilt engine then its worth considering.
As with any major unit , if rebuilding an engine & it amounts to LESS than 70% of buying a replacement engine, then consider it a good proposition.
If a good used take out is 70% of the van's value then again consider it.
Dennis
The Following 2 Users Say Thank You to lindenengineering For This Useful Post:
BrennWagon (09-21-2019), hkpierce (09-23-2019)
Old 09-21-2019, 04:48 PM   #7
showkey
This has been asked before............does not get easier. As many have chosen not to repair rebuild vans 4-6 years newer with half the miles.
193k. body rust ??????????
193k Transmission and rear end ??????? Potentially another $7-8k
2008 3500 chassis Class C built in 2010
Pulling 6x12 enclosed trailer
showkey is online now   Reply With Quote
