Old 02-14-2014, 11:42 AM   #11
Eric Experience
Eric Experience's Avatar
Default Re: No turn signals . Help.
Nick.
Some one else posted the drawing. Sounds like you did a good job with the fire hose. If you take the trim off around the switches and them clean the switches as best you can with compressed air you may get the dirt out of the switches. Eric
Old 02-14-2014, 12:20 PM   #12
MillionMileSprinter
Formerly Type2Teach
MillionMileSprinter's Avatar
I would second swapping the grey relays on the bottom of the steering column fuse box. My buddy had similar issues with his blinkers and after cleaning everything, i finally swapped the two relays next to each other. Viola! No more blinker issues.
Sprinter Mechanic
Joel Sell
For HELP, SERVICE and MORE
The Following User Says Thank You to MillionMileSprinter For This Useful Post:
SILVERFOX (02-15-2014)
Old 02-15-2014, 04:24 AM   #13
SILVERFOX
SILVERFOX's Avatar
Thanks again.
If we get to the bottom of this I hope it can also help others in the future.
I will have a play with it tomorrow or Monday. Does anyone know if the relays are available in most places or are they a bit special???
Cheers
Nick.
SILVERFOX is offline   Reply With Quote
Old 07-14-2014, 01:52 PM   #14
SILVERFOX
SILVERFOX's Avatar
HI AND THANKS TO ALL FOR YOUR HELP AND COMMENTS. Well I finally found it was the relay in question. Problem solved and has been reliable. Thanks again. Nick.
Old 07-14-2014, 09:07 PM   #15
Originally Posted by Type2Teach View Post
... i finally swapped the two relays next to each other. Viola! No more blinker issues.
You might consider buying a replacement relay.
By swapping those relays you moved what is possibly a defective relay causing an intermittent wiper issue to the engine relay position which could set you up for future engine operation problems.
My opinion. Much better to leave the engine relay alone and swap the two less critical outside relays.
Old 07-19-2014, 12:58 PM   #16
SILVERFOX
SILVERFOX's Avatar
Thanks for the suggestion Vic. Do you think I should simply replace the three relays at the bottom of the fusebox?
Old 07-19-2014, 05:38 PM   #17
MillionMileSprinter
Formerly Type2Teach
Point well taken, Vic. Where can I buy those relays other than the stealership?
Sprinter Mechanic
Joel Sell
Old 07-19-2014, 08:36 PM   #18
MillionMileSprinter
Formerly Type2Teach
By just pulling them out and cleaning them, I have fixed (for now) the flasher issues on 3 different T1Ns. No one has come back for a re-fix. I would like to have a new one on hand, but will continue to just clean the contacts until there is a need to actually replace the relay.
Sprinter Mechanic
Joel Sell
Old 07-20-2014, 04:38 AM   #19
Personally I would not mess with the center position engine ECM aka ECU relay unless it has given some indication of trouble. "Let sleeping dogs lie." comes to mind.
I'm not certain whether the paticular Amazon information below will help on your side of the world, but the info from the box may have some value.
Some info is here.
http://sprinter-source.com/forum/sho...808#post315808
Old 01-27-2015, 11:42 PM   #20
blisspacket
2002 T1N, 2014 I4-7spd
Putting in my two cents. This seems a great thread in that Cheyenne posted that nice diagram of fuses and relays under the steering column. Yes, I had the same intermittent operation of turn signals. Then nothing. At one point I opened up the relay and attempted to dress the points. Best solution was spend $7 each at an Amazon site and got three relays to RnR all three. Turn signals operate now as do wipers. Fly in the ointment: sometimes I get a "Start Error" which creates NO action when I turn the key to start. I'd had an electrical drain a few years back, so have an underthedash major battery disconnect switch. Per another guru on this site, I simply do a battery disconnect, reconnect, and my "Start Error" has disappeared, I'm off and away. I dread the day when Start Error reappears, but so far allz well. I have 120k miles on this Sprinter, it's a gem in so many ways, and this Forum is a superb asset, but I gotta say I'm disappointed. Not so much so that we didn't jump onto an 07 V6 that is a marvel of engineering--I hope!!
blisspacket is offline   Reply With Quote
