Go Back   Sprinter-Forum > Regional Discussions > Europe
Old 04-04-2019, 09:43 PM   #1
Jonesyyy87
Post Air leak injector learn.
Hi all,
First time posting so bare with me.
I had an injector go Just before Christmas. Iíve had all 4 replaced and my question is do the injectors need to be learnt on a star machine or do they just need to be coded? Basically ever since the new injectors have been installed the engine runs as I can only describe as ďroughĒ at around 2000/2500 rpm and thereís a loss of power as well as a aggressive vibration/rumble which I can feel through the steering wheel as well as the rest of the van. Iíve had the egr off cleaned it all out as it was gunked up but is working fine now, Iíve had a new dpf installed nearly every sensor you can think of replaced but itís still running ďroughĒ. When Iím accelerating I can hear a hissing noise from what sounds like the passenger side of the engine. There no codes stored on the ecu and now Iím starting to lose my patience!!! Could it be a simple air leak?
Mercedes Sprinter 313 2010 reg
Any help much appreciated.
Jonesyyy87 is offline   Reply With Quote
Old 04-04-2019, 09:44 PM   #2
Jonesyyy87
Default Re: Air leak injector learn.
Just thought I’d add that when idle engine ticks over fine.
injectors, turbo hose, vacuum pump
